Thanks Chuck. I like your high tech tester. Much more sensible than mine. The thread on the valve body is an oddball: metric, and by memory measures 12.75 OD. Nothing I could find on a "standard" metric table of threads". To make my "manifold", I step drilled a brass fitting and overdrove a 1/4 pipe tap, which is nominally smaller in diameter, but uses almost the same thread form as the valve body. Managed to get two threads out of the deal before I ran out of tap length. Held 60 psi no problem........Ever find yourself in the middle of a dumbass solution you have devised but there is no going back?Stephen Hill
I was a mold maker in another lifetime
Well that explains a lot - is it still only treatable, or did all my donation to research ever lead to a cure ?
Antieham writes: M14 - 1.5 threads. Nothing "oddball" about that.I measured the OD on the valve body thread for my 1976 LeMans. Definitely nowhere near 14 mm. Closer to 12.75. I couldn't find that in any metric table I looked at.Stephen Hill
Uhh, how did you measure that? Calipers? (pretty close) Micrometers? (right on the money) Scale? (open to interpretation.) Charlie's seldom wrong..
