Motoul 7100 was used for the first oil change and will be used for the second, in about a month.http://wildguzzi.com/forum/index.php?topic=89848.msg1420688#msg1420688I was planning on switching to Castrol 10/60, API SN (readily available and reasonably priced) , but this discussion has convinced me to stay with Motoul. Be good to find it for less than $63.25 for 4 liters!Fortunately O'Reilly's has a very liberal return policy, so I can return the 6 quarts @ $7.99 each.
I would add that anti-foaming tendency would be an important attribute since Guzzi relies heavily upon oil cooling. One thing I noticed on the product info page for ENI/AGIP 10W60 is a specific reference to strong anti-foaming additives. My Ducati's always had a sight glass, which was handy not only for a quick spot check of the oil level, but after high rpm run you could pull off, stop and check the sight glass for foam. The only oil I ever saw exhibit a rather disturbing amount of foam which appeared as the top 1/2 of the oil visible in the sight glass, was Amsoil MCT 10W40, their motorcycle specific oil supposedly JASO MA API/SL approved. Mobil 1 Racing 4T 10W40 never showed any surface foam or even surface bubbles. Silkolene Pro 4 15W50 would show very minor surface bubbles. Spectro Platinum 4 no foam or bubbles.Of course, what can be seen through a one inch diameter sight glass is certainly not solid proof, but it can give hints.
I would be more concerned if the oil met the weight range. Is you Duck okay with 10W40?
One of the friends here had same year Multi-Strada. Too many problems with the bike. He turned it back into the dealer. The last I heard is that he got another large Monster.
If guys would worry as much about what they put in their bodies as they do what oil they put in a their put in their engines they would be a much healthier bunch. It`s kind of funny but sad also. Anyway, anybody ever seen an engine failure that can be directly related to not using the "correct" oil ? I have seen grey paste like stuff in the bottom of Motul oil bottles, which always concerned me.
Ummm. . . . yes. . . .That gray paste is probably part of the additive package -- moly, if your spec calls for moly, since that seems to fall out of solution readily and appears as a gray paste. The moral of the story is to shake it, shake it good, before pouring.
How would I shake it if it sat in the bike for 3 months of winter?
If you should shake moly good before putting it in your bike doesn't sound like it should be put in your MC in the 1st place. Sounds like you should then shake your MC oil good before you ride it again. I haven't added moly for decades in my Guzzi oils and have never regretted it. I just use GL-5 oil and have yet to have a gear failure, no matter the viscosity.
Once you start riding it, the action and heat will reconstitute. Ever made a cake with a blender, its the same principal!
Sounds ignorant.
Kind of mean spirited
Sounds ignorant.I've been doing this, riding Guzzis for 33 years for maybe 200K miles on 5 different ones . How long have you been riding Guzzis, Rodekyll?
A reasonable reply to a mocking comment.BTW -- do you have any idea what goes on inside a guzzi engine? Think about it. It self-stirs. One big challenge in the 90ºV is keeping the whipping and splashing under control.
Rk, you don't put moly in the motor, you put it in the rearend. You just flunked this test.
Quote from: rodekyll on August 03, 2017, 11:05:26 PMSounds ignorant.I've been doing this, riding Guzzis for 33 years for maybe 200K miles on 5 different ones . How long have you been riding Guzzis, Rodekyll?You're a neophyte, then. I've owned my daily driver, Rodekyll, much longer than you've been riding. I've got 200k on it alone. Got my first one, Rollonda, in '74. Mt. St. Helens killed it or I'd probably still have it kicking around, too. I liked Rollonda, except for the brakes. But anyone can ride them. As a certified mechanic, I've never had one in the shop.Any more questions?
Why the drama? It's just a discussion.
