Author Topic: 1000SP Turn Signal I.D.  (Read 1422 times)
Offline timmythecop
« on: December 20, 2017, 11:40:09 PM »
I know my limits to what goes where, so can anyone inform me as to the difference in these two signals? The Red one is mine and has a black housing that points the lens in a more forward direction and the green one is just your average signal lens.  Is it a euro-u.s. thing or an era thing. Possibly an aftermarket thing?  Any info is appreciated.
« Last Edit: December 20, 2017, 11:41:01 PM by timmythecop »
1980 1000SP
1978 850 T3
2000 VFR800Fi
2015 Harley FLHTPi
2005 Harley XLH1200R
1995 BMW R1100GS
1992 BMW K75S
1981 Suzuki GS450T
Re: 1000SP Turn Signal I.D.
« Reply #1 on: December 21, 2017, 09:10:16 AM »
The bottom ones were used on early ('78 & '79?) models in the US. The upper ones were used after those - on through the SP II IIRC. The early ones consist of just the signal and surround, the later ones have more pieces: signal body, mounting bracket, surround and a gasket.
From the research I did when I was looking for early bits, I found that the signal was used on several Italian cars (Maserati and Fiat 850 sedan) but the lens was sometimes clear in those applications. They were also used on Ducatis. Rather difficult to find.
Offline timmythecop
« Reply #2 on: December 22, 2017, 12:26:44 AM »
Thanks for the info.  I did try to find out myself, but I was stymied.
« Last Edit: December 22, 2017, 12:28:03 AM by timmythecop »
1980 1000SP
1978 850 T3
2000 VFR800Fi
2015 Harley FLHTPi
1995 BMW R1100GS
1992 BMW K75S
1981 Suzuki GS450T
« Reply #3 on: December 23, 2017, 02:09:28 PM »
Gotta love WG..I've never had a Guzzi related question that wasn't answered within a day..
Offline bmc5733946
« Reply #4 on: December 23, 2017, 02:35:47 PM »
Yeah, Chuck we need better questions, your turn to come up with some!    :grin:
Brian
1989 MILLE GT
2006 BREVA 750
2004 BREVA 750
1975 CONVERT
Offline timmythecop
« Reply #5 on: December 23, 2017, 04:47:03 PM »
Yes. I guess i need a parts exchange log lije i have for my vfr and BMW K100. For example, the lug nuts on a vfr are the same for a honda civic and in a pinch, you can bolt in a civic soace saver, and a K bike fuel pump is over 150 bucks, but the mustang 2 part in my bike cost 23 dollars
1980 1000SP
1978 850 T3
2000 VFR800Fi
2015 Harley FLHTPi
1995 BMW R1100GS
1992 BMW K75S
1981 Suzuki GS450T
« Reply #6 on: December 23, 2017, 06:51:55 PM »
Brian
what's the real reason the convert u-joint/driveshaft uses 20 tooth splines and the 5 speeds use 10? I believe it to be an engineering/design choice but what's the physics behind it?
