Author Topic: removing water spots from windshield  (Read 3039 times)
Offline nc43bsa
« on: September 10, 2017, 10:42:38 PM »
I searched but couldn't find anything, so . . .
Does anyone know a method of removing water spots from a car windshield? It's not real bad, but when it's raining lightly, especially at night, the spot pattern appears every time the wiper blade passes. New blades don't help.
The driver's side outside mirror is also spotted very badly.
1990 MilleGT
Offline ITSec
Re: removing water spots from windshield
« Reply #1 on: September 10, 2017, 10:47:22 PM »
Soak the windshield with water mixed with a water softening agent (avoid getting it on the paint). After it's been on for a bit, scrub it a bit then rinse liberally with plain water and then dry it with a soft towel.
Water spots are almost always caused by dissolved minerals or stuff in the atmosphere drying on the glass. The wetting agent in the water softener will help re-dissolve that crud and keep it suspended until you rinse and dry.
ITSecurity
2013 Stelvio NTX - Copper
2008 Norge GT - Silver
I am but mad north-northwest!
Offline dsrdave
« Reply #2 on: September 11, 2017, 07:11:08 AM »
GlassWork  water spot remover by Pinnacle.  Works great!
I get it from autogeek but I'm sure there are other places.
Offline Mike Craven
« Reply #3 on: September 11, 2017, 07:49:43 AM »
I use "Bon ami" because it's softer than glass and takes off all kinds of shadows on glass.  Then you have to do-over the Rain-x.  (It's also what you could cut the kids loose with for bathroom cleaning and not scratch up porcelain, chrome, tile.)
Mike
Mike  L-715, Atlanta GA
1983 Cali II
Offline old as dirt 2
« Reply #4 on: September 11, 2017, 07:53:47 AM »
Bar keepers Friend .
this stuff works excellent in removing stuff from glass
2013 Norge
2008 MP3 500
bunch of other stuff that is long gone.
« Reply #5 on: September 11, 2017, 08:43:02 AM »
 Wash it wit dehydrated water.
« Reply #6 on: September 11, 2017, 11:07:52 AM »
Dehydrated water ????
Would distilled water do OK ?
« Last Edit: September 11, 2017, 11:08:39 AM by Huzo »
« Reply #7 on: September 11, 2017, 11:53:29 AM »
I was whining about the spots left on my bike windscreen after a diesel truck "rolled coal" on me.  My sister suggested toothpaste.  I couldn't see that helping, but the screen was ruined otherwise, and she had the travel size tube of Colgate right there.  I put it on dry, buffed a bit, added some water, buffed more, let it dry to a film, and wiped it off.  hmmmm.  It cleared up.  Smelt minty, too.  Go figure.
Offline stonelover
« Reply #8 on: September 11, 2017, 12:23:29 PM »
A dab of Simichrome metal polish on a finger tip has worked well for me.  Great for buffing out scratches too.
Offline roadscum
« Reply #9 on: September 11, 2017, 01:07:22 PM »
Mixture of vinegar and water should do the trick. It works for me to remove the residue on the paint and windshield fron the recycled water of our irrigation system.
Paul
"The only true wisdom is in knowing you know nothing " - Socrates
Paul M. in SW Florida: 318 miles, 11 curves and not a Guzzi dealer in sight!
Offline Chesterfield
« Reply #10 on: September 11, 2017, 06:47:03 PM »
Paul
Those water spots can be tenacious, Bon Ami or Barkeepers friend will not touch the spots that have been cooked on by the sun. I use the cleaner used for Ceramic stove tops. It you have a buffer it will polish up the glass quite well also. They are all a Cerium Oxide derivative like this.
https://www.amazon.com/gp/product/B006LO118O/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
« Last Edit: September 11, 2017, 06:53:08 PM by Chesterfield »
Offline rss29
« Reply #11 on: September 11, 2017, 09:24:30 PM »
Glass polish. I use the stuff from Griots Garage with a random orbit buffer, but you can do by hand as well. Works really well.
« Last Edit: September 11, 2017, 09:24:57 PM by rss29 »
Offline Ncdan
« Reply #12 on: September 11, 2017, 10:18:01 PM »
Wax it when you wax your bike. Cleans and repels water when you get cayin a rain storm. I've been doing it for 40+ years on all windshields, never owned a bike without one
Offline dguzzi
« Reply #13 on: September 12, 2017, 10:11:39 AM »
Still cracking up on the dehydrated water idea....
  I was going to say vinegar as well...
« Last Edit: September 12, 2017, 10:12:40 AM by dguzzi »
'03 EVT
'87 Cagiva
'72 Commando
'71 Commando
'13 F150
'16 Mustang
Offline Zoom Zoom
« Reply #14 on: September 12, 2017, 11:21:55 AM »
And to rehydrate the water, just add water. Brings it right back to its original self.😁
ZZ
Offline screamday
« Reply #15 on: September 12, 2017, 12:05:02 PM »
Paul
^^^ This.....and use old newspapers to wipe down with instead of paper towels. The newspaper will reduce streaking, if not eliminate it altogether.
Tony in SC
"Comfort the disturbed and Disturb the comfortable"
1988 R100RS
1998 V11 EV
Offline roadscum
« Reply #16 on: September 12, 2017, 02:46:37 PM »
Saturate a towel or paper towel with the vinegar/water mixture, lay it on the stains. Now go enjoy a cold beer, two if you'd like. Return to the stains and wipe with the towel, that should do the trick.
If the stains persist, have more beer! :boozing:
Paul
