Author Topic: 1380 CC 8v motor kits? Magical exhausts? 8v Grisos w/o oil coolers?  (Read 8828 times)
Offline Kristian
A US vendor sells a 1,380 cc "drop-in" kit for Griso 8vs; somehow, this doesn't strike me as a good idea.
They also sell super-short dual exhausts for Grisos, and suggest eliminating the oil cooler to make it fit. That strikes me as a really bad idea; you know, 4-v heads, air-cooling, big power, and all that. And, shorty exhausts for street use wouldn't really be optimal, or so I thought.
Finally, the same vendor claims that 110+ WHP is easily available on Griso 8Vs with exhaust & FI tuning). I have scrubbed the net for a Dynojet test sheet showing this, but cannot find it. The vendor doesn't show dyno charts.
Has anyone here ever gotten 110+ WHP out of their 8v Griso from easy mods?
What's going on with this vendor?
Ta-
« Last Edit: March 12, 2018, 10:42:42 PM by Kristian »
beetle
Re: 1380 CC 8v motor kits? Magical exhausts? 8v Grisos w/o oil coolers?
« Reply #1 on: March 12, 2018, 07:12:10 PM »
What does the 'drop in' kit entail? Guzzi OEM barrels and pistons and crank, or aftermarket?
Shorty exhaust does nothing good. For maximum torque on the street, you need a 2 into 1 with a long pipe.
No oil cooler is a disaster waiting to happen. Don't do it.
« Reply #2 on: March 12, 2018, 07:13:14 PM »
 Yes , don't do it .
Online LowRyter
« Reply #3 on: March 12, 2018, 08:42:37 PM »
Mr Google took me to Guzzi Tech.
http://www.guzzitech.com/store/product/gt-1380-big-bore-pistons-cylinders/
110 HP sounds achievable.
« Reply #4 on: March 12, 2018, 08:48:55 PM »
 Except the 1400 Griso that Pete and Mark built with proper mapping and exhaust isn't making but about 100 HP . Maybe this thing is making 110 HP , but I'll bet the torque curve looks like a side shot of MT Everest .
 Edit . Removing the oil cooler after increasing the displacement by 200 CC's is just asking for trouble .
« Last Edit: March 12, 2018, 08:51:10 PM by oldbike54 »
Offline Turin
« Reply #5 on: March 12, 2018, 08:58:22 PM »
Couldn't you just include a couple of brackets and some longer hoses to relocate the oil cooler with this kit? ?  Wouldn't be a bad idea.
1985 Sidlow Guzzi
« Reply #6 on: March 12, 2018, 09:05:27 PM »
 That would require some real engineering .
« Reply #7 on: March 12, 2018, 09:16:46 PM »
You might be able to get an honest 110 at th rear wheel but only by sacrificing drivability. You certainly won't get it with individual short pipes but if all you're interested in is suckering the rubes you can probably flog a few based on bullshit.
beetle
« Reply #8 on: March 12, 2018, 09:45:05 PM »
With a feeling of dread, I clicked on the link. It's not really a 'drop in' kit. You have to get your crank rebalanced. No mention of any other work. Curious.
Couldn't find any shorty twin exhaust that required oil cooler removal. Oil cooler relocation kits are available. I've seen them done. Rossopurro or some such. One exhaust description did make me giggle. "Mandatory GT ECU reflash required."
110 RWHP may be possible on a good day. Under the right conditions. But as Dusty says, it'd be peaky. Shite to ride, I imagine.
Offline groundhog105
« Reply #9 on: March 12, 2018, 11:09:34 PM »
I see nothing in the GuzziTech add that claims 110 whp or relocating or removing the oil cooler.  Also not really �drop in� when rebalance is required.   I would certainly think 110 whp is very possible when Todd is getting 95 plus whp out of the single throttle body 1400s.  Archived by using a full exhaust system, opened air box, PC5 with auto tune.  My 1400 California has these changes and pulls extremely hard for a large cruiser.
