Author Topic: New Muffler?  (Read 8040 times)
Offline Scott of the Sahara
New Muffler?
« on: February 14, 2018, 08:31:53 AM »
I needed to move my son's bike to his new house about 5 miles away. He has a Suzuki SV650 with a really nice after market muffler that puts out a nice exhaust sound.
I know on the Moto Guzzi Norge, people have talked about replacing the stock muffler for an after market one. It made me consider dropping about $600.00 for one. The sound is intoxicating. I am aware of dealing with the Fuel Injection also.
My Friend's Harley has aftermarket pipes and I have ridden it a couple of times. When I am on that bike I feel like the Terminator in Terminator 2.
Could be just what my bike needs.
Or not
Re: New Muffler?
« Reply #1 on: February 14, 2018, 09:11:06 AM »
 Pete would probably recommend a Mistral with the DB killer installed .
« Last Edit: February 14, 2018, 06:33:46 PM by guzzisteve »
Offline lti_57
  • Directly above the center of the Earth
Re: New Muffler?
« Reply #3 on: February 14, 2018, 02:11:40 PM »
http://staintune.com.au/
I have one of these on my 07 Norge it sounds quite nice and not loud when rolling down the road
Moto Guzzi Norge 1200 & Breva 1200
GU MS NRG 12 2006 onwards Moto Guzzi Norge 1200 Single Oval muffler Removable Restrictor Each $800
2007 Guzzi Griso
1992 BMW K75
Offline Sheepdog
Re: New Muffler?
« Reply #4 on: February 14, 2018, 02:54:54 PM »
The pair of Mistral Classics/H-pipe that I put on my Vintage put out a wonderful sound.  The bike gets better fuel mileage, runs cooler, and has more linear throttle response. If you get a freer flowing pipe, I would highly recommend an FI ECU re-flash and a TPS check at the same time. It may cost a bit more, but your bike will be transformed...
Offline menzies
Re: New Muffler?
« Reply #5 on: February 14, 2018, 05:58:05 PM »
I fitted a Staintune to a Breva 1100, it sounded nice and mellow and I never noticed any popping or any other problems associated with the mod.
2001 Triumph Bonneville
2007 Triumph Bonneville
2006 Triumph Scrambler
Offline mtwillyman
Re: New Muffler?
« Reply #6 on: February 14, 2018, 06:52:02 PM »
I have a 2008 Norge. Would the GPR muffler work with the stock fueling on my bike? I'd like a deeper sound and cooler running please. Thanks for any insight to this.
Port Ludlow,WA
2003 Stone
Re: New Muffler?
« Reply #7 on: February 14, 2018, 07:27:58 PM »
The earlier 2V Norges have the cat in the 'Collostomy bag' pre muffler don't they? In which case you can run pretty much any pipe although it'll be better with the dB killer in.
With the 8V's they will always run better with a dB killer in and will run significantly worse with the killer out, especially if you stick with the original CL map.
Offline flip
Re: New Muffler?
« Reply #8 on: February 15, 2018, 12:19:49 PM »
I have a Staintune on my Breva 1100 also. Without the db killer it is a little louder than I like but it isn't bad. It does have a nice tone.
North Carolina
Offline JeffOlson
Re: New Muffler?
« Reply #9 on: February 15, 2018, 01:06:52 PM »
I have had two Norges (both 8V 2014 models). On each of them, the stock muffler opened up noticeably with enough time and miles and eventually sounded much better than when new. However, the sound is not what I would describe as "glorious."
On my first Norge (the one a speeding school teacher rear-ended), I eventually put on an Agostini (before she rear-ended me). On my current Norge, I have recently installed a Mistral. Both cans look nice and weigh significantly less than stock. Both sound better than stock, with or without DB killers.
Currently, I am running the Mistral with the DB killer installed. It sounds really good and is probably a little (a very little) louder than stock. Both the Agostini and the Mistral sound glorious with the DB killer removed, but as Pete has said, your performance may suffer a bit. (I have not noticed a difference in performance, with or without the DB killer in either the Agostini or the Mistral, but I am not allowed to ride "freely" in America like our friends down under; idling in bumper-to-bumper traffic, I have not noticed any difference in performance.)
2018 Vespa GTS 300
2016 Moto Guzzi Norge
2015 Vespa Sprint 150
2015 Vespa GTS 300
Re: New Muffler?
« Reply #10 on: February 19, 2018, 06:01:24 PM »
I am somewhat confused. Would I need a Fuel Injection update on my '08 Norge if I installed an aftermarket Muffler???
Re: New Muffler?
« Reply #11 on: February 19, 2018, 06:21:08 PM »
No, many run fine, but you can get them to run better yet. Yours should have the latest factory in it.
Offline nobleswood
Re: New Muffler?
