Author Topic: Anni Arrives Today! Experienced Shippers, What should I Check Before Accepting?  (Read 2624 times)
Offline Guzzi Gal
    • Sonoran Sunriders, YouTube
My Anniversario is arriving in about 30 minutes (I got the call when typing this)!  Other than cosmetic stuff, and will she start, what should I absolutely check before accepting delivery?
« Last Edit: September 22, 2017, 11:20:32 AM by Guzzi Gal »
"Velvet" '16 Honda CTX 700,
"Miri" and Mori"
Offline TimmyTheHog
Can't comment on electrical & engine components...
BUT CHECK and ENSURE CLUTCH IS PROPERLY ADJUSTED!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Currently Bikeless...*cry*
Offline Guzzi Gal
I'll give her quick trip up the street, and check out the clutch feel.
"Miri" and Mori"
Offline TimmyTheHog
Before you even do that, take a look at the freeplay gap @ the lever, and check the gear arm orientation by the gear box...
UNLESS they change the clearance for the Anniversary, the gap of free play @ the lever is 2~3mm
The clutch cable should be relatively 90 degree to the arm when the clutch lever is NOT PULLED. My is a V7 so arm is hidden under the bike.
Your arm should be accessible from the right side of the bike.
« Last Edit: September 22, 2017, 11:49:24 AM by TimmyTheHog »
It all depends on what you paid for, if a dealer then check dealer prep, the driver has no interest in making the bike right only to deliver it undamaged.
Check the L/H handlebar adjuster for clutch, they come loose from factory.
« Last Edit: September 22, 2017, 11:48:04 AM by guzzisteve »
Offline TimmyTheHog
this is true...
but sometimes it is better pay attention to spots that MAY be wrong so can catch in time NOT be wrong...
also might give you the sense of how good the dealer actually is
Offline Socalrob
Good luck, sure it will be great.  I swore you took delivery of this bike like two husband bikes and a year ago.  The anticipation must have killed you.
Please be sure to post up your impressions tonight.  I love my Anniversario.
Offline Guzzi Gal
Bought her on Aug. 22nd, and got her Sept. 22nd..  All in all, not bad.  Heading to the MVD in a few, to make her official.  Gotta have those vanity plates!   :wink:
"Miri" and Mori"
