Author Topic: Good news for 8V owners.  (Read 3785 times)
« on: July 19, 2017, 12:54:41 AM »
One of the most vexing things with the 8V motors is the fact that the front main bearing is a split bearing pressed into the case itself and is therefore 'Not a service item'. This effectively means that the factory wants you to buy a new crankcase if you damage the front main.
Now Ron in Queensland got in contact with King Bearings who he has dealings with for aeroplane/helicopter stuff and they were singularly disinterested in trying to help find a solution! :angry:
Anyway while buggering about with the 1400 motor I grabbed the old 1200 crank and a front main off one of the earlier 2V engines. Well surprise, surprise, journal sizes and clearances are exactly the same. The only difference is the case isn't machined for the bearing. All the bosses for bolts etc. are there though so it looks like all that needs doing is machine the inner face of the timing chest to suit the bearing depth, drill the bolt holes and get the feed gallery to line up.
Obviously getting alignment right will be critical but you can get the X and Y coordinates off the rear main and sorting the depth won't take a lot. It'll Aldo mean we can sort three undersizes for both front and rear mains and crankpin if needs be! WIN!
Re: Good news for 8V owners.
« Reply #1 on: July 19, 2017, 01:09:37 AM »
 Pete , sometimes you amaze us . This info will save lots of money for 8V owners .
« Reply #2 on: July 19, 2017, 01:21:50 AM »
Look, the parts and machining of the case and fixings will probably rival the cost of a new case BUT once that work is completed you're back to the point of having three under-grinds for the journals and no need for a new crank if there is journal damage.
The reason why they went to the new system would of been purely cost. Fewer machining operations, simpler installation, lower component cost but it isn't 'Owner Friendly' if you're wanting to ride the machine as something other than a 'Disposable item'. There is no reason an 8V need be any less durable than an old Loop or Tonti, what man has made man can make again. It's just working ways around the 'Disposable Culture' mindset which I detest.
« Reply #3 on: July 19, 2017, 01:38:16 AM »
 Yeah , same here mate . Sometimes seems we can't have modern tech W/O the modern idea of "throw it on the rubbish heap and buy a new one" . That's why guys like you are so important , figuring out ways to fix what wasn't designed to be fixed .
« Reply #4 on: July 19, 2017, 02:28:55 AM »
And you wonder why the bloody hell people put you on a pedestal Pete !!! Sorry if it shits you to tears, but some of us would be rooted or pay through the nose without your expertise. Thanx on behalf of the 8V crowd. (Poor bastards) :evil:
« Reply #5 on: July 19, 2017, 02:41:12 AM »
Nobody should 'Put me on a pedestal'. I'm just 'Some bloke'. I just happen to be passionate about Guzzi and particularly the CARC bikes. That's all.
« Reply #6 on: July 19, 2017, 03:48:24 AM »
 :bike-037:d
Yeah point taken Pete, I/we accept that, but thanks for sharing your knowledge or making us the recipients. Anyway no more of that... Hope you ask for help if you ever need it and am able to. BTW, what's the wash up with your young bloke ?
Offline nobleswood
« Reply #7 on: July 19, 2017, 11:43:08 AM »
Alright, scratch the 'put you on a pedestal ' bit.  But certainly buy you a few beers
 :boozing:
2013 1200 8v Griso
« Reply #8 on: July 19, 2017, 11:51:30 AM »
 Thing is Pete , we know you are a cantankerous old goat , but you are OUR cantankerous old goat  :grin:
Offline flip
« Reply #9 on: July 19, 2017, 02:09:00 PM »
Pete, if you were with Gilligan and the gang on that 3 hour tour, you'd have found a way to fix the boat and get them off of that island in the first season!
« Last Edit: July 19, 2017, 02:10:38 PM by flip »
North Carolina
Offline bigbikerrick
« Reply #10 on: July 19, 2017, 04:20:32 PM »
Now thats a cool analogy!!
Rick.
Offline wymple
« Reply #11 on: July 19, 2017, 05:06:35 PM »
Yup, as long as the boat was Italian..... :bow:
« Reply #12 on: July 19, 2017, 05:19:43 PM »
With a V shaped hull
Offline pauldaytona
    • Paul's fast Guzzi Page
« Reply #13 on: July 20, 2017, 02:36:06 AM »
I suppose they had the 2v norge engine on the drawing board when they started the 4v engine. So that the base mold is the same is no surprise. Evolution instead of revolution.
Paul
Daytona 1225, Stelvio 1151
Rough Edge racing
« Reply #14 on: July 20, 2017, 07:21:34 AM »
 I believe the cost in the USA to have the case line bored/reamed by a competent auto machine shop would be in the $250-$400 range depending on the jigging required..
Offline Diploman
« Reply #15 on: July 20, 2017, 07:22:54 AM »
Down with Disposable Culture!!  Up with Pete!!
2015 KTM 390 Duke
