Author Topic: Convert fuel tank seams.  (Read 1334 times)
Offline gearman
« on: September 21, 2017, 09:08:18 AM »
Has any one sanded  the tank to bare metal? Is there a filled seam on top? Thanks
Offline Groover
    • Scooteropolis
Re: Convert fuel tank seams.
« Reply #1 on: September 22, 2017, 07:33:54 AM »
Good question, but I think the tank may be stamp by top piece and a bottom piece, then welded at the bottom seams all around the tube frame tunnel. It does seem like big stretch though, so not 100% sure.
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Offline LeRoy
« Reply #2 on: September 22, 2017, 07:39:08 AM »
 Yes, there is a seam on top that runs front-to-back. The tank may be made in three pieces; left, right and bottom. My tank had filler covering the top seam. The seam itself was not terribly well done but that's what the filter is all about. It was clearly original.
EDIT: The picture Groover shows should make it clear that at least three pieces are needed to produce a Convert or any similar tank. The bottom view shows that the tank's side walls wrap around where they meet he bottom panel. There's no way a single top piece could be stamped in this form; there's no way to wrap it around the male portion of a die or to remove it from the tooling if it were formed in that way. As I noted, it seems that there is a left piece, a right piece and a bottom panel.
« Last Edit: September 22, 2017, 07:01:33 PM by LeRoy »
LeRoy (Bob Sharp)
Rochester, MI  U.S.A.
'83 1000SP (as of Oct. 15)
Offline gearman
« Reply #3 on: September 23, 2017, 10:33:02 AM »
Great answer. It makes sense.
