Author Topic: Suggestions please: best replacement battery for 2007 Norge  (Read 9309 times)
Offline blackbuell
« on: November 01, 2017, 02:26:26 PM »
I might be buying a 2007 Norge; plan to replace the battery if I do. Got any good recommendations? Also....does anybody still market the startus interruptus harnesses? Anybody got a spare that they want to sell?
Thanks,
Jon
Offline Huzo
Re: Suggestions please: best replacement battery for 2007 Norge
« Reply #1 on: November 01, 2017, 02:38:54 PM »
Jeez mate.
Recently in Norway on mine and I just strolled into a place and asked for the biggest battery that would fit in. I got an Exide 20 A/hr from memory but bike is away on the water so can't check for you.
Whatever you get though, pay heed to Roper's words on allowing the battery to sit overnight before subjecting to charge of any sort. That allows the acid to soak fully into the 'glass mat.
No need to buggerise around with a harness.
Just rip the yellow wire from the relay and insert a FUSED wire from the battery into the recently vacated hole.
Done!
« Last Edit: November 01, 2017, 02:41:09 PM by Huzo »
« Reply #2 on: November 01, 2017, 02:44:44 PM »
Lots of battery options available but I wouldn't consider anything but a well proven AGM
The Startus Interuptus fix is still available or you can do your own quite easily.
Huzo beat me too it, Yes Pete advised me against buying anything less than 20 AH for our cold climate.
You could google Yuasa and see what they have for a Norge, that's what I did but I ended up with the Canadian Tire equivalent :thumb:
YTX20CH-BS was what they recommend, the Canadian Tire battery had the same part No so I guess it was a re-branded Yuasa.
You will need to pull the rear end off and fill the bearings with grease, I can offer you my $10 shop stand design for doing that.
« Last Edit: November 02, 2017, 04:54:51 PM by Kiwi_Roy »
« Reply #3 on: November 01, 2017, 03:30:32 PM »
Look into MotoBat brand have installed in Norge & Stelvio.
Offline blackbuell
« Reply #4 on: November 01, 2017, 03:57:50 PM »
Steve,
MotoBatt lists one battery (MBTX16U) for 2009-2016 Norge. Is there any reason why it wouldn't work for a 2007 model?
Thanks,
Jon
Offline PJPR01
« Reply #5 on: November 01, 2017, 04:19:57 PM »
I've got a spare unused MPH Startus Interruptus if you need one.
Battery...I just bought an AGM for mine as a backup for the Shorai Lithium one (obviously much lighter in weight though), mine is a 2008.  I would think it's the exact same battery, you can find one at your local Autozone/O'Reilly's will have it.
Cheers...
Paul R
2015 Red/Black Griso
2008 Silver Norge
2002 V11 Scura
Offline old as dirt 2
« Reply #6 on: November 01, 2017, 04:29:32 PM »
I use Motobatt, always
2013 Norge
2008 MP3 500
bunch of other stuff that is long gone.
« Reply #7 on: November 01, 2017, 08:13:14 PM »
I have an Odyssey 680 in my Norge
« Reply #8 on: November 01, 2017, 09:07:05 PM »
Hi, Jon
Met you a few years back at the NE Ohio Guzzi breakfast in Kent. Glad to see you're back among the fold with your purchase of a Norge.  I don't recall ...... did you sell your original Norge?
Re battery, I've had fairly good luck with the battery that came with my 1200 Sport, which was manufactured by Yuasa.
I think I have info on that battery if you want it.
Glad to see you back with us.
Bob
« Reply #9 on: November 01, 2017, 10:12:27 PM »
Steve,
Thanks,
Jon
All the same batt
Offline jdgretz
  • Proud Owner of a Red Norge
« Reply #10 on: November 02, 2017, 04:21:45 AM »
Steve,
Thanks,
Jon
Yes, that's what I have been running in mine for a number of years now.  I especially like the second set of terminals.  Makes adding direct connections very easy.
jdg
1999 Honda Helix - Zippy
2008 Honda Goldwing
Offline blackbuell
« Reply #11 on: November 02, 2017, 06:18:13 AM »
Thanks all for info.
Bob,
I certainly remember you. BTW, my youngest daughter lives up your way in Aurora. Last May I decided to hang on to my 2009 Norge until I put over 100,000 miles on the ODO; a few weeks later my wife and I were riding home at night on I-75 from the dirt track race in Lexington, and a deer decided to run in front of us; totaled the bike and damn near totaled us, did total the doe. IMO, 2-valve Norges are great road bikes; I just closed a deal to buy a 2007 and am anxious to make everything on it just right (it does suffer from startus interruptus).