Online LowRyter
« Reply #10 on: March 12, 2018, 11:13:18 PM »
that 1400 has a flat torque curve.  110 hp seems pretty achievable without affecting rideability.
« Reply #11 on: March 12, 2018, 11:18:36 PM »
John? How much experimentation have you done with the 8V motor and how well do you know it's architecture? It is NOT an engine that is easy to magic power out of due to its design. Unfortunately people make comparisons with other twins of the same capacity and just assume that the same figures will be achievable out of the 8V. They are wrong. How do we know? Hard work and honesty.
(Shrug.)
Online LowRyter
« Reply #12 on: March 12, 2018, 11:25:05 PM »
none. Pete.
none what so ever.  I can't even change the timing cover gasket on my Sport.
my comments were trolled against making the engine peaky.
But hell, the V11 makes 123 hp.  :wink:
« Last Edit: March 12, 2018, 11:26:56 PM by LowRyter »
« Reply #13 on: March 13, 2018, 12:46:33 AM »
On the subject of oil cooler removal there are several reasons I would councel against it. Although overall the 8V is grossly over-cooled the cooling circuit, which is fed through the cooler, then delivers oil to the cooling galleries around the exhaust valves. This is the very hottest part of the motor and that oil flow is vital to remove heat from the valve seats and by extension the valves. The only way valves can dump heat is through their seats when they are closed and through the stem/guide interface. Too little cooling, which might be caused by insufficient oil flow or insufficient temperature differential betwixt valve head and seat could lead to weakening of the valve stem and loss of a valve head.
Is that likely? Who knows? But the oil galleries were put there for a reason so common sense dictates that overheating of the valves was foreseen as a possibility.
Offline LBC Tenni
« Reply #14 on: March 13, 2018, 01:22:27 AM »
My 2014 Norge was “tuned” by this “vendor” for the original owner. It was a stinking, over-fueled mess. The guy was so frustrated by the experience and this “expert” telling him it was as good as it gets, he sold the bike to me for about half what he paid new. Poor bastard. I removed the PCV, loaded Mark’s map, and it is now a complete joy. I would run far and fast from any of his offerings that go beyond the very simple bolt-ons.
2011 GRiSO SE8V Tenni
« Reply #15 on: March 13, 2018, 01:34:44 AM »
Bullshit free, accurate, (Compared to other runs.) dyno chart from a tool that gets seemingly realistic figures from other machines. The dip at the top is caused by the PCV Mark was using as a storage device for a more economical map. Removing the PCV screwed up the fueling again I believe indicating that even when it wasn't active it was having an impact.
I'm sure if he wishes too he can explain more fully.
As we stated before we even started down this road we were't expecting a big boost in 'Power'. What we wanted to see was big, fat, torque. That's exactly what we got. It's a hoot to ride, 10-12 ft/lbs more torque and the 'Curve' is flat from nothing to the rev limiter. The engine is also quiet enough not to annoy people and outwardly indistinguishable from any other single spark 8V.
The bike? Not so much.
It's the one in the middle.
« Last Edit: March 13, 2018, 03:50:47 AM by pete roper »
beetle
« Reply #16 on: March 13, 2018, 02:08:00 AM »
I tossed the Power Commander. The PC-V loads down the TPS to such extent that the ECU can't read it correctly. You can add some resistance between the TPS and PC to reduce the affect. I had 30K or additional resistance to get it to function, but it still wasn't right. When it started breaking down under load, I removed it.
I'm still tweaking the map. I'll remove the dip at 4000 RPM, and I fully expect to crack 100 RWHP.
« Last Edit: March 13, 2018, 02:08:33 AM by beetle »
Online LowRyter
« Reply #17 on: March 13, 2018, 11:34:56 AM »
just curious why no thermostat on the oil cooler?  None available aftermarket?
