Author Topic: Shim washers used on a Tonti 5 speed speedometer drive  (Read 1397 times)
Online acogoff
« on: August 07, 2017, 06:53:25 PM »
     Does anyone know of any reason why these hardened shim washers would not work on the speedometer drive? Mine had one missing and the one that was left measured 6m x  12m x 1m, the same as these. These are very hard, like 85 rockwell C. Maybe they are too hard.
https image
« Last Edit: August 07, 2017, 07:07:50 PM by acogoff »
Marshall County Minnesota USA
Offline nc43bsa
Re: Shim washers used on a Tonti 5 speed speedometer drive
« Reply #1 on: August 07, 2017, 07:07:31 PM »
If it's the same size, I don't see why it wouldn't work.
The washer you're referring to just keeps the gear from wearing into the case.
1990 MilleGT
Offline mtiberio
    • TiberioRacing
« Reply #2 on: August 08, 2017, 08:25:26 AM »
McMaster Carr? Why the tape?
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
Online acogoff
« Reply #4 on: August 08, 2017, 08:46:25 AM »
     You get the prize mtiberio. And you too Antietam. And the prize is-- my respect, which is pretty much worthless.  I had thought about having a quiz as to where these came from, but changed my mind before posting.
I had read that they are so impossible to come by and it turns out - no they are not.
« Last Edit: August 08, 2017, 08:51:44 AM by acogoff »
