Author Topic: 1380 CC 8v motor kits? Magical exhausts? 8v Grisos w/o oil coolers?  (Read 8922 times)
Re: 1380 CC 8v motor kits? Magical exhausts? 8v Grisos w/o oil coolers?
« Reply #30 on: March 14, 2018, 06:07:50 PM »
If he doesn't balance the crank then he must be skimming weight off pistons if he uses the same rods.
Pics of a supercharger on the other forum.
Offline pauldaytona
    • Paul's fast Guzzi Page
« Reply #31 on: March 14, 2018, 06:20:32 PM »
 I know Pete looked into that and found it not the way to do it.
Paul
Daytona 1225, Stelvio 1151
« Reply #32 on: March 14, 2018, 06:22:51 PM »
There is a 37g difference in weight between the 1200 and 1400 pistons. Unless you rebalance the crank it will sap power and make the engine vibrate like a cheap sex aid. IMHO there is no way to remove 37g of metal safely from the pistons.
I can guess what they've done to the barrels, it's why the pic shows them upside down. If they are using some different camshafts and valve springs plus a fair bit of head work they can probably drag a bit more out of 1400cc's but I still disbelieve 140, apart from anything else because of the other componentry used in the bike.
Offline pauldaytona
« Reply #33 on: March 14, 2018, 06:29:26 PM »
 This was a swap in one day, just cilindrs pistons, no head work.
top view
Paul
beetle
« Reply #34 on: March 14, 2018, 08:10:27 PM »
Only changes are the barrels and pistons? And they use stock parts? Rubbish! It would vibrate itself to bits. No other changes? No head work? No fancy cams? 140HP & 148Nm (109 ft-lbs)? Complete  Rubbish!
Online LowRyter
« Reply #35 on: March 14, 2018, 08:21:51 PM »
You'll have to provide the crow  :laugh:
 Is that 140 NM at peak , W/O doing the math , isn't that about 102 HP at 8K RPM's ?
I'll take the catfish.  And those Delrod dogs smothered in onions.
« Last Edit: March 14, 2018, 08:22:14 PM by LowRyter »
« Reply #36 on: March 14, 2018, 09:08:48 PM »
top view
Well Paul, if that is all they've done I'd run a bloody mile! The cooling circuit is now blocked. The cooling oil will be venting straight into the timing chest through the OPRV. Used in anger, or even mild annoyance for any length of time I'd expect a spectacular valve or head casting/seat failure.
Offline Huzo
« Reply #37 on: March 15, 2018, 01:45:37 AM »
Just to clarify..
By "vibrate like a cheap sex aid" are we to assume not at all, or to the point of discomfort...
(Unaccustomed as I am of course.... :embarrassed: :drool:)
Offline Huzo
« Reply #38 on: March 15, 2018, 02:00:22 AM »
It all becomes a bit hard to swallow if you apply the numbers claimed.
<br /
140 Nm x 8,000/9.5488= 117,292 Watts
Or
117.292 KW/0.746 = 157 Hp.....
Now of course if that peak torque was claimed @ 6,000 RPM, then the peak power comes to 117 odd Hp.
« Last Edit: March 15, 2018, 02:10:59 AM by Huzo »
Offline pauldaytona
« Reply #39 on: March 15, 2018, 03:41:14 AM »
Pete something has been done for the oil return.
Paul
« Reply #40 on: March 15, 2018, 04:08:20 AM »
Thank you!
The output figures are still pure bullshit.
