Author Topic: V9 roamer final drive leak UPDATE  (Read 6494 times)
Offline Scott DeRoss
« on: August 25, 2017, 10:11:56 PM »
Well this bike is becoming increasingly irritating. Back to the dealer once again today. Put some miles on it since I got it back. Not many at all Just a few hundred plus. Came out the other day and noticed the rear wheel full of oil.
There also was a palm full puddle at the rear tire. I thought maybe it was overfilled and would settle down.
Wiped wheel and tire off of the oil and went for a ride. Nope, about 60 miles later oil on the wheel again.
So, back to the dealer again. probably a seal went bad.
SUCKS!
Any one else have an issue like this?
Brought the bike in for the leak they had it two weeks got it back and still leaked. Took pics and sent them to the dealer they said the sent them to corporate, brought back in, in early September stressed my dissatisfaction. Didn't hear anything at all after a month and one half. E-mailed them on status said they are still waiting for a NEW final drive to arrive from Italy. Boy this has been crazy since I bought the bike in late May!
« Last Edit: October 22, 2017, 05:18:18 PM by Scott DeRoss »
2007 Vintage (Vinnie)
2017 V9 Roamer (Sunny)
1-76 & 3-78 Robins
1975 Honda CT90
1979 Beneli G2 moped
75 850t wifes (Plum Crazy)
79 Honda Ct70 (restored)
MGNOC L-661
Never take life so serious you won't get out of it alive
Offline Hittman
Re: V9 roamer final drive leak
« Reply #1 on: August 25, 2017, 10:16:06 PM »
Unfortunately there was a machining issue with the earlier rear diffs that cause leaks. They should just replace your diff with the update part and it will solve the issue.
« Reply #2 on: August 25, 2017, 10:19:18 PM »
Ok, that would be great. This was sold as a 2017 but on the steering neck say's 03/16
1-76 & 3-78 Robins
1975 Honda CT90
MGNOC L-661
Offline Hittman
« Reply #3 on: August 26, 2017, 12:10:29 AM »
There is a serial # stamped into the rear diff. If I think about I'll find the cutoff # tomorrow for you.
Re: V9 roamer final drive leak UPDATE
« Reply #4 on: October 22, 2017, 05:20:22 PM »
Bumped for the update
1-76 & 3-78 Robins
1975 Honda CT90
MGNOC L-661
bpreynolds
« Reply #5 on: October 23, 2017, 06:11:14 AM »
My rear breather sprayed oil on the back wheel until I did the first service myself.  Once I put the correct level of oil in there it hasn’t repeated this since then.  I dunno if this will help you or not but I offer it up.
Offline Kev m
« Reply #6 on: October 23, 2017, 06:27:28 AM »
So the update is it's a known problem, and you still don't have your bike?!?  :thewife:
« Reply #7 on: October 23, 2017, 07:52:36 PM »
Kevin, yes, it is a known problem on some of the earlier ones. So, at this time I am waiting for the dealer to receive the new final drive and for them to install it. So far since I dropped it off one and one half months.  :angry:
1-76 & 3-78 Robins
1975 Honda CT90
MGNOC L-661
« Reply #8 on: October 23, 2017, 07:59:56 PM »
My rear breather sprayed oil on the back wheel until I did the first service myself.  Once I put the correct level of oil in there it hasn�t repeated this since then.  I dunno if this will help you or not but I offer it up.
Thanks for the offer but this was definitely not the issue. I will keep your breather problem in mind though. Thanks
1-76 & 3-78 Robins
1975 Honda CT90
MGNOC L-661
Offline Kev m
« Reply #9 on: October 23, 2017, 09:00:22 PM »
I am really sorry to hear this. Crap if you were local I'd literally loan you mine!
Hang in there, I suspect it's a really nice bike and will be a pleasure once sorted.
But you shouldn't have to endure this!!!
Offline JeffOlson
« Reply #10 on: October 23, 2017, 11:21:08 PM »
The dealership should at least give you a loaner bike (along with free coffee and donuts).
A motorcycle dealership may not have the same cash flow as a car dealership, but they should still strive for good customer service.
When my car developed engine troubles very early on, the dealership could not diagnose the problem without the involvement of factory engineers located a world away. While my car sat in the shop for two months, the dealership provided me with a very nice loaner car, offered to unwind the deal, and even made my car payments for me.
Here’s a thought: Moto Guzzi should provide all dealers with at least one leftover V7 to be used as a loaner...
« Last Edit: October 23, 2017, 11:27:08 PM by JeffOlson »
2018 Vespa GTS 300
2016 Moto Guzzi Norge
2015 Vespa Sprint 150
2015 Vespa GTS 300
« Reply #11 on: October 23, 2017, 11:25:00 PM »
One of the last tech bulletins I Recieved when I was still a service agent concerned the new availability of special tools to disassemble both the Cali 14 and V9 bevelboxes. Why don't they just buy the tools and repair it?
Kev, V9's use a completely new driveshaft, swingarm and FD. Yours wouldn't fit.
Offline Kev m
« Reply #12 on: October 24, 2017, 06:00:12 AM »
No I was saying if he was local he could just ride my V7 for a while.
« Reply #13 on: October 24, 2017, 09:42:47 AM »
Ah, gotcha. :thumb:
Offline astricklin123
« Reply #14 on: October 24, 2017, 11:07:43 AM »
They are not going to repair it using a non-factory recommended method because this is a warranty issue and they want the manufacturer to pay for the repair. Also, reporting it to the manufacturer could help others as they may release a TSB or even have a recall to fix all bikes with the same parts.
Offline Darren Williams
  • Finally got me a Griso!
« Reply #15 on: October 24, 2017, 12:08:32 PM »
Too bad MG wouldn't let them just swap a swing arm and bevel box off another bike and fix that one when the parts come in. Of course they could even put grease on the bone dry swing arm bearings while they were changing them out!   :evil:
Offline jpv7
« Reply #16 on: October 24, 2017, 12:44:28 PM »
Here�s a thought: Moto Guzzi should provide all dealers with at least one leftover V7 to be used as a loaner...
Ask the dealer to give you the Guzzi demo V9 or even V7. That might be possible depending on where you are located.  Dealers may be sharing one...That's what the dealer here in Toronto did for a guy whose clutch went out and parts were backordered...seems fair.
