Author Topic: Spares and tools for touring, pcm reliability.  (Read 3626 times)
Offline Edgo897
« on: November 08, 2017, 12:02:20 AM »
I'm going through my 98 V11 EV trying to make it as reliable as I can. I pack the simple stuff that can go bad, fuses, relays, cables, etc..., and I have tools to remove a wheel if necessary. Barring something catastrophic I think I have it covered. My big concern is the P8 pcm. If it goes bad one is really cooked. Does anyone carry a spare or is it not a concern? I'm thinking of getting a spare to keep in the bag.
Thanks, Ed
Offline Murray
Re: Spares and tools for touring, pcm reliability.
« Reply #1 on: November 08, 2017, 04:54:15 AM »
I doubt your 98 EV has the P8. TBH you are far more likely to have a voltage regulator turn itself inside out than an ECU. There are plenty of examples of these with 100 000miles plus. I have however seen a crank sensor bring a bit to a halt with no warning so that might be more likely. I wouldn't worry about it too much.
« Reply #2 on: November 08, 2017, 05:52:14 AM »
ECUs are as reliable as a bucket of hammers. Run a dedicated ground wire from your voltage regulator case to a bolt on the engine.
Offline Edgo897
« Reply #3 on: November 08, 2017, 06:34:07 AM »
So I'll get a spare crank sensor and voltage regulator for the road tool kit. Cheap and easy to find now rather than trying to find one in the middle of nowhere. What else?
« Reply #4 on: November 08, 2017, 06:48:29 AM »
Front wheel bearings are the only thing that let my EV down, cheap as chips but unobtainable when you need them,
Change them out when you change the tires and carry 1 old one as a spare.
Offline Murray
« Reply #5 on: November 08, 2017, 07:14:51 AM »
A generic accel HD or ATV voltage reg will do (for a fraction of the cost) 26amp or greater is the capacity required. TBH if it does wet itself you can still ride on batt power for a little while so not a complete show stopper.
Offline Edgo897
« Reply #6 on: November 08, 2017, 09:05:05 AM »
I installed new front and rear wheel bearings. Can someone post up a link for a spare regulator purchase? And is there an inexpensive crank sensor replacement out there?
« Reply #7 on: November 08, 2017, 09:26:33 AM »
Have faith in your bike, you don't need 1/2 saddle bag for what if, just a card. I wouldn't have that stuff bouncing around for what if it breaks before you need it. Check bike before you leave, and join the Club.
« Reply #8 on: November 08, 2017, 09:32:28 AM »
 Don't all '98 EV's have the P8 ? Not really an issue except for it being large and clunky .
Offline ken farr
« Reply #9 on: November 08, 2017, 09:34:47 AM »
 :1:
kjf
ken farr
06 B1100 - click!
Fillmore, Ca.
Online Wayne Orwig
« Reply #10 on: November 08, 2017, 09:48:33 AM »
I have replaced a lot of clutch plates and voltage regulators, but never had to replace an ECU.
I did have a somewhat sudden TPS failure once.
You can get those parts shipped overnight. You would need to tow a trailer full of parts and tools for everything like that.
Join the MGNOC and carry the owners list in case you need to call about getting a part quickly.
Carry tire plugs and a pump. Spare fuses and relays. Reasonable tools. Enjoy the ride.
« Reply #11 on: November 08, 2017, 09:55:44 AM »
As far as I'm concerned, I try to have a way to fix a flat. That's the most common "break down." I certainly don't plan on overhauling the motorcycle on the side of the road.  :smiley:
Offline Edgo897
« Reply #12 on: November 08, 2017, 10:07:22 AM »
My 98 EV has the P8 "big brain". I've got fix-a-flat and some tire plugs. As I see it an ounce of prevention is always worth a pound of cure. The bike has three bags, if half of one has a few parts and tools I think it's worth it to me. I do all my own wrenching so if a fifty dollar spare part gets me going I'd like to be able to do that. I do like the simplicity of this Beast.
« Reply #13 on: November 08, 2017, 10:26:49 AM »
 I carry a small repurposed soft bag originally intended as an ice bag filled with some basic tools . Those tools have come in handy more than once , usually in helping another motorcyclist who can't be bothered to carry any tools at all  :rolleyes: :grin:
 Seriously , don't get carried away , honestly a supply of water and a candy bar or a bag of trail mix , and a cell phone along with some very basic tools will usually suffice .
 Oh , a couple of crimp connectors , a small roll of wire , and zip ties are really handy .
Offline Edgo897
« Reply #14 on: November 08, 2017, 11:49:32 AM »
 If I carry a lot of stuff then won't it make it likely that those parts will not
fail?
« Last Edit: November 08, 2017, 03:44:37 PM by Edgo897 »
Offline malik
« Reply #15 on: November 09, 2017, 03:08:59 PM »
Quite likely, but carrying a couple of spare pistons is a little over the top.
Do what you can to make it reliable, subscribe to a decent roadside assist service, and carry less. Enjoy the adventure.
