Author Topic: Anybody know about WOLO Dual Horns?  (Read 5810 times)
Offline willowstreetguzziguy
« on: November 03, 2017, 01:06:54 PM »
Was looking to replace my anemic single horn on my 1200 sport and found a set of Wolo dual tone horns at advanced auto parts. Has anybody come upon these and are they any good? I was looking for a set of Fiamm horns and saw these.
2008 Guzzi 1200 Sport
Re: Anybody know about WOLO Dual Horns?
« Reply #1 on: November 03, 2017, 01:48:39 PM »
I have a pair (one high, one low) of these on my Convert. Very loud.
« Reply #2 on: November 03, 2017, 02:05:24 PM »
Are they WOLO? How long have you had them on your bike?
« Last Edit: November 03, 2017, 02:06:30 PM by willowstreetguzziguy »
Offline Testarossa
    • Skiing History
« Reply #3 on: November 03, 2017, 02:54:04 PM »
I bought this for the Mille
but wound up replacing them with the Fiamm equivalent, which is noticeably louder.
I do believe that there's a lot of production variation in horns, especially the "off" brands.
« Reply #4 on: November 03, 2017, 03:03:45 PM »
Yes, Wolo, bought on Amazon.
https://www.amazon.com/gp/product/B00029XGLE/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
Been on for 6mos./8,000 miles so far.
« Reply #5 on: November 03, 2017, 03:25:33 PM »
I put Wolos on the Norge. They were plenty loud.
« Reply #6 on: November 03, 2017, 03:41:09 PM »
Wolo's work.  :thumb:
« Reply #7 on: November 03, 2017, 05:04:20 PM »
I put the FIAAM Freeway Blasters on my Griso, they just fit in place of the original squeakers with a new bracket.
I removed the chrome grill and wired the relay straight from fuse at the battery, Very loud.
If you want horns to be loud they need a relay with a dedicated supply, Guzzi wimpy wiring will not cut it.
« Last Edit: November 03, 2017, 05:16:12 PM by Kiwi_Roy »
« Reply #8 on: November 03, 2017, 06:19:13 PM »
You can hook up a Delco-Remy off a GM car and sound like a Caddy/Buick.  That'll get people looking.  The Fiamms sound like a Mercedes sedan.   :evil:   :thumb:
Offline Testarossa
    • Skiing History
« Reply #9 on: November 03, 2017, 06:30:09 PM »
 :1:
Offline Dalini
« Reply #10 on: November 03, 2017, 11:44:26 PM »
I like them. They install easily, are definately heard by drivers & also compliment my MGX-21.
Moto
« Reply #11 on: November 03, 2017, 11:54:41 PM »
Can anybody tell me the diameter of these things?
Moto
« Reply #12 on: November 04, 2017, 12:26:34 AM »
Are they the “Snail” shape horns or round? Because the do make a set of larger round red ones.
« Reply #13 on: November 04, 2017, 08:45:09 AM »
Can I take split the positive and negative wires leading to the stock single horn and wire them to he 2 new horns?
« Reply #14 on: November 04, 2017, 08:59:49 AM »
Yes, that's how they're wired from the factory.
« Reply #15 on: November 04, 2017, 09:34:35 AM »
You can do that. But I found in a number of cases that the stock wiring just is not up to  the task of powering two healthy horns. In the end, I would add a relay and a power feed from the battery. It made a real difference.
« Reply #16 on: November 04, 2017, 09:53:25 AM »
I took his question to mean wiring between the horns - from one horn to the other. I agree, there definitely needs to be a relay with direct power feed to one horn and then wires of proper gauge to carry the power to the other horn.
« Reply #17 on: November 04, 2017, 03:06:04 PM »
I've had dual wolos that had two terminals on one buzzer and four on the other.  They were designed to feed through the 4-term to the 2-term in parallel.
« Reply #18 on: November 22, 2017, 09:06:33 AM »
I was just alerted to this very loud and effective horn installation:
https://www.youtube.com/watch?v=pTRYm_peqGA
« Reply #19 on: November 22, 2017, 09:41:53 AM »
Wonder what locomotive he swiped those from?  :grin: Must be a current or former railroad engineer - he's blowing for a road crossing.
« Reply #20 on: November 22, 2017, 09:53:36 AM »
Interesting, I thought it sounded familiar.  I've seen the video before at some point.  It still makes me want to build my own.  :)
Offline HDGoose
« Reply #21 on: November 22, 2017, 10:09:22 AM »
I wired a WOLO 'Bad Boy' dual tone air horn to my 97 California on the headlight bracket. Not pretty but works well. I could not find anything acceptable that fit in the stock location.
Offline webmost
  • Safety Third
    • The Sotweed Factor
« Reply #22 on: November 22, 2017, 10:25:43 AM »
Have Fiamms on one bike and Wolos on two others. Wolos are way louder. Really let's 'em know they pissed you off.
Unmitigated risk aversion is the new Puritanism; complete with witch hunts funny outfits and humorless preachers thundering doom. The Deity is Safety; Satan is a Lawyer; but the object is the same: to suck the life out of life and tell you how to live it.
« Reply #23 on: November 22, 2017, 06:25:11 PM »
Always thought Fiamms were louder... thanks
« Reply #24 on: November 22, 2017, 07:03:47 PM »
Anecdotally, Wolos have a shorter life than Fiamms.  That's IIRC from different forum threads on horns.   :tongue:
Offline Idontwantapickle
« Reply #25 on: November 23, 2017, 07:46:48 PM »
As others have noted a relay is best for power. I routed the stock wire up under the tank on my Norge and use it to trigger the relay. Stock wiring unmolested
Sir James Paul McCartney
AMA Charter Life Member
72 Eldo
84 BMW R100RS
Offline Diploman
« Reply #26 on: November 24, 2017, 08:06:32 AM »
I believe very strongly in the necessity/utility of fitting loud, penetrating horns on any motorbike I ride.  I can't count the number of times I have averted potentially dangerous situations by being able to warn and attract the attention of otherwise distracted or preoccupied drivers with a pre-emptive horn blast.
I have always run dual Fiamms or Hella Supertones.  Finding a suitable place to mount dual horns is usually a bit of a pain. particularly with a smaller bike such as my V50.  Recently I discovered a good solution:  the Denali Soundbomb Split, a (better quality) knockoff of the Stebel Nautilus, but with the dual-tone horn and compressor split into separate units.  This configuration greatly simplifies mounting and opens up many options.  On the V50, for example, I fitted the compressor to the central spine under the tank, then ran the air hose forward to the horn unit which is affixed to the upper cross member between the downtubes just under the headstock.  The Denali has a higher pitched, louder and more penetrating output compared to the Fiamm.  It runs, of course, off a relay.  Highly recommended.
http://www.twistedthrottle.com/denali-soundbomb-split-dual-tone-air-horn
2015 KTM 390 Duke
Offline webmost
  • Safety Third
« Reply #27 on: November 24, 2017, 05:17:31 PM »
No. Your stock horn wiring is designed to power your stock meep meep. Use it to flip a relay for loud results.
« Reply #28 on: November 24, 2017, 05:19:35 PM »
 :1:
Offline redhawk47
  • Traveler
« Reply #29 on: November 24, 2017, 11:56:54 PM »
Check out screaming-banshee.com - shockwave
Loud horn, small package, comes with harness and relay
Has an interesting dual horn function. Tap the horn button and you get a beep; hold the button and you get a BLAST.
I have a similar setup on my V7 with a Nautilus low tone and one of the OEM horns. I was able to fit the Nautilus in the OEM location, with engine guards. I'll try to do a video tomorrow.
Dan
