Author Topic: Well that sucked  (Read 2963 times)
Offline lorazepam
  • Almost ready for suspenders
Well that sucked
« on: August 08, 2017, 08:37:55 PM »
I know what my next purchase will be for the V7. A center stand. I changed the rear tire tonight, and the easiest part was spooning off the old one, and putting the new one on the rim.
I have a paddock stand, but it does not raise the rear nearly enough to get the wheel off.
Is it ok to grease the cush drive rubbers when installing the wheel? they did not want to go back together without it. Tonight was an exercise in frustration for sure. Whine over.
Offline sign216
Re: Well that sucked
« Reply #1 on: August 08, 2017, 08:39:29 PM »
Yep, it's a trick to keep them from falling out.  Either grease, or add a little silicone caulk.
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
Offline lorazepam
« Reply #2 on: August 08, 2017, 08:45:23 PM »
I looped a ratchet strap around the rear drive after they were lined up, used a piece of wood as a spacer, and it "popped" right into place. The rubbers looked new after 6k miles.
Offline sign216
« Reply #3 on: August 08, 2017, 09:07:38 PM »
I'm putting a '69 Benelli back on the road, and it's original cush rubbers look good too.
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
Offline raul
« Reply #4 on: August 09, 2017, 08:27:35 AM »
The center stand makes that soooooooo much easier.
Missed you at the rally.
Offline lorazepam
« Reply #5 on: August 09, 2017, 08:38:08 AM »
I was off all bikes since last October because of vertigo issues. got it under control, (I hope) and have been riding scooters to get my confidence back up. Trashing a cheap Chinese scooter at 30mph is not as bad as destroying one of my bikes at highway speeds. I am feeling confident leaning into turns, and am getting the V7 in shape for some fall riding.
I will make the rally next year even if I have to drive.
« Reply #6 on: August 09, 2017, 01:40:19 PM »
Keep your head level in turns mate. Talk to Sky for good info.
Offline malik
« Reply #7 on: August 09, 2017, 05:01:41 PM »
It can be frustrating with those cush rubbers. My record is I think, around 2 hours. I gave up, had a cuppa & a smoke, held my tongue just so, & it went straight on.
Tip 1 - sometimes it goes on easier when the bike is leant over to the left - far enough for the tyre to clear the guard & the rubbers tend to stay in ( although those fingers on the hub can still pop one out or jam).
Tip 2 - even with a centre stand they can be problematic. I find a block of 2x4 under the stand (either the RHS or both sides) provides the room for the tyre to clear the mudguard again, & to finesse the alignment more easily.
Tip 3 - if at first you don't succeed, take a break. Come back to it when calm.
It seems to become easier, or at least less frustrating, with familiarity.
I also recommend having a few spare cush rubbers on hand, sooner or later you may find some broken & if they are, it's even harder to get that wheel on.
Offline sign216
« Reply #8 on: August 10, 2017, 04:18:38 AM »
Try some of the vintage Italian single cyl. bikes.  I've got a Sears / Gilera 106cc four stroke, that's almost as light as a moped, and as fun as a bigger motorcycle.  That, and a Wards / Benelli 350 are my "fall back" bikes for when the inevitable comes and the V7 is too much to muscle around.
I originally bought the Gilera 106 for my son.  He and I rebuild vintage Italian mopeds, and I wanted him to "graduate" to a motorcycle with a shift-able transmission.
« Last Edit: August 10, 2017, 04:22:30 AM by sign216 »
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
Offline lorazepam
« Reply #9 on: August 10, 2017, 10:07:41 AM »
I have no trouble moving the V7, or my Calvin around, it was more about inducing vertigo while riding. It is now under control, hasn't happened since I go treatment from my doctor, plus no more alcohol, and I have been taking Meclazine. It sucks to finally have to take a medication, as I made it 59 years without having to take anything on a regular basis.
It was a fear of having an incident while riding that kept me off the bike.
« Reply #10 on: August 10, 2017, 07:40:15 PM »
Ok -- just have to ask out of general curiosity -- if you haven't taken anything regularly for 59 years, why the screen name?
« Reply #11 on: August 10, 2017, 07:45:21 PM »
 The vertigo will more than likely be self limiting . I find that motorcycle riding doesn't bother me , but riding in a car on a curvy road W/O tilting my head causes the problem . Do the exercises.
Offline lorazepam
« Reply #12 on: August 10, 2017, 07:50:17 PM »
It usually isn't taken on forums, and it is easy to remember.
« Reply #13 on: August 10, 2017, 07:59:09 PM »
Alrighty, then.    :grin:
Offline lorazepam
« Reply #14 on: August 10, 2017, 08:06:06 PM »
Most folks have no clue what it means. I have been trolled by guys that thought I was female,"but it has pam in it"
