Author Topic: Small block CPK tooth wheel question  (Read 22373 times)
Offline FredZeppelin
« on: December 24, 2017, 04:22:01 AM »
Hi all,
Compliments of the season.
Can anyone shed some light on this?:
I am preparing to fit an aftermarket EFI/CDI kit to a 2014 V7 engine that is missing most of the OEM gubbins.
The toothed wheel that triggers the CPK sensor has 48 teeth, less 2 gaps of 2 teeth.
These gaps are diametrically opposite each other.
If the ignition is triggered by the gap passing the sensor plus a programmed delay, how does the OEM ECU know when to fire cylinder 1 and when to fire cylinder 2?
Many thanks for any insight you can give on this.
Cheers
Fred Cawston
Fred
'72 Stornello 160
Small block bitza
Honda Bros 650
'63 Ducati Sport 48
BM 1100RT
Re: Small block CPK tooth wheel question
« Reply #1 on: December 24, 2017, 09:44:47 AM »
You'll get more views if you post in the correct section: General Discussion.
« Reply #2 on: December 24, 2017, 04:31:39 PM »
Thanks Charlie, will do.
Fred
'72 Stornello 160
Small block bitza
Honda Bros 650
'63 Ducati Sport 48
BM 1100RT