I'll check out the Yuasa along with the other ones recommended here.
Jon
« Reply #12 on: November 02, 2017, 11:01:21 AM »
Bob,
Jon
I don't know how I forgot about your get-off with the deer.  I remember your post when it happened.  It appears you're in fine shape after such a mishap.  Hope that holds true for your wife, too.
Never ridden a Norge, but my 1200 Sport uses a lot of the same components, and has been a great machine, admittedly with 35,000 miles less than your 09 had when it 'departed' this world.
Bob
Offline Diploman
« Reply #13 on: November 02, 2017, 04:07:12 PM »
My V50 II is fitted with an 8-cell Anti-Gravity Lithium battery.  Performance has been outstanding since I put her on the road last July.  Very strong starts, charges perfectly and holds the charge better than AGM/LA.  I think the 12-cell unit would be more suitable for your Norge's power requirements.
I reckon you could save around 10 pounds by replacing your current battery with a lithium equivalent.  The diminutive size of the lithium battery means you can mount it anywhere, in any orientation, and then use the space vacated in your battery box for something useful - eg, on-board luggage, etc.
Other than the rather spendy cost of a lithium battery and the need for a special charger, I can see no downside to fitting your bike with a lithium battery (unless perhaps you plan to ride in extremely cold temps.)  For reasons I don't quite understand, there appears to be considerable conservatism on this forum and reluctance to move forward from traditional battery technology.  I see no reason why both modern and older-generation Guzzis should not benefit from this now-mature, advanced battery technology.
https://shop.revzilla.com/motorcycle/antigravity-small-case-12-cell-360ca-lithium-ion-battery
« Last Edit: November 02, 2017, 04:08:59 PM by Diploman »
2015 KTM 390 Duke
Offline Bisbonian
  • Living the Dream
« Reply #14 on: November 02, 2017, 04:13:28 PM »
My experience with a lithium battery in my 1200 Sport has cured me of trying it again. For me, cold meant anything below 55 degrees wouldn't allow for a start.
While the older bikes may have no problem, the starter logic on my 1200 Sport meant that the starter would not spin if the ECU did not sense enough battery power. So this means that the battery never got that load to allow it to warm up and provide full power.
While the batteries may be great for a number of machines, my 1200 Sport (and probably the Norge in this thread) is not one of them. I really wanted it to work out, but alas.
Offline blackbuell
« Reply #15 on: November 02, 2017, 05:58:58 PM »
I'm going with the Yuasa; pick up one tomorrow from a local dealership; need it for Saturday morning ride home from Indiana with the "new" Norge. I sure hope this bike fulfills its potential as a long-term cross-country rider.
Jon
Offline PJPR01
« Reply #16 on: November 02, 2017, 06:17:28 PM »
I've had good experience with the Shorai lithium...but it lasted 3 years and then I had a failed cell.  What I can't tell for certain is whether that's a normal battery life for a Lithium or not...but Shorai was good...they sent me a refurbed for free, or the chance to buy a new one for 50% of the price per their policy below.  I took the free refurb and it's working fine so far.  Obviously it's about a 2:1 price ratio for Lithium vs. AGM...but the weight savings is nice.
Shorai has a 5-year Prorated Warranty For Batteries:
1st Year from original purchase date:: Free Replacement unless we determine that the warranty has been voided due to non-compliance. All free replacements require a dated receipt.   You must have the correct battery for your vehicle to qualify for full free replacement.
2nd � 5th Year: 50% off of the MSRP of a new battery if we are unable to recover yours.
After 5 Years - Recycle Program: 15% discount and FREE ground shipping (with core exchange)
Shorai has a 1-year Free Replacement Warranty on Chargers, however you may receive Firmware updates or Charger checkups at any time at no cost other than the shipping to us.  We cover the shipping to you for all warranties unless expedited shipping is requested.
« Last Edit: November 02, 2017, 11:36:47 PM by PJPR01 »
Paul R
2008 Silver Norge
2002 V11 Scura
Offline Huzo
« Reply #17 on: November 02, 2017, 07:27:24 PM »
Jon
Mine and the others have done
ok.
Do make sure you do the startus mod, and the swingarm/suspension grease thing.
What colour...(most important) !
Offline Diploman
« Reply #18 on: November 02, 2017, 09:59:07 PM »
Bisbonian,  It is true that in colder temperatures lithium batteries become a bit lethargic.  55 degrees, however, seems quite warm for this phenomenon.  My Anti-Gravity starts to show initial low voltage at around 35 degrees.
