Author Topic: 850 T  (Read 3339 times)
Offline commander
850 T
« on: October 10, 2017, 08:17:13 AM »
Help, I have a 1975 850 T, the previous owner put the turn indicators taped on top of the gauges, i don't see a factory location ?
Is there one ? thanks.
« Last Edit: October 10, 2017, 04:26:22 PM by oldbike54 »
Online Turin
Re: 850 T
« Reply #1 on: October 10, 2017, 12:35:18 PM »
headlight brackets/ headlight bucket/
These are not mine
« Last Edit: October 10, 2017, 06:41:57 PM by Turin »
1986 Sidlow Guzzi
1996 Triumph Daytona 900
Offline commander
Re: 850 T
« Reply #2 on: October 10, 2017, 12:53:23 PM »
Sorry i mean on the dash or gauge area the little green lights
Offline Sportsterleroy
    • 1976 Moto GuzziT3 rebirth of da turd
Re: 850 T
« Reply #3 on: October 10, 2017, 01:26:52 PM »
The T-3 bezel has NO turn indicators panels built in for seeing which is flashing or still on.  A dash console for V35, V50, V50 II, 850 T3 California, 850T4.  would have them and should fit std t-3 location
Leroy in Cleveland
« Last Edit: October 10, 2017, 01:31:16 PM by Sportsterleroy »
Leroy
Cleveland Ohio
1977 Moto Guzzi Convert
1976 Moto Guzzi 850 T3
2006 Harley Road glide
1996 Harley Sportster 1200
http://977motoguzziconvertproject.shutterfly.com/
http://1976motoguzzit3rebirthofdaturd.shutterfly.com/
Offline Idontwantapickle
Re: 850 T
« Reply #4 on: October 10, 2017, 02:19:49 PM »
You should be able to see the front signals flashing, no dash indicator needed.
Sir James Paul McCartney
AMA Charter Life Member
72 Eldo
84 BMW R100RS
Re: 850 T
« Reply #5 on: October 10, 2017, 02:24:47 PM »
Nice T there, Turin.. :thumb:
Moto
Re: 850 T
« Reply #6 on: October 10, 2017, 02:25:58 PM »
Neither the 850-T nor the early 850-T3 dashes had turn signal indicators. Later T3 and others did.
Moto
Re: 850 T
« Reply #7 on: October 10, 2017, 03:25:15 PM »
I completely miss the fact that my indicator has been flashing away for miles, and I know I'm not the only guilty one.
Another option is one of the small Piezo buzzers connected with a pair of diodes
     Diodes
|----|<----- From Left side
|----|<----- From Right side
|     Buzzer
|-----(+ - )---- To Chassis
Sooner or later you wonder what's that annoying noise
https://www.digikey.ca/product-detail/en/CEP-2260A/102-1120-ND/412379?WT.mc_id=IQ_7604_G_pla412379&wt.srch=1&wt.medium=cpc&WT.srch=1&mkwid=sEIT2P6VX&pcrid=102742808345&pkw=&pmt=&pdv=c&gclid=CjwKCAjw3_HOBRBaEiwAvLBboqMH-JGK-hoL-j3N0SCx-d6SLWdsECk1kGB8D2_NTlRLb5CRXEDscxoCJyoQAvD_BwE
I need to mount a pair of those in my helmet
« Last Edit: October 10, 2017, 03:27:58 PM by Kiwi_Roy »
Offline commander
Re: 850 T
« Reply #8 on: October 10, 2017, 04:20:12 PM »
ok thanks guys
Offline Matt Story
  • Flint, MI
Re: 850 T
« Reply #9 on: October 10, 2017, 04:42:42 PM »
I have a more sophisticated device but similar to this
https://kisantech.com/mag/signalminder/10apf.html
from Kisan on my R1150RT.  I am very happy with it, and am considering this 10apf on my pre computer bikes.
'75 850T - First & only owner
'77 Honda CB750 Supersport
'02 BMW R1150RT
Flint, MI
Online Turin
Re: 850 T
« Reply #10 on: October 10, 2017, 06:43:48 PM »
Sorry, neither of those are mine.
1986 Sidlow Guzzi
Offline Gliderjohn
Re: 850 T
« Reply #11 on: October 10, 2017, 07:35:21 PM »
I have a March 1975 T-3 LAPD which I would think is an early T-3 and it has indicators (maybe because of having the big one piece police dash?) problem is you can only see the indicators in the dark, kind of redundant then. :roll eyes:
East Mountains, NM
Re: 850 T
« Reply #12 on: October 10, 2017, 08:20:19 PM »
  change the std bulbs for LED bulbs at www.superbrightleds .com Bright 24/7 when on the bike. . Match color of lens when purchase them and didnt put one in charge light if I remember correctly
Leroy in Cleveland
Leroy
Cleveland Ohio
Online wirespokes
Re: 850 T
« Reply #13 on: October 10, 2017, 10:45:15 PM »
You'd think with the signals right in front of you, it'd be obvious they're flashing. But, in fact, that's not the case most times during the day.
Here's how I handled it on my 77T3. There is an almost useless Low Fluid indicator for the rear master cylinder in the dash.
The lead to that bulb comes from the lid of the master cylinder behind the right sidecover. A few inches away is the flasher unit. I just added a lead from the output of the flasher to the Low Fluid lead at the master cylinder.
It works perfectly telling me when the flashers are on. If the brake fluid goes low, then the light will come on solid and I'll know that's what it is, because it's not flashing.
Re: 850 T
« Reply #14 on: October 11, 2017, 12:22:39 AM »
Thinking outside the box - brilliant
Leroy in Cleveland
You can add an LED for the charge light just add a resistor in parallel something like a 47 Ohm 1 Watt should do it.
Actually I think anything between 22 and 100 Ohms should do.
« Last Edit: October 11, 2017, 12:28:35 AM by Kiwi_Roy »
Moto
Re: 850 T
« Reply #15 on: October 11, 2017, 12:41:32 AM »
My civilian T3 had the usual, smaller dash, without turn signal indicators. My original T3 owners manual has a photo of just that dash. I replaced it with a newer version that has indicators but is otherwise virtually identical. I think it was NOS from a Monza, but was told at Motorcycle International that it was also fitted to T3's, later ones, I presume.
Re: 850 T
« Reply #16 on: September 22, 2025, 08:32:38 AM »
How about using a 194 LED wired between the two sides.
These lamps are non Polarized and pretty bright
The current will run from the active side through the LED and be grounded through the non active side
The LED would draw about 10 milliamps, not enough to power the non active incandescent lamps.
https://www.superbrightleds.com/194-led-bulb-1-led-miniature-wedge-base?queryID=6cb05c7305d99f853289707aac398a1f
