Author Topic: another trike build  (Read 2044 times)
Offline gearman
another trike build
« on: December 22, 2017, 10:51:37 AM »
After my fiasco on the leaning trike I decided to make a scale 2by i and a 1by 2 and test the stability.I wish I could find a 500 rpm motor with remote control to shut it off while running  at different speeds and turning radisuses.SP
Re: another trike build
« Reply #1 on: December 22, 2017, 10:59:58 AM »
What is the rear drive?  I still think you'll be unhappy with a live axle -- IRS is the way to go!
« Reply #2 on: December 22, 2017, 11:08:33 AM »
for a motor try www.surpluscenter.c om
I agree with David and he has much experience with it.
« Last Edit: December 22, 2017, 11:10:15 AM by John A »
Offline gearman
« Reply #3 on: December 22, 2017, 11:12:38 AM »
This is just a test. I am only driving one wheel, Through a 90 degree bevel box,
« Reply #4 on: December 23, 2017, 09:06:02 AM »
Building a model isn't going to help test stability much unless you can get the center of gravity in exactly the same place as it would be with a Guzzi engine, transmission, etc. plus a full tank and rider aboard.
Offline gearman
« Reply #5 on: December 29, 2017, 08:32:16 AM »
As long as the center of gravity is the same on both versions it should answer the dynamic question I want answered.   ME thinks.
