Author Topic: Tonti frame measurement please  (Read 1150 times)
Offline gearman
« on: July 16, 2017, 02:41:29 PM »
I am trying to put my convert back together and need the exact measurement between the rear shock stud and the edge of the frame rail as per picture.
cheap image hosting
up load pictures
    Also the correct orientation of the formed flattened area. They could be in wrong in my photo.You might need an empty frame  to measure. thanks   I see that the picture got cropped. The dumb end of the tape measure is up against the rear side or the shock stud and the measurement is read with the right edge of the frame hole.
« Last Edit: July 16, 2017, 02:45:11 PM by gearman »
Offline guzzista
Re: Tonti frame measurement please
« Reply #1 on: July 16, 2017, 03:58:57 PM »
Quick measurement on short neck Tonti ( SP) FRAME IS 280MM center to center from shock upper mount to rear frame hole