I know a fellow that had a Stelvio and said there was usually mayonnaise in it whenever he serviced it.
Offline mojohand
« Reply #18 on: March 13, 2018, 11:49:55 AM »
I would buy a Griso again if it had ABS and a better oil pressure sensor. More HP was never a problem to me when I had one.
Ahhh, Nera was such a great bike...
Richmond, VA, USA
2020 BMW R1250RS
Previous: 2000 Jackal, 04 Breva 750, 06 Breva 1100, 07 Norge, 09 Griso, 12 Norge, 14 FJR, 14 Striple, 16 SpeedTriple, 18 KTM Super Adventure S
Offline Kristian
« Reply #19 on: March 13, 2018, 12:00:01 PM »
Right here: https://www.cycleworld.com/2013/07/09/2013-moto-guzzi-griso-8v-se-black-devil-riding-impression
Look up new Griso exhaust re removing oil cooler.
Offline Kristian
« Reply #20 on: March 13, 2018, 12:04:46 PM »
That is a **monster** torque curve!
Offline JohninVT
« Reply #21 on: March 13, 2018, 01:19:12 PM »
Ta-
Todd is the Billy Mays of Guzzidom.
« Reply #22 on: March 13, 2018, 03:25:44 PM »
Thanks. That's what we were aiming for. The engine work required a little bit of ingenuity but the hard yards are all down to Mark. I'd be very interested to see what sort of figures might be achievable with a 'Thumb on the scales' dyno like they seem to specialise in in So-Cal!  :grin: or I suppose we could just pull any old numbers out of our arses! Seems like lots of people are willing to believe anything if it's what they want to hear.......
« Reply #23 on: March 13, 2018, 04:02:18 PM »
No, there are aftermarket thermostats available, I actually bought one and was going to fit it to mine but due to mounting considerations I stuck it in the 'Too hard' basket.
It needs to be a bypass thermostat as well. One that still allows full flow through the system and just bypasses the cooler. You can't just dump the oil back in the sump without sending it through the cooling circuit as is done on V11's and earlier CARC 2V machines. The oil flow through the cooling circuit is required. For that reason the alternative of just blocking off the cooler during cold weather, although less elegant, is a lot simpler as a ruse to warm the oil up. Having said that the roller engines don't seem to mind cold oil particularly.......
Offline pauldaytona
    • Paul's fast Guzzi Page
« Reply #24 on: March 14, 2018, 04:29:47 PM »
Well the guys from Radical guzzi in germany, you sure have seen their 4 valve engines in tonti frames, do conversions too.  they use only cilinders and pistons of the 1400 cali, no balancing, and claim it is all ok. then do a dyno and this is their figure, believe it or not, the customer with his griso is happy. They tell that they use stock parts but have some secrets to get the mix good.   :violent1::
« Last Edit: March 14, 2018, 04:35:38 PM by pauldaytona »
Paul
Daytona 1225, Stelvio 1151
« Reply #25 on: March 14, 2018, 04:33:41 PM »
No, I don't. Neither do I believe you can stick that sort of power safely through a helically cut five speed, twin plate clutch and Tonti bevelbox.
Online LowRyter
« Reply #26 on: March 14, 2018, 04:34:25 PM »
wow,  that power curve looks like Mt Everest.
Looks like Dusty will feed me crow at Cedar Vale instead of catfish.
« Reply #27 on: March 14, 2018, 05:02:40 PM »
 You'll have to provide the crow  :laugh:
 Is that 140 NM at peak , W/O doing the math , isn't that about 102 HP at 8K RPM's ?
Offline pauldaytona
« Reply #28 on: March 14, 2018, 05:06:17 PM »
At the bottom are the numbers.
Paul
« Reply #29 on: March 14, 2018, 05:15:25 PM »
 So 104 KW = about 140 HP ? :shocked: Man Paul , I am having a hard time believing it would hold together or be very streetable .
