Author Topic: What's the REAL break-in mileage for a Guzzi?  (Read 10995 times)
Offline mjptexas
« on: February 06, 2018, 09:07:06 PM »
My 2014 Cali 1400 Custom just turned over 22,000 miles, and, I've noticed something interesting over the last month.  Fuel consumption has improved by 2-3 mpg, and the bike seems to run smoother.  So, does that mean that at about 20,000 miles it's finally broken in?
Mike
'18 R Nine T Urban GS
'17 Griso
'16 XL1200 Roadster
'15 Monster 821
'14 Cali Custom
'14 Vespa GTS300 Super
'15 Vespa Primavera
'75 CB400F
'76 CB550F
Re: What's the REAL break-in mileage for a Guzzi?
« Reply #1 on: February 06, 2018, 09:11:33 PM »
 Yes ... or you have finally learned how to do division  :laugh:
« Reply #2 on: February 06, 2018, 10:10:43 PM »
Do they change your fuel formula in the winter?
Offline ITSec
« Reply #3 on: February 06, 2018, 10:53:21 PM »
My own experience is that larger twin cylinder engines take somewhere on the far side of 15,000 miles to finish breaking in. My DL1000 V-Strom hit its stride at about 18,000, my Norge finally got to its best at about 20,000, the Stelvio I bought used continued to improve to about that same number. Part of it is other things, like getting valve clearances and throttle body balancing just right, but these large twins just seem to take a while to reach their happy place.
ITSecurity
2013 Stelvio NTX - Copper
2008 Norge GT - Silver
I am but mad north-northwest!
Offline Sheepdog
« Reply #4 on: February 06, 2018, 11:53:49 PM »
My Vintage got noticeably smoother at 15k...and smoother still with a reflashed ECU.
« Last Edit: February 12, 2018, 09:51:32 AM by Sheepdog »
« Reply #5 on: February 07, 2018, 12:21:01 AM »
Yes, even on the big block carbed Guzzis it took at least 15K miles before the motor finally felt like it's broken in. :grin:
Offline Zoom Zoom
« Reply #6 on: February 07, 2018, 04:07:06 AM »
Yep, 20K miles give or take.
John Henry
« Last Edit: February 07, 2018, 04:55:05 AM by Zoom Zoom »
Offline molly
« Reply #7 on: February 07, 2018, 04:13:28 AM »
I've had three CARC Guzzis and after 15,000 miles they just got that bit sweeter.
Dave
Lincolnshire, U.K.
Griso 1100
Offline mjptexas
« Reply #8 on: February 07, 2018, 06:28:00 AM »
Or perhaps I finally figured out how to use the calculator on my phone  :cool:
Mike
'17 Griso
'16 XL1200 Roadster
'15 Monster 821
'14 Cali Custom
'15 Vespa Primavera
'75 CB400F
'76 CB550F
Offline mjptexas
« Reply #9 on: February 07, 2018, 06:31:18 AM »
No clue.  I live in Central Texas, so winter runs from Christmas, maybe through Valentine’s Day. Would hardly seem worth the effort.
Mike
'17 Griso
'16 XL1200 Roadster
'15 Monster 821
'14 Cali Custom
'15 Vespa Primavera
'75 CB400F
'76 CB550F
« Reply #10 on: February 07, 2018, 07:39:54 AM »
 Good , now would you teach me  :rolleyes: :laugh:
Offline ramarren
  • Not Quite Anonymous
« Reply #11 on: February 07, 2018, 09:11:30 AM »
I bought my '89 LeMans V with something like 6000 miles on the odometer in 1995. It had a lot of minor silly things wrong with it, courtesy the previous owner, but in sorting those out it was obviously a good, solid bike that hadn't been hurt at all. It didn't feel like it was fully broken in, particularly the transmission, until it turned over 15,000 miles.
My new V7III Racer was purchased in October. I had the first service done just a hair early (about 790 miles) due to travel commitments, logistics, and all that stuff. It still felt tight. About fifteen hundred miles later, the engine's tight feel disappeared over the course of about 30-40 miles and it sounded better and revs more easily; fuel mileage is up. The transmission--good from the start, really--continues to smooth out and shift better and better as the miles add up. At 1450 miles or so now, it's beginning to feel like the LeMans V transmission felt, so I look forward to another watershed in transmission smoothness up around the 12000-15000 mark.
