Stock Bassa front brake light switch available anywhere?
Topic: Stock Bassa front brake light switch available anywhere? (Read 1323 times)
normzone
'72 Eldo - 1980 to 1990 - '99 Bassa 2014 - 2023
November 15, 2017, 11:18:02 AM »
[Zoom Zoom] provided a part number for an aftermarket switch that's close but it does not appear to be sealed in the same manner, and the example Radio Shack shipped requires some jig-fiddling to make it trigger properly.
Testing indicates that the aged stocker is still working, just requires - you guessed it, some adjustment to the triggering mechanism to make it go
off
reliably.
I'm on the verge of just putting a little aluminum foil behind the ball bearing that lives in the pocket in the brake lever and serves as the messenger to the switch when the lever is moved. But before I start getting creative, is there a stock switch source? Our usual providers don't show it on their websites.
yogidozer
Re: Stock Bassa front brake light switch available anywhere?
Reply #1 on:
November 15, 2017, 11:25:43 AM »
like this?
California 1100, 1998-2000 California EV, Jackal, Quota ES, Bassa, 1100 Sport Corsa, V11 LeMans, Centauro, Daytona, Ballabio, V11Cafe, etc. Compare to the similar but larger version to avoid ordering errors. Brake light switch, hand brake microswitch, no wire, 9mm x 19mm with male spade terminals. TIP: Use caution when removing the switch, to avoid loss of the very small actuating metal ball.
http://www.mgcycle.com/index.php?main_page=product_info&cPath=110_146&products_id=1230
or this
California 1100 1994-1997, 1998-2000 California EV, Jackal, Quota ES, Bassa, California Special, 1100 Sport Corsa, 1100 Sport Injected, V11 LeMans 2001-2004, Centauro, Daytona, Daytona RS, Ballabio, V11 Cafe, Quota ES, Nevada 1993-1997, Nevada Club 1998-2001, Nevada Base Club 2002-2003. Brembo brake light switch kit, with screws and nuts and cylindrical plastic activator. Hand brake microswitch, no wire, 9mm x 19mm with male spade terminals
http://www.mgcycle.com/index.php?main_page=product_info&cPath=110_146&products_id=4469
Hahnda
Gaggle Mentor
Reply #2 on:
November 15, 2017, 11:38:17 AM »
$9 shipping included.
http://www.dpguzzi.com/switch.htm
1949 GTV - 1948 Airone
www.scramblercycle.
com
normzone
Reply #3 on:
November 15, 2017, 11:53:22 AM »
Wow - thanks so much guys.
I guess this means that I'll have to pass the trophy on my fireplace mantle on to you guys - You know, the one that says " Best Internet Search " on it.
Fortunately it was designed to be split in two, so you can share it. I'll have to dig through my stuff for it though - the fireplace mantle is in a box somewhere, since I'm packing to move.
