Author Topic: Eldo front axle  (Read 2098 times)
Offline ray bear
Eldo front axle
« on: December 19, 2017, 07:57:40 PM »
Hi all, can someone tell me the difference between the front axle, spindle on an Eldorado with 2 shoes to one with 4 shoes, I wish to purchase a 4 shoe wheel to put on my eldo but does not have a spindle. Parts list shows different numbers for the two but can the 2 shoe spindle be machined to fit the 4 shoe. I cant use my V7 sport as an example as the Tonti has a different brake/ hub to the loop frame.
And would any one in Australia have one they aren't using for a tent peg or paper weight...Thanks Bill
I couldn't find any advertised with Harpers or MG and  moto inter
« Last Edit: December 19, 2017, 07:59:12 PM by raybear »
73 V7 sport
73 Eldo police special
68 BSA rocket 3
74 Norton Commando
78 Honda CBX 1000
47 HRD vincent Rapide
XT 500 Yamaha
Re: Eldo front axle
« Reply #1 on: December 19, 2017, 08:21:21 PM »
http://thisoldtractor.com/moto_guzzi_loopframe_axles.html
It would be possible to machine the 70 mm long large diameter of the 2LS axle down to 59 mm to make it a 4LS axle.
Offline ray bear
Re: Eldo front axle
« Reply #2 on: December 19, 2017, 08:42:07 PM »
Thanks Charlie, I looked on gregorys site but missed that one, If I cant acquire the correct one then I can turn mine down, It should not affect the axle strength.
73 V7 sport
68 BSA rocket 3
74 Norton Commando
78 Honda CBX 1000
XT 500 Yamaha
Offline Idontwantapickle
Re: Eldo front axle
« Reply #3 on: December 19, 2017, 09:51:43 PM »
Be very careful machining that axle, I have seen that fail and it is not a good surprise! Try to hold out for the correct part. Maybe the seller has it?
Hunter
Sir James Paul McCartney
AMA Charter Life Member
72 Eldo
84 BMW R100RS
Re: Eldo front axle
« Reply #4 on: December 19, 2017, 10:07:57 PM »
Available from Stein-Dinse:
https://www.stein-dinse.biz/Moto-Guzzi/Frame-Accessories/Wheels-and-rims/Axle/Axle-front-850-GT::7867.html
It would probably be a good idea to confirm the length of the large diameter with them before ordering.
Offline harrytief
Re: Eldo front axle
« Reply #5 on: December 20, 2017, 08:40:13 AM »
Do you know if this axle will also work for a twin front disc eldo? The listing does not list a police eldo nor give dimensions>
Harry
Re: Eldo front axle
« Reply #6 on: December 20, 2017, 09:07:07 AM »
Harry
No, it will not. Dimensions of the disc axle from This Old Tractor:
The overall length of the axle is 291 mm. The length of the larger diameter portion is 92 mm.
It's also larger in diameter. You need the disc axle - twin or single disc doesn't effect axle length. I bought four from Teo Lamers but only have one left and it has boogered up threads. Harper's has them listed on their website:
https://www.harpermoto.com/front-axle-13614140.html
Offline Don G
Re: Eldo front axle
« Reply #7 on: December 20, 2017, 12:28:40 PM »
Would you also need a different right hand lower fork leg as well?  DonG
Re: Eldo front axle
« Reply #8 on: December 20, 2017, 01:54:21 PM »
For the 4LS front drum? Yes, it needs to have an "anchor" on it the same as the left fork lower. One could be added to a 2LS lower if care was used during welding.