« Reply #12 on: February 19, 2018, 09:35:10 PM »
JeffOlsen,
I'm thinking about changing the muffler on my 2013 Griso 8v 1200 & have narrowed it down to an Agostini or a Mistral. While there is a price difference between them what's your opinion about how they compare as you've had both of them ?
A friend of mine has some Agostini pipes on a V7 racer & loves the sound, consequently he is dismissive of the Mistral. What's your 2 cents ?
Cheers
2013 1200 8v Griso
Offline JeffOlson
Re: New Muffler?
« Reply #13 on: February 20, 2018, 12:31:29 AM »
^ I think they both sound great, especially with the DB killer removed. Perhaps the Agostini has a slightly better sound to my tin ear, but tone is very subjective. Some people like creamy, smooth overdrive; others prefer Velcro-like fuzz.
One thing I did not like about the Agostini: for the Norge, it is suspended by a thin metal strap with a large rubber band between the strap and the body of the muffler acting, apparently, like a shock absorber. The Mistral, on the other hand, has a solid metal arm riveted to the muffler, which seems like a much more secure way to mount the muffler. (For the Griso, I do not know how each one is suspended.)
2018 Vespa GTS 300
2015 Vespa GTS 300
Re: New Muffler?
« Reply #14 on: February 20, 2018, 06:02:39 PM »
do you run it with or without the db killer? do you have any pinging in hot weather?
Offline menzies
Re: New Muffler?
« Reply #15 on: February 20, 2018, 07:01:09 PM »
I ran with the db killer and no pinging.
Re: New Muffler?
« Reply #16 on: February 21, 2018, 12:37:16 AM »
Or not
My Norge has a Staintune.
400 mm versus standard 500 mm offering.
No dB killer, but I'm reliably informed it'd go better with it in.
Don't give a rat's though, it goes like the clappers as it is !
« Last Edit: February 21, 2018, 12:48:54 AM by Huzo »
Re: New Muffler?
« Reply #17 on: February 21, 2018, 12:47:14 AM »
Talk to Beetle !
End of story.... :bow: :thumb:
Offline dl.allen
Re: New Muffler?
« Reply #18 on: February 21, 2018, 08:21:26 PM »
Yep
GPR can with beetle map
2012 8 v Norge
Def had to leave db killer in.
Love it
Re: New Muffler?
« Reply #19 on: February 21, 2018, 08:53:14 PM »
Mine (as you know) Pete, is an '07 2 VPC.
I think it's in the original muffler, 'cos when I ditched it for the Staintune, there was/is no cat evident on the remaining system and the original muffler weighs a metric tonne !
beetle
Re: New Muffler?
« Reply #20 on: February 22, 2018, 04:54:00 AM »
The 2V Norge had the cat in the muffler. The 8V has the colostomy box twist it's nethers.
Offline Fnq1000
Re: New Muffler?
« Reply #21 on: February 22, 2018, 05:08:04 AM »
Huzo
Spoke wheels on a Norge - NICE
Staintune shows up the rear wheel nicely. However Do you run standard panniers with that muffler?
Cheers
Jason
Re: New Muffler?
« Reply #22 on: February 22, 2018, 05:20:32 AM »
Huzo
Cheers
Jason
Yes, but I took a scoop out of the pannier to clear the muffler.
Also.
FNQ= Far North Queensland ?
« Last Edit: February 22, 2018, 05:23:48 AM by Huzo »
Offline Fnq1000
Re: New Muffler?
« Reply #23 on: February 22, 2018, 02:33:07 PM »
Huzo
Thanks - FNQ, you are correct and that is where my heart is, but physically and temporarily SEQ based
Cheers
Re: New Muffler?
« Reply #24 on: February 22, 2018, 04:28:19 PM »
Might be up there soon
Re: New Muffler?
« Reply #25 on: February 23, 2018, 10:09:31 AM »
Talk to Beetle !
I wish! But I don't have a computer that will run guzzi diag and even if I did, I'm not tech literate enough to mess with that stuff :-(  It's too complicated
Offline bettythebear
Re: New Muffler?
« Reply #26 on: February 23, 2018, 10:37:12 AM »
I really want to be one of the Mistral ones. I like those because I don't want to pay $600 and have to stare at a strap holding it on. like the Agostini's I've seen.
2011 v7 Classic
Re: New Muffler?
« Reply #27 on: February 23, 2018, 01:21:49 PM »
Yeah Barbie.
If I didn't live as close to Pete as I do, I'd be in the same boat!
Is there no one around that can load the map and do a TB balance etc..?
Re: New Muffler?
« Reply #28 on: February 23, 2018, 03:22:22 PM »
I'll be over in August. You want me to load you up a map? I work for beer!:D
Re: New Muffler?
« Reply #29 on: February 23, 2018, 07:23:13 PM »
Mate, that's an offer from heaven..
Just say yes !!!!!!
Will you have your box of tricks with you Pete ?