Moto Guzzis are in it for the long haul.. :D
« Last Edit: February 07, 2018, 09:12:01 AM by ramarren »
Online sdcr
« Reply #12 on: February 07, 2018, 09:24:00 AM »
My G5 had about 77,000 and change when I sold it. I don't think it was fully broke in.
2000 BMW R1100 RS
1983 BMW R100
2009 Jaguar XK
« Reply #13 on: February 07, 2018, 09:25:44 AM »
I know this is long repeated Guzzi canon - but I still am skeptical to some extent.
I don't recall either of my big blocks changing that dramatically by 10k or 15k, I just don't.
And I generally don't believe break-in works that way, I mean jeez how much metal or swarf or whatever has to be worn away in 10k miles to achieve changes like that to the motor and chassis.
I WILL ADMIT though that the V7 felt particularly strangled/choked for the first maybe couple of thousand miles. That did break-in more then, but a difference between say 5k and 10k - nahhhhhhhh.
I think it's more likely what changed was human and perception oriented.
Offline Sheepdog
« Reply #14 on: February 07, 2018, 10:39:38 AM »
Yes, Kev...it does seem like a great many miles. I don't think that it is any one thing, but the whole bike felt smoother after 15K. In particular, shifting was better. I suppose bedding surfaces tighten up, bolts stretch (rocker arms get re-torqued every valve adjustment), and small gaps seal up. Plus, air-cooled motors require looser tolerances than liquid cooled ones due to heat expansion. They start out with a pretty tight fit, but find their happy place as the miles pile on. All that passive fitting takes time...
« Reply #15 on: February 07, 2018, 10:44:51 AM »
Well, not for nothing, but looser tolerances should mean it takes less time because there's less to wear no?
I'll remain skeptical. I just haven't felt THAT big a difference after 10k or 15k (as opposed to say 1-2k) on anything I bought new from BMW and Harley to Guzzi.
I DO think there is a little wear in on things like the tranmission/shifter pawls, any suspension bearings or bushings, and sure some internal components in the motor. But by 10k.... man it should have happened already, it REALLY should have.
But I'll likely remain alone in this... that's fine.
Offline rider33
« Reply #16 on: February 07, 2018, 10:57:53 AM »
I think it really depends on the engine, not the brand.  High tech, high compression engines like the V4 on my ST1300 were butter smooth to begin with and never really changed.  The big bore thumpers like the KLR's I've owned or the DR I now have most definatly loosened up over the first 5 or 10 thousand miles.
On a simple, low stressed air-cooled engine like the V7 I expect things will bead in much like my Bonnie did,
somewhere after 10K.  On larger, higher performance engines in the line that might take a bit more.  Guzzi's from what I can tell are old school metal,  they like to ease I to things over time.
"some journeys continue long after movement in time and space has ceased"  -Steinbeck
Offline Socalrob
« Reply #17 on: February 07, 2018, 01:37:48 PM »
I own a 8.1 liter V8 powered Chevy 3/4 ton 4wd Suburban bought new in 2001.  Think about it, each cylinder over a liter in displacement.  I swear the engine was still tight at 50,000 miles and took until 60/70K miles to feel bedded in and more free revving.  While that Suburban has never been "fast" (I think it takes a bit to get all those big pistons moving), it has a ton of torque and it takes a pretty decent trailer to be noticed even on steep hills.
Go over to BMW boxer forums.  Many folks will not switch to synthetic oil until around 12K miles for fear of not having the rings set properly.   :grin:
Online JJ
« Reply #18 on: February 07, 2018, 02:01:54 PM »
When I bought my Centuaro GT a few years ago, it had 6,500 original miles on it.  I did all the upgrades / fixes, and now it has 11,500 miles on it.  No noticeable difference, from my perspective, in engine performance / smoothness.
When I bought my three new Big Twin Harley's, 1 FLH-S  / 2 Road King's, I recall the engines did seem to run a bit "smoother" after 5,000 miles...but I think 10K-15K might be a bit of a s stretch, (IMHO), but then again, I tend to be a relatively "conservative" rider and rarely FLOG my bikes... :cool:
Offline Huzo
« Reply #19 on: February 07, 2018, 02:13:35 PM »
I think Kev makes a good point regarding our perceptions changing gradually and believing our own BS a bit..
