Author Topic: "new" 2007 Norge valve clearance: glad I checked  (Read 3231 times)
Offline blackbuell
« on: December 07, 2017, 12:58:25 PM »
The 2007 Norge I bought a month ago now has a mere 3,000 miles on the ODO; 700 of those miles are mine. I've done quite a bit to it: new battery, new tires, changed all fluids, added a Kaoko throttle control, a ram mount for GPS, and a startus interruptus kit (thanks Paul), straightened a few supports for body work, touched up paint on body work, and done lots of polishing. Due to the low mileage, I figured the valves should be OK; thought I'd wait until my first summer cross-country trip before checking them. Why would valve clearances change if a bike was just sitting for 10 years?
I was bored yesterday (still adjusting to this retirement thing) so I decided to check the valves. Big surprise: all were tight. In fact, the left intake had essentially zero clearance. The bike did seem to be running fine; was certainly running as strong or even stronger than my 2009 Norge was before its demise at 54,000 miles. We are experiencing a cold spell now in KY; hope it warms up soon to see if the valve adjustment has made any difference in performance.
Jon
Offline Don G
Re: "new" 2007 Norge valve clearance: glad I checked
« Reply #1 on: December 07, 2017, 01:46:56 PM »
You should go through that Norge from stem to stern, likely find a bunch of things needing attention.  DonG
« Reply #2 on: December 07, 2017, 01:55:09 PM »
I checked my new Norge at the 600 mile service, and they were .013"  :rolleyes: Luigi apparently doesn't have any feeler gauges..
Offline blackbuell
« Reply #3 on: December 07, 2017, 02:02:14 PM »
Must have been a noisy motor!
Jon
Offline blackbuell
« Reply #4 on: December 07, 2017, 02:07:10 PM »
Doing that gradually: next will be fuel filter and alternator belt. Just loctited side and center stands (had those come loose on my 2009). Later will lube swingarm and shock pivots.
« Reply #5 on: December 07, 2017, 02:24:33 PM »
Please post the part Nos, I assume they will be applicable to my O7 Griso
Do you have a shop stand that will support the rear end when you remove the swing arm?
I posted my home built $10 special on Griso Gheto I'm pretty sure it will work for a Norge also.
Offline Sheepdog
« Reply #6 on: December 07, 2017, 02:27:52 PM »
My US-spec �07 Vintage came with pretty tight clearances on the valves when new (.002” & .004”) This was supposedly a measure to reduce valve noise. It is quieter, but it seems to run a little better with the older and looser clearance of .004” & .006”.
« Reply #7 on: December 07, 2017, 04:32:36 PM »
Jon
I wear earplugs. <shrug> I just figured that since nobody in the US actually sets up or services new bikes  :evil: they'd leave them plenty loose so it wouldn't burn valves.
