Author Topic: Anyone familiar with this new clutch  (Read 2383 times)
Offline Ncdan
« on: November 16, 2017, 07:46:27 AM »
I just saw an add for an apparent new type of clutch. Im sorry I don’t know how to enter it here. It’s called  REKULSE and you can google reklusecom  The add is a Video and it shows a guy on a harley coming to a stop lite and not using the clutch, with th the bike still in gear. When the light changes he just pulls off with gas only just like a cyntrifical clutch , changing gears with no clutch at all. The add also goes on to say you can use the clutch if you feel the need but not necessary. If this thing works it could be a good thing for some folks that have hand and strength issues, check it out and give your thoughts.
Offline mtiberio
    • TiberioRacing
Re: Anyone familiar with this new clutch
« Reply #1 on: November 16, 2017, 08:09:09 AM »
bought one for my harley. returned it. I thought it was a joke, a gimmick. If I adjusted it to fully disengage, it was jerky on the uptake. If I adjusted it to be smooth, it didn't fully disengage. Its a centrifugal clutch that they try and make small enough to fit in the same space as the stocker. It uses small ball bearings and the centrifugal force driving them outward in ramps to engage/disengage the clutch.
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
Online pehayes
« Reply #2 on: November 16, 2017, 10:19:38 AM »
Nothing new under the sun.  I once owned a Harley Davidson Scoot-Away TOPPER.  Wish I still owned it!  Centrifugal clutch and variable pulleys and belt drive.  Used three giant ball bearings to drive the centrifugal ramp system to change the effective diameter of the front belt pulley.  Drive system was designed by SACHS I believe.
I saw one of these new fangled clutches in demo on a BMW show last year.  Seemed interesting, but might effect a lot of low speed or low rpm driveability functions.  Certainly effective for someone with ability limitations.
Ffremont CA
« Reply #3 on: November 16, 2017, 11:40:40 AM »
These are popular on dirt bikes and dual sports, as it makes it easier to pick through rough single track at slow speeds w/o being on/off the clutch so much.
Offline motocruz
« Reply #4 on: November 16, 2017, 12:56:00 PM »
How does this work on a Harley? Most riders keep rapping on their throttles at an intersection for noise. Man, they would shoot right through the intersection if they forgot they installed it.....  :bike-037:
1976 T-3
1998 EV
1973 Triumph Trident
1980 Yamaha 400 YZ
2022 V85 Guardia D’Onore
Offline Guzzi Gal
    • Sonoran Sunriders, YouTube
« Reply #5 on: November 16, 2017, 03:13:46 PM »
Ha!   :grin:
"Velvet" '16 Honda CTX 700,
"Miri" and Mori"
Offline KiwiKev
« Reply #6 on: November 16, 2017, 06:19:03 PM »
Ffremont CA
That variable belt drive was used
on some scooters and may well be still. Our French teacher at college had a wierd Manurhin ?? Scooter that used it.
https://encrypted-tbn1.gstatic.com/images?q=tbn:ANd9GcRKrh-WU0pT5f7FuRdovVuYJ1RI26KGJDaxn8JbNLMvlacA4bI7IeoBks79fw
« Last Edit: November 16, 2017, 06:22:08 PM by KiwiKev »
Offline Murray
« Reply #7 on: November 16, 2017, 06:25:18 PM »
Centrifugal clutch with slipper arrangement been around a number of years some of the enduro riders were using them (on a 300 TM stroker no less) did put a fair bit of heat back into the engine cases apparently, I very much doubt it could be applied to a Guzzi as it is based around the standard motorcycle multi-plate basket design.
« Reply #8 on: November 16, 2017, 06:25:39 PM »
Patrick.. you are the first guy I've ever heard of that actually owned a Topper.  :grin:
« Reply #9 on: November 16, 2017, 10:26:04 PM »
Most current scooters have centrifugal clutches for twist & go throttle operation, including my 3 Italian maxi-scooters (250, 400, 460).  Mine disengage when I get down to maybe 3 mph before stopping.  Mine have phenolic? rollers that engage the front pulley/belt drive.  Periodically I have to replace the rollers.  The front pulley expands/contracts to change the drive ratio of the belt for X speeds.  It's really a simple design that works.  :thumb:
« Last Edit: November 16, 2017, 10:27:59 PM by Arizona Wayne »
