Author Topic: exhaust gasket for dummies  (Read 3357 times)
Offline EyedocKav
« on: December 01, 2017, 10:23:26 PM »
My breva 750 had an exhaust leak from the left side head.  When I removed the exhaust pipe, the gasket was shot.  Now that I have the new gasket, it has a metal side and and a (cork?) side and no instructions as to which side goes against the head and which side on the pipe.  Anyone know if it matters?  Thanks
Offline normzone
Re: exhaust gasket for dummies
« Reply #1 on: December 01, 2017, 11:46:25 PM »
Welcome to the forum, [EyedocKav].
I have no idea, but somebody who knows the answer will be along shortly.
Offline Phang
« Reply #2 on: December 02, 2017, 12:14:34 AM »
I installed it green side facing the head and metal side facing the header but I want to know the correct way.
2000 V11 Sport (Green)
1973 V7 Sport (Green)
Offline organfixsing
« Reply #3 on: December 02, 2017, 12:24:33 AM »
My instinct would be to put the metal side to the head as this is probably the hottest side of the junction, but, I don't really know.
Cheers
Brian  :afro:
If you remove the wings of a fly, does that make it a walk?
Offline Moto Fugazzi
    • Griso
« Reply #4 on: December 02, 2017, 01:21:46 AM »
I would also agree with organfixsing. The flat metal part should fit into the head (they should both be properly machined flat), while the malleable green surface would conform to the pipe a little better. That's my best somewhat educated guess.
Did you remove the old gasket yet? That should be the correct way, assuming they installed it correctly at the factory. But then again, if they installed it properly, you wouldn't have a leak in most cases.
Ken
Ken
2004 V11 Cafe Sport
2009 V7C White
2007 Griso Black-Sold
1978 V50 II Blue-Sold
« Reply #5 on: December 02, 2017, 01:44:22 AM »
Head may be closer to combustion but it is also a much larger heat sink.
To answer the question I don't think it matters terribly.
Offline MotoBug
« Reply #6 on: December 02, 2017, 05:05:13 AM »
Softer cork side to the alloy head? To reduce wear on softer hot alloy perhaps.
Offline Pop
« Reply #7 on: December 02, 2017, 06:59:19 PM »
As usual, all I can offer is bad humor. GREEN SIDE UP!
I only hope that one day I will have some useful info.
Pop
Ride to eat, if there ain't food, I ain't goin'
Offline guzzinka
« Reply #8 on: December 02, 2017, 09:02:30 PM »
Pop
:1:  That's how I always feel! :boozing:   Fortunately, bad humor is helpful
Offline Ncdan
« Reply #9 on: December 03, 2017, 07:19:07 AM »
My thinking would be to replace both at the same time and put one one way and one the other. That way which ever one goes fails first you’ll know the correct method:(
Orange Guzzi
« Reply #10 on: December 03, 2017, 10:39:19 AM »
It will not matter.  Just the way it is manufactured.  The metal gives the fiber some strength and integrity so it does not crumble and fall out.   I have two per side in my bike, stacked up.  There are various types of gaskets available made in different styles.  Recheck your nuts after a couple of rides.  Fully assemble the exhaust before tightening the various fasteners and clamps.  I work from the head back to the muffler when doing the final tightening.
« Reply #11 on: December 03, 2017, 11:16:25 AM »
Uhhh..
« Reply #12 on: December 03, 2017, 11:59:57 AM »
Be sure none of it is mounted in a bind or it'll crack on ya, most likely at the crossover. Anti-sneeze is your friend. The nickel based silver stuff blends in better if it spreads out of the joint and your concerned about looks.
Offline EyedocKav
« Reply #13 on: December 09, 2017, 06:47:48 PM »
Update: I first installed it with the metal side on the head and it still leaked.  Took it apart and noticed that there was some soot residue on the head so cleaned that really well, put it back but this time the other way and it held.  Perhaps if I had done a thorough cleaning in the first place it might have worked that way too.  I guess the jury is still out.  Cheers.
