Author Topic: CX100 Craigslist seattle  (Read 4256 times)
« on: July 22, 2017, 11:00:04 PM »
Re: CX100 Craigslist seattle
« Reply #1 on: July 23, 2017, 12:49:19 AM »
I have a `81 CX100.  This wannabe doesn't have the original fairing/headlight, dash, or the lower fairing, and probably 111,000 miles on the motor, since it just keeps on rotating.  BTW, that original seat feels like a 2X6  piece of wood when you sit on it for more than 30 minutes.  If the original fairing, dash, are in such great condition, why were they replaced?
« Last Edit: July 23, 2017, 01:32:10 AM by Arizona Wayne »
« Reply #2 on: July 23, 2017, 01:29:02 AM »
Those seats were disgraceful from the start weren't they ?
« Reply #3 on: July 23, 2017, 01:35:27 AM »
As far as comfort, yes.  They split your cheeks, if nothing else.  :huh:
« Reply #4 on: July 23, 2017, 01:52:24 AM »
Never been around the block on one. My Mk 2 came with a brand new curvy styled thingy, I've seen lots of them but don't know what they're standard on. Still have the tidy original but won't use it.
« Reply #5 on: July 23, 2017, 02:53:21 AM »
I have news for you, the only difference between your LM II and a CX100 is the motor.   Everything else is the same when new.  Your LM II had a 850 motor and the CX had a 949 motor.  In the USA your 850 motor wasn't clean enough to pass our stringent pollution test.  So over here the CX came with the SP motor instead that could.  :wink:  In Canada they also got the LM II.  The LM II you bought apparently had an aftermarket seat.
« Reply #6 on: July 23, 2017, 05:26:08 AM »
 :1: on the engines.  Too much for the asking price and it's not close to Seattle.
Offline Swedemoto
« Reply #7 on: July 23, 2017, 09:04:22 AM »
Can anyone tell me what PN# the carb manifolds are? they are different than the cast originals are on my '80 SP.
« Reply #8 on: July 23, 2017, 09:38:04 AM »
[/quote]
I have those of my CX, Can't tell you a PN, I got mine @ Harpers. Call Curtis  :thumb:
Wayne doesn't really have a CX, he makes that @#$t up
« Last Edit: July 23, 2017, 09:41:26 AM by Guzzistajohn »
« Reply #9 on: July 23, 2017, 02:52:23 PM »
 :1:  He's really a laptop set on auto-response.  :wink: :grin: :grin: :grin:  CX's came with the square slide carbs.  Both the '80 & '81 that I have don't have those carbs.
« Reply #10 on: July 23, 2017, 03:03:32 PM »
The `80 and earlier CXs had square slide carbs.  The `81 had round slide carbs.  I've had my `81 since `84 when it had. 6,000 miles on the odometer.   When new the intake manifolds were rubber elbows.
« Reply #11 on: July 23, 2017, 03:20:38 PM »
My '81 must be a transitional model.  It has square ones.
Online blackcat
« Reply #12 on: July 23, 2017, 03:35:38 PM »
Ugly is why I removed mine.
I still have the original seat and it's fine for around town, add some beads or a pad for long distance. Had a Gaman seat for like a week, then I ditched it as it was as hard as a rock.
My 81 had 30mm round slides and the clocks are in km with plastic lenses.
« Last Edit: July 23, 2017, 03:37:04 PM by blackcat »
« Reply #13 on: July 23, 2017, 04:25:08 PM »
I have those black intakes on my CX now.  They're made out of Delrin and are not really designed to support the carb. weight, so I have mine supported by long/thin black zip ties wrapped to the above frame. Believe I got  mine from MG Cycle.  :azn:
« Reply #14 on: July 23, 2017, 06:41:31 PM »
Me too, that rectangle headlight sucked too  :thumb:
« Last Edit: July 23, 2017, 06:43:13 PM by Guzzistajohn »
