Author Topic: California II tank Overflow  (Read 1414 times)
« on: September 01, 2017, 10:18:28 PM »
The tank on a California II has a spout that goes down into the tank about 2 inches.
If you overfill the tank to a point where this spout is dipped in fuel and leave the bike in the sun the air inside warms up forcing the fuel up the spout and out the filler all over the engine.
Easy solution
Drill a tiny hole through the side of the spout up near the top, this lets the air pressure dissipate and also lets you cram about another half a gallon into the tank.
Center punch first or the drill will wander off, I used a hand drill for safety.
« Last Edit: September 01, 2017, 10:26:02 PM by Kiwi_Roy »
Online rodekyll
Re: California II tank Overflow
« Reply #1 on: September 02, 2017, 12:33:13 AM »
Good tip!
The rt side is my choice for the hole.  Helps me fill it on the sidestand without "burping".
Offline KiwiKev
« Reply #2 on: September 02, 2017, 04:20:19 PM »
Sounds like an easy fix Roy, not sure if my bike has this but I'll check when I get out of bed.
Father's Day Sunday here and my boy Mark promised to make breakfast.
