Author Topic: Shinko 705 on V7 Special?  (Read 4143 times)
Offline Toecutter
« on: January 29, 2018, 01:50:45 PM »
Time for new shoes.
Living at the end of several km of gravel, dirt and sand, so my daily commute is about 70% pavement, 30% "anything from dry packed dirt to slick-as-snot mud".
Looking at Shinko 705s. The front only comes in a 110/80, though. Anyone run it? It's only 4mm less clearance in radius, but I thought I'd ask if anyone is doing it already. Any clearance issues width or height-wise?
Thanks in advance.
Offline egschade
  • Eric - MGNOC NJ Rep - mgnocnj.forumotion.com
Re: Shinko 705 on V7 Special?
« Reply #1 on: January 30, 2018, 06:50:46 AM »
Can't speak to clearance on a V7 but my experience with them on a BMW F800GS was positive. They stuck to the road well and only felt a little buzzy at low speed. Off road they're decent until things get muddy and deep at which point you'll be wishing for knobbies anyway. The 705's appeared to be a little wider than same-size and profile street tires they replaced but I didn't measure.
The elder Eric in NJ
2024 Triumph 400X Scrambler
1971 Honda SL350
Past Guzzis:
2018 V7 III Carbon Dark
1985 LeMans 1000
2020 V85TT Adventure
V65 SP
V7 III Stone
V50
Griso 1200SE Tenni
Breva 1100
EV Touring
Offline Toecutter
« Reply #2 on: January 30, 2018, 08:13:46 AM »
Thank you.
I'm a bit leery of going from the 100/80 to a 110/80... ever since I went from a 130/80 to a 140/80 on my CB750, and wore a hole through my battery box and battery. :thumb:
I think I'm gonna go ahead though, I've burned through three sets of Sport Demons on this bike, and, quite frankly, as much as I love the tire, I can't afford to keep going this way. Plus, they suck in the dirt.
I'm so annoyed at the lack of dual-sport options in the stock V7 sizes, that I'm think about lacing the front to a 19" rim.
Offline Sheepdog
« Reply #3 on: January 30, 2018, 11:24:03 AM »
The Kenda K761 is another tire you might consider. It is affordable and long-lasting by all accounts and the tread design is similar to the Shinkos.
Offline JACoH
« Reply #4 on: January 30, 2018, 11:56:11 AM »
Not sure what year your Special is, but the specifications for my V7 III Special, says stock front tire is 100/90-18 and lists alternate as 110/80-18. So, either should be fine.
In my experience with Kenda tires, they are as good as any other brand coated in grease. Be careful in the wet and the dry, and on the tar snakes. Not worth the money saved.
Offline redhawk47
  • Traveler
« Reply #5 on: January 30, 2018, 12:33:30 PM »
Yes, the 110/80 is listed as an alternative on the V7III so it should be fine on a V7 or V7II.
However, Shinko doesn't make it in a 18.
Consider to 4.10-18 but review the speed and pressure ratings.
I have used 705s on my F800GS and my KLR and have been very pleased.
Choices are even more limited for my V7II Stone for staying with tubeless tires. I am running Avon TrailRiders with a 110/80-18 rear tire, reversed, on the front - it looks like a tractor tire and will probably last for two or three rears.
Dan
Dan
Offline Toecutter
« Reply #6 on: January 30, 2018, 02:18:32 PM »
Well... shit. I could have sworn I found it in 110/80-18, would have bet a beer on it, and of course now... I can't find it at all.
Son of a...
Tire choices for this bike suck, quite frankly.
Offline Sheepdog
« Reply #7 on: January 30, 2018, 02:54:31 PM »
According to the Shinko site, the 705 front tire is not offered in an 18" rim size. The Kenda is interchangeable front and rear and has a 110/80-18 available. They do cost a bit more than the 705s. Though it has great longevity, Dan is correct that it does not stick on pavement as well as the Shinkos. They do well on dirt, however; as long as it's not too muddy. They're H-rated, too.
http://tiresunlimited.com/ALL%20TIRES/Kenda/k761_dual_sport.htm
« Last Edit: January 30, 2018, 02:56:59 PM by Sheepdog »
Offline Sheepdog
« Reply #8 on: January 30, 2018, 03:07:14 PM »
The Avon Distancia has an 18" rear that will work if you mount it backward. The weight is within a pound of like-sized fronts and the tread pattern is similar to the Shinko 705.
http://tiresunlimited.com/ALL%20TIRES/AVON/AVON%20MC/avon_distanzia.htm
Offline lazlokovacs
« Reply #9 on: January 30, 2018, 04:14:56 PM »
currently running 120s up front on mine, no problems
Offline lazlokovacs
« Reply #10 on: January 30, 2018, 04:16:42 PM »
hang on...
you're discussing one of them modern guzzis aren't ya?
sorry, thought this was about the original V7speciale (loop frame)
as you were gents, apologies
Offline egschade
« Reply #11 on: January 30, 2018, 05:31:34 PM »
I prefer a 90/10 adv tire like the Pirelli Scorpions. You can get them in the correct size for the V7 but curiously, the front is bias ply and the rear radial. Not sure I like that mix.
1971 Honda SL350
Past Guzzis:
1985 LeMans 1000
V65 SP
V7 III Stone
V50
Griso 1200SE Tenni
Breva 1100
EV Touring
Offline JohninVT
« Reply #12 on: January 31, 2018, 04:10:23 AM »
705's are the best value in dual sport tires available.  If you're just going to cruise gravel roads 20-25% of the time and the rest on pavement they're perfect.  They won't turn your V7 into a KTM in the dirt but for gravel touring they're a very good tire.  Most people riding heavier ADV bikes get 6-7,000 out of a rear 705 so you should get excellent life on a 100lb lighter bike(with 1/3rd the hp).  They're a little loud during break in, then they quiet down for thousands of miles before getting louder again towards the end of their tread life.  They're not great in the rain but they won't scare the hell out of you either as long as you remember you're on a tire with a blocky tread pattern.
Offline redhawk47
  • Traveler
« Reply #13 on: February 03, 2018, 12:09:23 AM »
The Shinko 705 4.10-18 is a front/rear tire. Its speed rating is P = 93mph, if that is an issue.
Dan
Offline MMRanch
  • MMRanch
« Reply #14 on: February 03, 2018, 03:02:55 AM »
 Toecutter
I'm going with Avon Road Riders , I've run them on one of my other bikes and they last forever.   I use my front brake for 99% of the stopping chores and my first front one still lasted more than 30,000 miles over 5 years before I took it off due to cracking sidewalls , the tread was still 25%.   I've got one now on the back of my V-7II --- the rear Demon lasted 4,300 miles , and when the front Demon dies there will be a Road Ridder up there too.
Good luck with whatever you pick !
« Last Edit: February 03, 2018, 03:09:10 AM by MMRanch »
2016 V7-II Stone
Offline malik
« Reply #15 on: February 03, 2018, 01:59:50 PM »
I, too, am happy with the Avon Roadriders on my V7s. I've replaced 7 rears & 3 fronts now for an average of 12,000 & 35,000 miles respectively. (They actually did kilometers, but I've converted to imperial for you guys).
They seem to work OK on dirt, but I'm not a confident dirt rider, and suspect that a more appropriate tread pattern for dirt may well make a difference. Good luck.
