Author Topic: Knight Design Extended Pegs  (Read 1653 times)
« on: October 15, 2017, 05:26:35 AM »
I ordered a pair of black 1-3/8" extended pegs for my Griso, they seem well made.
What a difference 1-3/8 makes
If you order the extended toe pegs you need 2, they don't come as a pair.
You definitely need one for the brake but might be able to adjust the gear pedal down.
http://www.knightdesignllc.com
Don't just click on the pictures or you may miss the black ones.
« Last Edit: October 15, 2017, 05:37:48 AM by Kiwi_Roy »
Offline timax
Re: Knight Design Extended Pegs
« Reply #1 on: October 15, 2017, 06:02:21 AM »
I have them also for my V7. I think mine are 50mm and as you say make a huge difference. Well made and look good also. Havnt scraped them yet and the way i ride probably wont.
I adjusted the gear lever down easily but needed some washes to for the brake return stop to bulk it out after extending the pedal down. So several washers on a 6mm bolt instead of the standard stop.
Only a lame , underpowered piece of shit V7ll with a fake scrambler makeover  not really worthy of a Guzzi badge but its mine and i love it!
« Reply #2 on: October 15, 2017, 06:45:41 AM »
Got a set on my Triumph, nicely made, I can stand up on them with no security concerns.
Been bugging them for a couple years to make the same set for the passenger, but not enough demand yet apparently .....
Offline Dilliw
« Reply #3 on: October 15, 2017, 07:47:14 AM »
Yep the gear is fine.  Brakee is a must though
George Westbury
Austin, TX