However a friend of mine whom I hold in high regard for mechanical intuition had a long break from riding my bike.
Between about 40,000 and 50,000 he had not been on it and one day we've headed off for a ride. He owns a perfect R 1100 S and he stopped down the road and we swapped.
At the next stop he got the first word in (for once) and said, " what have you done to this thing, it feels like silk".
I'd thought it had become noticeably sweeter but dismissed it as imagination, but there probably was a change around then.
Offline Huzo
« Reply #20 on: February 07, 2018, 02:17:48 PM »
No one's alone here Kev.
I'm certain the gearbox in my Norge is getting better all the time, it shifts beautifully.
Like my Suzuki Bandit.
What do you think of the reasoning that says..
"If it's slow to wear in, it's slow to wear out".
PS. Thanks for the PM.
You're OK  :bow: :thumb:
« Reply #21 on: February 07, 2018, 02:30:06 PM »
Couldn't that just be balance? Were the TB's balanced in that time between rides?
Unless he's specifically talking about the shifter, but really, how the hell would he remember after any length of time?
« Reply #22 on: February 07, 2018, 02:32:21 PM »
You're OK  [emoji144] :thumb:
I dunno, jury is out in my mind. There are a lot of things we want to believe, but then learn they don't make sense. I'm not sure if the engineering that would support it, unless we're literally suggesting that say compression rings take 10k to wear in and another 100-200k to wear out. That doesn't makes sense to me. But I've been wrong before and will be again.
« Reply #23 on: February 07, 2018, 02:38:20 PM »
I tend to agree with you, kev.  My V7 was noticeably smoother at 7.5K than when new.
I absolutely could NOT run 5th below 3800 rpm under any reasonable riding conditions. (I could downhill for all you wiswguys!)  Now, 3800 is ok but the bike prefers 4000 and above whereas when new it was 4200-4300 as the floor.  I kept notes!
Offline Socalrob
« Reply #24 on: February 07, 2018, 03:05:56 PM »
My GSA (1200 boxer) will run like silk one day and have some vibes another.  Those days it runs like silk are great.  It is noticeable.  Could be gas, temp, air pressure, humidity, who knows, but there are those perfect days.
« Reply #25 on: February 07, 2018, 03:15:19 PM »
Good point! [emoji106]
« Reply #26 on: February 07, 2018, 03:46:52 PM »
I noticed my '14 Accord VTEC started to rev freer at about 20k miles.   It's a stick and the wife's main car, I drive it on occasion.  It seems to rev quicker and easier now.
..................a nd this has nothing to do with price of tea in china    :lipsrsealed:
« Last Edit: February 07, 2018, 03:47:51 PM by LowRyter »
Offline Huzo
« Reply #27 on: February 08, 2018, 12:35:27 AM »
Don't think I mentioned the time.
Was a pretty big trip between those two readings.
Offline Huzo
« Reply #28 on: February 08, 2018, 12:38:46 AM »
Pete did the Beetle map and TB's at around 92,000 from memory.
That REALLY made a difference...
« Reply #29 on: February 08, 2018, 01:05:38 AM »
This.
The vast majority of the 'Bedding in' is perceptual. On later bikes there are a lot more 2RS bearings in the gearbox, (And a couple in the engine.) and seal drag may be a minor contributor but this idea that modern 'air cooled' engines, especially those with Nicasil bores, (ie. most of them.) run looser tolerances is fanciful.
Especially with plain bearings the tolerances remain stuck at the 'rule of thumb' they have had for most of the last two centuries, one thou clearance for every inch of journal diameter, (Within reason.). They either work or they don't. Frictional losses in plain bearings won't change as its due to the viscous drag imparted by the wedge.
Sure they will feel 'Tighter' but most likely most of that is the owner believing what he's been told and the fact that the controls are new and may have higher friction levels promoting a feeling of 'Tightness'.
Not that any of this matters a toss. Just get on and ride the bloody thing! If it feels it's 'loosening up'? Great! If it feels no different? Also great! If it melts into a pool of molten slag? Not so great! :evil:
