There's another adjustment point on the back of the transmission and a 3rd on the cable near your right foot.
You could try flushing the bell housing w/mineral spirits. Just plug the slot on bottom, use a funnel and fill through the inspection hole on R/H side. I used a wood wedge in the slot or an old piece of innertube. I made lot of extra money changing clutch hubs in the 80's, cause most every one was bad. Not the new parts so much till new hub came out on 93 models.
How many miles on this machine? The Guzzi double plate clutch is usually robust until nearing 100K miles.Before you do all this big disassembly, make two inspections.1-lay under the bike or place a mirror or use a friend. Look at the action lever at the back of the transmission. When you pull on the hand lever, does the transmission lever come in and abut any part of the transmission rear cover casting? If so, adjust the pin in the center of the transmission lever to create some free space at full pull.2-again under the bike. Look at the relationship between the outer body of the throwout system and the rear cover casting around it. At rest, the outer body should be just about flush. If the outer body is substantially recessed into the casting it usually indicates some significant wear to throwout parts, usually the throwout radial bearing and race washers. You should consider pulling and replacing the throwout bearing and race washers. Easy to do with the swingarm off. If the outer body is substantially exposed or proud of the surrounding casting it indicates wear to the clutch friction components themselves and then a full removal is in order. Here is a pic of a recessed outer body. Its a smallblock, but the parts and the visuals are pretty much the same.Patrick HayesFremont CA
Let me ask. Have you been adjusting the clutch lever and cable so that it is taught? Sure way to quickly disintegrate the throwout bearing. That bearing is only intended for intermittent or momentary use and can't handle full-time load rotation. Always adjust the clutch so that there is some freeplay in the system at rest to ensure that the bearing gets fully unloaded.Patrick HayesFremont CA
Sounds like a notchy input boss to me. Regardless of the mileage it's a 35 year old motorbike with an unknown service history, chances are it's been running in a shocking state of tune for a while at least. When were the carburettors last balanced accurately and what speed does it usually idle at? I'll bet London to a brick that the clutch hub and probably the flywheel are shot to shit.Pete
Bike starts right up and idles quite nice (around 900). Hiccups a bit at low rpms but pulls like a mule above 5,000. Had big bore kit done with cams and custom pipes done years ago. It certainly needs some fine tuning but plugs are clean and it seems real happy pushing it in it's happy zone of 5000-7500 rpm.
The shallow splines weren't the problem, at least not all of it. Guzzi went through a period in the '80s where the hub wasn't heat-treated properly. Must have been done at the local pizzeria...
I am pretty mechanically Any thoughts?
The bike is red but it had been sitting for years prior to my recent purchase of it. I will take yours and Steve's advise and try kerosene and prying method before resorting to more drastic measures. Thanks again!
My 84 LM3 got real bad at 15K mi, notched hub looked just like the pics from SED. My 86 Cal2 started at 25K mi, I swapped it at 37K. Had a sidecar so I could keep the brakes on better so I didn't launch.
I'll take back my response on the kerosene. That could be too slippery for the clutch. I'd try to pry apart first and see if that works. Possibility that you might have to drill a drain hole into your trans. case. Trying the prying first. Go easy you don't want to tear things up.
