Author Topic: The Fugitive 1400 motor in a Tonti frame merged threadfest  (Read 20620 times)
Offline redrider90
http://www.bikeexif.com/radical-guzzi-cafe-racer
“The goal was to take the Moto Guzzi cafe racer to the next level,” says Radical collaborator Kris Karathomas.
“To cross the line of 100 horsepower and the torque typical of a two-valve engine. The logical consequence was to implant a 4-valve engine into the Tonti frame.”
The powerplant is sourced from Moto Guzzi’s 1200 cc Griso—but with the larger pistons and cylinders from the 1400 California. Specifications vary according to customer requirements, but hotter cams and Keihin 41mm FCR carbs are usually specified.
This boosts engine output to 130 horsepower and 112 ft.-lb. of torque. To put that into perspective, the stock California pumps out 96 horsepower and 89 ft.-lb.
Even more pertinent is the weight: Ristretto tips the scales at just under 200 kilos (440 pounds) with a full tank, while the California is 336 kilos'"
« Last Edit: March 08, 2020, 09:17:14 PM by oldbike54 »
Red 90 Mille GT
Offline Chesterfield
Re: Cafe 4V 130 HP Griso motor in Tonti frame
« Reply #1 on: August 14, 2017, 03:04:08 PM »
That is cool!
Online fotoguzzi
« Reply #2 on: August 14, 2017, 03:04:26 PM »
Needs fenders
« Reply #3 on: August 14, 2017, 03:06:48 PM »
Needs fenders
And nicer looking wheels.
And air filters.
« Last Edit: August 14, 2017, 03:07:49 PM by Triple Jim »
Offline Groover
    • Scooteropolis
« Reply #4 on: August 14, 2017, 03:36:27 PM »
I like! I wonder how that final shaft/drive is handled...
« Last Edit: August 14, 2017, 03:42:24 PM by Groover »
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Offline bad Chad
« Reply #5 on: August 14, 2017, 03:47:54 PM »
Wow, I wonder how this works?  It's siting it a frame originally designed for what, 55-60hp?
beetle
« Reply #6 on: August 14, 2017, 03:53:35 PM »
130HP? Bwahahahahaha!
112ft/lbs? Bwahahahahahaha!
With carbs? Bwahahahahahahahaha!
In a Tonti frame? A frame and bevel box designed for 60HP? Teehee!
Utter shite. I have never seen a dyno chart to back up these stupid claims.
I fart in their general direction.
« Reply #7 on: August 14, 2017, 03:58:59 PM »
 Mark , are you saying you don't believe the claims ?  :grin:
« Reply #8 on: August 14, 2017, 04:14:19 PM »
Somehow that sounds like Pete, I'm surprised it wasn't a munter. If you put it in a loop frame it would have the alt and room for EFI. Just think of the driveshafts you could twist off.
Offline redrider90
« Reply #9 on: August 14, 2017, 04:15:57 PM »
They claim they had sold 3 of them a $50K a pop
"Moto Guzzis are rarely prone to �shaft jacking.� But given the Ristretto�s high engine output, builder Stefan Bronold decided not to takes any chances. He�s designed and fitted a tubular-framed swingarm with more torsional stiffness than a factory original.
You get a choice of two wheels: conventional spoked items, or the striking solid disc wheels shown here�forged from aluminum, and made by RevTech."
Radical Guzzi "The Fugitive" Moto Guzzi Cafe Racer 1380cc 8V Motor
https://www.youtube.com/watch?v=slhYT1pKL4s
« Last Edit: August 14, 2017, 04:29:14 PM by redrider90 »
Red 90 Mille GT
beetle
« Reply #10 on: August 14, 2017, 04:25:23 PM »
Dusty, that's exactly what I'm saying.  :laugh:
Maybe I'm hanging out with Pete too much. Yes, I'm thinking about drive shafts twisted up like spaghetti and bevel drives with rooted internals.
That's a lovely swing arm. It'll hold the spaghetti twisted drive shaft very nicely.
 :grin:
« Reply #11 on: August 14, 2017, 04:37:22 PM »
Mark,    That's why I own 4 extra drives and a box of shafts. Stuff is getting pricey these days.
beetle
« Reply #12 on: August 14, 2017, 04:43:14 PM »
You're telling me. 50K for that pile of poxy munt?
Egads!
Offline rtbickel
« Reply #13 on: August 14, 2017, 05:18:59 PM »
That's one of the worst looking exhaust systems I've  ever seen.
2020 V85TT
« Reply #14 on: August 14, 2017, 05:43:08 PM »
It was explained to me that the reason the Germans keep sticking newer motors in ancient, overworked bits of shite like this is due to their type approval regs. It seems you aren't allowed to modify any bike newer than a certain date and that date predates the V11 spine frames or the CARC platforms.
