Author Topic: Before I take it apart .... the (plastic ?) fitting for the temp sensor ?  (Read 3188 times)
Offline normzone
I'd appreciate a quick review from the collective wisdom - I have a brass fitting and a new sensor ready to go in the head this weekend.
But the fitting in there currently looks like / sounds like to a ting test / black anodized bead blasted aluminum.
Is this a clever illusion? Do I truly have the dreaded plastic fitting that requires great luck or a dental surgeon to remove?
Just the first clue to address in my poor MPG  analysis ....
Re: Before I take it apart .... the (plastic ?) fitting for the temp sensor ?
« Reply #1 on: November 17, 2017, 10:58:15 PM »
'Buzzing'  Absolutely no idea where that came from! GUZZI made two parts the brass ones and the black plastic ones. No alloy ones I've ever heard of either OME or AM.
« Last Edit: November 18, 2017, 04:18:08 AM by pete roper »
Offline normzone
« Reply #2 on: November 18, 2017, 12:42:27 AM »
Much thanks Pete - I'll get surgical on it this weekend.
Offline organfixsing
« Reply #3 on: November 18, 2017, 01:01:28 AM »
Before you put in the new one, put a small amount of some nickel anti-sieze in the hole, it doesn't take much, to improve the heat transfer from cylinder head to sensor. The sensor is actually a water temperature sensor. I used electronics heatsink paste but I am not sure that it will remain fluid for very long. The anti-sieze will handle higher temperatures. Perhaps the copper anti-sieze will handle higher temperature than the nickel? I don't know.
Cheers
Brian  :grin:
If you remove the wings of a fly, does that make it a walk?
Offline ITSec
« Reply #4 on: November 18, 2017, 01:16:36 AM »
The temperatures reached by a computer CPU at the point of contact with its heat sink are very high all things considered, but not as high as cylinder heads typically get. The thermal paste is designed for a typical operating temp of 30-70 degrees Celsius, but has lots and lots of room to handle higher temps. I've used the same kind of paste for years and it's done a good job.
ITSecurity
2013 Stelvio NTX - Copper
2008 Norge GT - Silver
I am but mad north-northwest!
Offline antmanbee
« Reply #5 on: November 18, 2017, 05:33:01 AM »
I use copper anti seize paste. Copper transfers heat better than anything but silver.
« Reply #6 on: November 18, 2017, 09:39:02 AM »
Norm, just be aware.. when you try to remove the sensor, it'll break. Probably.  :smiley:
I use copper anti seize because I have a life time supply..
Offline normzone
« Reply #7 on: November 18, 2017, 01:01:48 PM »
Thanks [Chuck in Indiana] - I've read the threads by the first responders - as I understand it, it either comes out in one piece, or you need dental tools and a machine shop.
I'm sacrificing a chicken first to improve my odds - Okay, actually I'm scrambling four eggs, but when the pipeline to the gods is busy some times they don't notice the difference.
« Reply #8 on: November 18, 2017, 08:41:08 PM »
Now you tell me. All this time I've been trying to follow protocol.
Offline normzone
« Reply #9 on: November 26, 2017, 09:48:13 PM »
Well, as usual, it's risk analysis, risk management. Not being an antique aircraft guy, my standards are a little lower than yours.
Mine WAS plastic, did not break during removal, and having read all the local threads and the sixty page thread on the other forum, I will not detail how I installed the new gear since it would border on political and religious - all I'd need to do would be to add a picture of a vacuum nipple to get the mods involved
 :wink: :evil:
