Author Topic: Arcane small part for Stelvio NTX  (Read 3649 times)
Offline ITSec
« on: October 16, 2017, 02:57:08 PM »
I'm having trouble identifying a part using the Stelvio NTX parts manual (both my downloaded one and the one at AF1). On each side of the fairing there area wind deflectors; their lower mounting screws are threaded into a funny little rubber plug that has a threaded metal insert in it. The diagram in the parts manual doesn't clearly depict these things, the screws are #26 on the second page of "Front body - front fairing", but the descriptions for anything near the lower screws is either lost in translation or doesn't describe the thing I'm looking for.
Anybody know what I'm talking about, and which part it really is? There's one on my bike that has the embedded insert tearing away from the rubber portion. Thanks!
ITSecurity
2013 Stelvio NTX - Copper
2008 Norge GT - Silver
I am but mad north-northwest!
Offline little750
Re: Arcane small part for Stelvio NTX
« Reply #1 on: October 16, 2017, 03:40:52 PM »
Well nuts are what you need I think just google them.
Offline ITSec
« Reply #2 on: October 16, 2017, 05:15:11 PM »
No, nuts won't work. The thing I'm looking for acts as an expanding plug in the bodywork; it's a rubber plug with a metal threaded insert molded into it, and when you tighten the machine screw into it, the plug tightens in the hole in the body plastic.
ITSecurity
Online bmc5733946
« Reply #3 on: October 16, 2017, 05:37:59 PM »
Google the term "well nut" you will find them.
Brian
1989 MILLE GT
2006 BREVA 750
2004 BREVA 750
1975 CONVERT
Offline Markcarovilli
« Reply #4 on: October 16, 2017, 05:40:43 PM »
Well nuts :violent1:
Offline BMWDavid
2002 Moto Guzzi V11 LeMans
2003 Moto Guzzi V11 LeMans
2005 Honda XR650L
2007 Buell XB12Ss
2014 Yamaha FJR 1300es
Southwest Indiana
« Reply #6 on: October 16, 2017, 06:26:51 PM »
I don't think they expand, but they do spin if messed up. Another member here drilled tiny holes on rubber next to brass insert and inserted super glue. It worked.
Offline pyoungbl
« Reply #7 on: October 16, 2017, 06:58:19 PM »
Yep, well nuts.  Be darn careful with those little suckers.  If you put too much torque on the screw it will cause the well nut to spin in the plastic tank.  That's a big deal because you cannot take the tank off until you take off the fairing bits which are secured by the darn screws that are now spinning uselessly.  In many cases that means you need a new tank.  Yep, I know from bitter experience.  I strongly recommend coating the screw threads with anti seize and then only tightening finger tight.  I'd also urge you to throw the darn plastic wings in the trash because the studs used seem to encourage excess torque leading to the well nuts spinning.
« Last Edit: October 16, 2017, 06:58:58 PM by pyoungbl »
'13 V7 Special (red/white)
Bonaventure
« Reply #8 on: October 16, 2017, 07:48:49 PM »
Oh snap.  One of my deflectors seemed more chattery and loose at the bottom than the other and I tried to snug up the screw but it seemed to just continue turning with the same resistance and not snugging.  Perhaps the rubber thing-a-ma-jig is spinning.  Crap.
« Last Edit: October 16, 2017, 07:49:56 PM by Bonaventure »
Offline ITSec
« Reply #9 on: October 16, 2017, 08:51:29 PM »
OK, I need well nuts. That still doesn't tell me which part number these are from the parts catalog, or where they are on the durn diagram!  :grin:
There sure aren't any pieces labelled as well nuts...
ITSecurity
Online RinkRat II
  • Lake Powell AZ
« Reply #10 on: October 16, 2017, 09:01:41 PM »
 You can buy them at most Ace or True Value Hardware stores
     Paul B :boozing:
Offline pyoungbl
« Reply #11 on: October 16, 2017, 09:40:20 PM »
The well nuts are part of the gas tank, not a part that you can order from Guzzi.  Guzzi buys the gas tank complete from a subcontractor with the well nuts already installed.
Offline ITSec
« Reply #12 on: October 17, 2017, 02:07:44 AM »
Now that explains why I can't find them on the parts diagram - and now I know what I need to do to replace them! Since I have one good one I can measure it, get the specs and find an alternative. It would have been simpler if they could be ordered off the sheet (since I'm ordering some other stuff anyway) which is why I asked.
ITSecurity
Offline ITSec
« Reply #13 on: October 17, 2017, 02:09:10 AM »
     Paul B :boozing:
In metric? I'd be surprised...
Then again, Ace has sometimes had some odd stuff.
ITSecurity
« Reply #14 on: October 17, 2017, 02:24:11 AM »
GU93231605.
Comes up as 'Fairing nut. Centauro.
€0.89 from Teo. $2.44 from AF1
Buy one and go to your local nut and bolt place.
You're welcome! :grin:
Offline ITSec
« Reply #15 on: October 17, 2017, 11:08:47 AM »
GU93231605.
�0.89 from Teo. $2.44 from AF1
Thanks, Pete! Just what I wanted - I figured they had to have had a part number at some point even if they were now part of the assembly.
ITSecurity
Offline lti_57
  • Directly above the center of the Earth
« Reply #16 on: October 18, 2017, 02:21:28 PM »
My ACE store here has them I but them all the time for my Vinten Tripods and of course my Quota
2007 Guzzi Griso
1992 BMW K75
Bonaventure
« Reply #17 on: October 19, 2017, 05:35:47 AM »
Can you remove the deflectors altogether or will that cause something to fall off inside the tank?  May be a stupid question ...  :embarrassed:
Wondering if the deflectors create more turbulence than they help with?
« Reply #18 on: October 19, 2017, 05:45:07 AM »
The ones on the 'Turdio' were long gone before I bought it. Whether or not they are anything more or less than a cosmetic affectation I have no idea but I haven't died horribly due to their absence!
Offline ChuckH
« Reply #19 on: October 19, 2017, 07:28:04 AM »
Can you remove the deflectors altogether or will that cause something to fall off inside the tank?  May be a stupid question ...Wondering if the deflectors create more turbulence than they help with?
I never did install the deflectors on my '12 Stelvio.  My dealer -- Rose Farms -- did not install them during the setup process and I just left them in the plastic bag.  The threaded inserts are part of the tank, nothing will be hurt if you take the deflectors off.
