John Henry:I am giving this some thought. Since I have been posting here for a few years under this name, I really hate to change it. I will change the avatar however.
You're right on the mark. First open road ride I took included a bit of road works, where crap flipped up made a beeline for the top of the guard. A real front bum to clean, it's almost impossible to get access to. Hose alone, was ineffective.Coupled with road tar and other nasty things accumulating there, I'm considering repainting the top (inside) of the cover to make it less obvious. I might try masking tape first to get an idea whether this will work.
Yesterday, I traded the Blu Guzz in for a yellow V85TT. So, first of all, any of you that hankered for a blue 2015 1400 Custom with a lot of accessories, see Enzo at Cadre.
I just checked their website and don't see it listed, yet. I'll be curious to see the asking price. Those blue Cal14 Customs sure look nice. I missed out on one in Springfield Missouri last month...
The price YOU give THEM is just a phone call away!
Interesting to see the claim that 70% of trade-in's on the V85 come from non-Moto Guzzi riders.https://www.latimes.com/business/story/2019-08-01/moto-guzzi-was-once-a-legend-in-italian-motorcycles-can-it-make-a-comeback
Yes, it fit! Not as cool, but I will use this on my longer touring trip when I cant predict the weather.Maybe paint the lover part in white and yellow like the original part.
Thanks for that info AG. I gather that's the Caponord 'guard you're using? Given that whilst both will turn with the wheel/fork assembly, I'm guessing that you still need to remove one when the other is fitted, to avoid them clashing when you hit a bump....correct or not? I notice that the front half of the upper 'guard performs double duty as an air intake scoop or funnel, but the rear half merely performs a protective function, made redundant with the Caponord mudguard fitted. What will you do with this upper 'guard? Remove it or fabricate/find some sort of 'duckbill' arrangement to direct cool air towards the air intake?I suppose you could cut down the upper by removing the redundant slotted rear and foreshorten the front into some sort of de facto duckbill to provide a modicum of air-scoop functionality.
THAT...! is brilliant..I will do the same, well done.
Any idea when the red one you are desiring is going to be in your possession Peter?
Defective assembly and prep by the dealer -- I believe the dealer installs the hand guards. Does anyone know if the forks on the V85 are damper rod or cartridge design?
The bar end bolt vibrated out and I lost the weight as well, be sure to check these guys. Will remove the hand guard until I can figure out a replacement for the weight.
Thanks for the tip. I just went out and lock-tited mine.
Check the nuts on your seat too! This from Facebook:Sam RuaNew Member · 11 hrsI'm not sure how this happened but I managed to lose the lumbar support on the seat of my V85TT while out on my ride yesterday. I recommend checking the fasteners and even adding some thread locker. I was doing a fair amount of standing on the bike and that is all I can think of that would have caused this to pop off.😡
I'm also a very lucky lad!Decided to take a walk along my path to the freeway just in case, lo and behold there it was sitting in the gutter 1/4 mile from my home.
https://www.af1racing.com/store/Scripts/prodView.asp?idproduct=7009&sku=859949&description=OEM+Aprilia+Bar+End+Weight+%2D859949Miracle you found it. New ones aren't that expensive.
