Author Topic: CARC ICV Bypass  (Read 2536 times)
Offline tris
CARC ICV Bypass
« on: February 05, 2018, 06:37:33 AM »
Did anyone who put a valve in the line also loose the ICV completely and fit a Tee connector, but leaving the ICV electrically connected?
My ICV is playing around and I'm trying to avoid the £300 for a new one until I've explored the other options
Cheers
1993 TW125 "POS" - Resting
Re: CARC ICV Bypass
« Reply #1 on: February 05, 2018, 07:42:14 AM »
You can do that but you need a valve to crack open a bit to let in air for it to start cold then close it off once warm.
Offline ken farr
Re: CARC ICV Bypass
« Reply #2 on: February 05, 2018, 09:49:46 AM »
Could someone explain the above for me?
Electrical connection to the Carc?
kjf
ken farr
06 B1100 - click!
Fillmore, Ca.
Online Wayne Orwig
Re: CARC ICV Bypass
« Reply #3 on: February 05, 2018, 09:55:20 AM »
CARC vintage bikes.
Idle Control Valve. (not an actual CARC thing)
Offline Bisbonian
  • Living the Dream
Re: CARC ICV Bypass
« Reply #4 on: February 05, 2018, 10:30:48 AM »
I didn't bother removing the stepper motor, I just plumbed the shutoff valve into the hose going to the airbox. The stepper itself still works, just not like I'd like it to.
I turn my valve open for cold start, then when the popping on decel begins I close the valve and am good for the rest of the day.
Offline Huzo
Re: CARC ICV Bypass
« Reply #5 on: February 05, 2018, 12:02:14 PM »
Jeez that's a pain in the arse to have to do.
Is it not possible to clean the old one ?
Pete gave me a new one  :bow: and since he and Beetle have had their grubby paws on it, the bugger runs as clean as a birds bum.
No more contamination of the stepper.
Re: CARC ICV Bypass
« Reply #6 on: February 05, 2018, 04:10:04 PM »
2007 Griso
Should I pull the stepper off and clean it while I have the tank off?
Does it come apart?
Pulled the pump out, someone has already done the metal filter thing.  :thumb:
Cleaned the ignition switch, that's no easy task.
« Last Edit: February 05, 2018, 04:11:58 PM by Kiwi_Roy »
Offline tris
Re: CARC ICV Bypass
« Reply #7 on: February 05, 2018, 04:14:45 PM »
Peter
Its had carb cleaner shot through it
The valve bit stuck in a ultrasonic cleaner and buzzed
Plus I hooked it up to a stepper controller and ran it back and forth
On the back of that little lot it appears  to work OK on the bench - except that it leaks a bit one side.
Offline tris
Re: CARC ICV Bypass
« Reply #8 on: February 05, 2018, 04:25:21 PM »
Roy
If its idling OK them probably all good
If the TBs and ICV haven't been cleaned recently though its worth doing - there's a MG Service Note that says you should but I can't remember where I found that
Tris
Re: CARC ICV Bypass
« Reply #9 on: February 05, 2018, 05:09:18 PM »
Thanks Tris,
                 No it doesn't idle that consistently although it may be better than it was (parked for a year) so I will pull it off and give it a blast while I have access.
I'll do the TBs as well I guess
The list keeps getting longer.
« Last Edit: February 05, 2018, 05:16:00 PM by Kiwi_Roy »
Offline tris
Re: CARC ICV Bypass
« Reply #10 on: February 06, 2018, 01:24:43 AM »
Strange that isn't it
One of the reasons I sold my 95 Cali was because I got fed up with fixing it.
I've had to "fix" the B11 loads more than I did the Cali - pesky electronics.
Still I had some good news the other day. The LCD on the dash suddenly burst back into life!
So it must be a dodgy connection and a good candidate for Carmo to heal - permanently
Good luck with the Griso I love my B11 when its on song and I'm sure the Griso will be as good