There is an easy work-around for this behavior.  Turning on the headlight hi-beam for 30 -60 seconds before starting will heat up and activate the battery back to quasi -normal voltage and cranking power in colder weather.  Starts without problem once the battery is awakened.
2015 KTM 390 Duke
Offline Huzo
« Reply #19 on: November 02, 2017, 10:02:25 PM »
Why would you buggerise around when you can buy a Motobat or similar, chuck the bugger in, and just go for a ride...
Offline flip
« Reply #20 on: November 02, 2017, 10:25:18 PM »
A few years back, I put a Shorai in my Breva 1100. I think the first one lasted a couple of years. I got another one and it didn't last that long. My Breva was parked a lot during that time period and something on the bike kept draining the battery. I bought an extremely cheap AGM battery a few months ago and so far so good..I think the brand was Mighty Max and I paid around $44 with shipping.
Edit: After the 1st of the year, My Breva 1100 wouldn't turn over. I charged the battery and cleaned connections but the battery didn't have enough juice to do it's job. I took the smaller battery out of my Shiver and put it in the Breva and it fired right up. The Mighty Max battery had been put on a trickle charger several times while the bike was parked but it ended up dying in under a year.
« Last Edit: February 09, 2018, 09:27:37 PM by flip »
North Carolina
Offline blackbuell
« Reply #21 on: November 03, 2017, 05:13:59 AM »
Huzo,
It's red, and yes, I will lube the swingarm and shock pivots, and do the SI fix. I'll at least take a look at the alternator belt and the fuel filter; will replace them eventually if not right away. First few items on the agenda: replace tires and all fluids, locktite stand fasteners, install throttlemeister and ram mount for GPS.
It will be nice to have a Guzzi in the garage again,
Jon
Offline Huzo
« Reply #22 on: November 03, 2017, 05:33:54 AM »
Huzo,
Jon
Great !
Is it that nice one from here on the forum ?
Reckon once you do the things you mention, you'll be right to go. Being a Red '07, you might need to investigate the oil pump, but mine's a red '07 and been faultles in that regard.
Offline blackbuell
« Reply #23 on: November 03, 2017, 05:45:50 AM »
Huzo,
Yes, it is the one posted on the forum. It was built in the middle of 2007 (number 113733) ; appears to be outside the cluster of red Norges with the defective oil pumps.
Jon
Offline Huzo
« Reply #24 on: November 03, 2017, 09:17:59 AM »
Huzo,
Jon
I'm glad someone decent got it...
What oil do you intend to use? I put a Teo Lamers dip stick extender on mine. Are you keeping the lower fairing panels on ?
« Last Edit: November 03, 2017, 09:19:59 AM by Huzo »
Offline blackbuell
« Reply #25 on: November 03, 2017, 10:35:33 AM »
Huzo,
Will likely keep the lowers on; unlike other 2007's that I have seen, it has the hole and plug in the left-side lower panel and the same dipstick that my 2009 Norge had. I don't know if this was a mod that the first owner made, or the ones built late in the model year came like that from the factory.
Jon
Offline PJPR01
« Reply #26 on: November 03, 2017, 12:28:20 PM »
Weight savings are material enough in nature between Lithium and standard AGM or standard non AGM.  If you don't have extreme cold temps, it's not an issue...and a few more seconds to wait is not a deal breaker.
Paul R
2008 Silver Norge
2002 V11 Scura
Offline jdgretz
« Reply #27 on: November 03, 2017, 03:24:58 PM »
That works IF you can turn on the headlights without the bike being on.  On the Norge, no lights (other than parking lights) until the bike is running.  No turning on the heated gear (running direct from the battery) will do the trick.
jdg
2008 Honda Goldwing
Offline Huzo
« Reply #28 on: November 03, 2017, 03:56:52 PM »
Huzo,
Jon
Mine's 113401
Offline flower_king001
« Reply #29 on: November 03, 2017, 06:18:29 PM »
Same...I'm using one in my Breva 1100 and also have been using Motobatt's in my EV with great success. As a matter of fact I have a spare/new MBTX16U sitting on the shelf in the house if interested.
Brian
Steve,
Thanks,
Jon
« Last Edit: November 04, 2017, 09:03:18 AM by flower_king001 »
1971 BMW R90/5
1998 Moto Guzzi 1100 EV
2005 BMW 1200 RT
2007 BMW 1200 GS
2007 Moto Guzzi Breva 1100
