I have to add this forum is a great place to seek advice but there are always a fair number of curmudgeonly responses.
The first modification we tried was to twin spark the cylinder heads, this gave an improvement in performance and reduced the E.G.T's, but not by enough, back to the drawing board. Our conclusion was that there wasn't enough T.D.C. turbulence (squish) to propagate the flame, we increased this which also had a benefit, but not enough. The problem with squish as a flame propagator is that the spark initiates the burn some 30 degrees before T.D.C.
I had a chat with the 'inventor' Steve Scriminger. Thoroughly nice chap.Steve is actually going to give me a set for free and I am going to get a dyno comparison.
The ad is hilarious , comparing this nonsense to what f1 engines use . Yeah , it's the same , only , well , it isn't . F1 engines employ 2 spark plugs per cylinder , and on does fire just slightly before the other , all controlled by a sophisticated ECU , this guy is simply lying . Fact is , internal combustion relies on turbulence to complete burning the mixture , if I am reading his claims correctly , he is stating this reduces turbulence . What a load of horse manure . Dusty
Tom my bike gets a damn good thrashing on a reg basis but will also pootle about quite happily. It has a light flywheel so likes to rev.I take your point that if the alleged extra 10% happens only at 7800 revs it wont be much use, but I'm feeling optimistic !
Unfortunately Dusty you are wrong. See this https://youtu.be/L2Qv6wdZ9f4Funny how old fashion can be the way of the future, you can expect to see many cars runny this in the near future. Adam
I had a chat with the 'inventor' Steve Scriminger. Thoroughly nice chap.He says they have sold hundreds with no complaints including extensive racing use.Developed for BMW boxer engines which makes them very compatible with Guzzis.Steve explained that you wont notice much benefit if you just chug about at low revs as the improvement only kicks in at 4000 revs and aboveSteve is actually going to give me a set for free and I am going to get a dyno comparison.Will let you know.
I wonder how much performance I would gain with these Pulse jets + a Fish carburetor?I was thinking about my Guzzi but what about a Corvette?
Since time immoral, slick-talking hucksters
Thank you Huzo. Ok then....
I found a paper on this topic, the purpose was to allow leaner burn mixtures and still get good ignition, they didn't talk about power increases, but what they said was (paraphrasing) igniting the mixture in a small compartment was easier and then the flame propagates out into the larger cylinder. It was about using leaner mixtures. Who knows, I think some enterprising chap should buy some and do a dyno test.