The result seems to be this endless 'Groundhog Daying' of bolting 1200/1400 Hi-Cams into poor old Tonti frames, sticking the five speed lathe gearbox behind it with a clutch designed for at most 2/3rds of the power and torque the motor will produce then finally spitting the absurd power claims out through a bevelbox designed for 60 HP with tooth areas about a third of the size of the teeth in a CARC bevelbox, half the size of the teeth in a V11 bevelbox. All the bearings in the Tonti box are about a 1/4 the size of those in the CARC box! It's simply ridiculous!
Then the crowning glory! Stick poxy carburettors on it!
Look, if people like the look of it? That's fine! I think it's a hideous joke but I accept that others will have different tastes but please, for the love of all that's holy, don't pretend for a moment that it is either wise or capable in engineering terms or capable of matching the absurd claims made for it!
Oh, here's a picture of one of the horses used to calibrate the dyno used to gather the data on this machine's performance.
« Last Edit: August 14, 2017, 05:49:46 PM by pete roper »
« Reply #15 on: August 14, 2017, 05:58:31 PM »
 I had a 1950 Plymouth Club Coupe with an advertised 78 HP that probably used those little bitty horses as a unit of measure. It required a calendar for performance testing  :shocked: The really scary part was braking performance , 60 to zero MPH in 2 days . Of course that was moot , because anything above 50 MPH required a 15 MPH tail wind  :rolleyes:
« Last Edit: August 14, 2017, 06:05:44 PM by oldbike54 »
Offline guzzitime
« Reply #16 on: August 14, 2017, 09:12:54 PM »
Could they put some air filters in it pleaz? A sure waste of effort not to
Online fotoguzzi
« Reply #17 on: August 14, 2017, 09:19:14 PM »
you mean those pygmy ponies? these are called therapy ponies so they could get into our TV studio.
Online Turin
« Reply #18 on: August 14, 2017, 10:05:43 PM »
If you like that sort of thing...
1986 Sidlow Guzzi
1996 Triumph Daytona 900
« Reply #19 on: August 14, 2017, 10:36:22 PM »
Please see Rotten Ralph's recent thread.   http://wildguzzi.com/forum/index.php?topic=91797.msg1448873#msg1448873
« Last Edit: August 14, 2017, 10:38:11 PM by Triple Jim »
« Reply #20 on: August 15, 2017, 06:09:06 AM »
Why and how can carburettors make more top end than FI? Top end power will be a matter of two things, accuracy of mixture and volumetric efficiency.
Fuel metering is far more accurate with FI. VE has to be lower due to the inherent energy consumption of forcing the air through a Venturi to move the fuel mass from the float bowl to the Venturi by way of a jet and atomiser, (Wth a conventional slide carb.).
Sorry, the laws of physics reign supreme. Everything else is tiddlywinks.
Rough Edge racing
« Reply #21 on: August 15, 2017, 06:11:07 AM »
 So none of you think a very modified 4 valve head Guzzi can't make 130HP?.....4 valve stock new Ducati's make well over 130 HP within the rules of emission standards..Yes I know a Ducati engine is far more developed than any stock Guzzi...
 And auto drag racers know that carburetors can make more top end HP than fuel injection...
Rough Edge racing
« Reply #22 on: August 15, 2017, 06:12:22 AM »
Sorry Pete I removed my post for clarification....Mo re HP in limited racing situations...I did say drag racing....
beetle
« Reply #23 on: August 15, 2017, 06:16:28 AM »
People who think they can make more HP with carbs, don't understand fuel injection. Or can't make it work.
« Reply #24 on: August 15, 2017, 06:26:25 AM »
I never said a word...............
Rough Edge racing
« Reply #25 on: August 15, 2017, 06:52:46 AM »
  Please do not take my statement out of context... Are you involved in land speed racing and drag racing like I am? Do you talk to the tuners about making power? Do you understand how a simple placement of injectors  in all so important for high end power? Do you think a sharp tuner in a small shop can even get close to a the resources and engineering the factory racing teams have?
Offline Groover
    • Scooteropolis
« Reply #26 on: August 15, 2017, 07:13:35 AM »
How about a 600cc engine on a Vespa 50cc frame?  :azn:
YouTube Video:
https://www.youtube.com/watch?v=wkVtCxkPDmo
1980 Vespa SI Moped
« Reply #27 on: August 15, 2017, 07:27:12 AM »
I helped a friend (RIP, Lyle) ruin a Metro..  :smiley:
Talk about something scary to drive..
« Reply #28 on: August 15, 2017, 01:51:53 PM »
Chuck, how far does that infinity effect go?  I can see three yellow Metropolitans in the photo.  Is there an even smaller one on top?
Offline redrider90
« Reply #29 on: August 15, 2017, 02:31:55 PM »
Hot damn I missed that one Jim. Had to go back and look and am going WT.... and then I saw them stacked like a wedding cake.  :weiner:
Red 90 Mille GT
