Author Topic: smaller battery for t3?  (Read 2343 times)
Offline yackee
« on: March 16, 2018, 09:06:23 AM »
The  battery in my t-3 died (after just 2 years, sadly). My local wal-mart used to sell 300 CCA/375 CA  lawn tractor batteries that would *just* fit into the bike, and those worked fine, but the local was-mart doesn't carry them anymore. I'm planning on running out to the local Honda etc. shop today to see what they have, and was wondering if anyone had any advice/recommendations on what to look for as an appropriate (and perhaps smaller!) replacement. A friend recommended I look at "gel" batteries, but I am pretty clueless about this stuff.
Any thoughts on what I should look for? Do I just need to try to match the cold cranking amps, or are there other factors I need to worry about? I anticipate that the Honda parts guy will clam up as soon as I tell him it's for an old Moto Guzzi.
Jason
Re: smaller battery for t3?
« Reply #1 on: March 16, 2018, 10:20:17 AM »
Highly recommend the Oddessy battery mentioned in the other battery thread. Expensive but with very long life. Do you have a batteries plus in your town?
Curious why your old battery lasted only two years, do you by chance have a tender plugged in all the time? Don’t do that.
Offline acogoff
« Reply #2 on: March 16, 2018, 10:23:32 AM »
     For me the Odyssey 680 works well. Requires a bit of shimming. The first one went 8 years before I could tell it was loosing some capacity. I passed it on to the neighbor kid for use in his atv.
Marshall County Minnesota USA
« Reply #3 on: March 16, 2018, 10:50:34 AM »
Jason
Low end replacement: a sealed riding mower battery (group U1) from NAPA, Advance, Autozone, etc. costs around $60. I wouldn't recommend any that vents through the caps.
https://www.napaonline.com/en/p/NBP8227
Mid-range: ETX30L/YIX30L/MTX30L AGM battery meant originally for '97-'15 Harley FL/FLH touring bikes. Should be available at Advance Auto, Autozone, etc. and any battery retailer. This what I use in my '76 Convert and install in nearly all customer's Guzzis.
https://www.batterymart.com/p-mtx-30l-mega-crank-30l-battery.html
https://www.batterymart.com/p-Big-Crank-ETX30L-Battery.html
Offline Diploman
« Reply #4 on: March 16, 2018, 11:27:12 AM »
If you are looking for a "smaller" battery for your T3, I suggest you consider a Lithium Ion battery from AntiGravity's "small case" series.  These batteries are extremely compact and lightweight compared to traditional lead acid batteries, but pack greater energy density for their size.  I replaced a Yuasa in my V50 with an Antigravity 8-cell of about equal power (240 CCA) and saved about eight pounds and considerable space.  For a T3 you might want to consider AntiGravity's  12-cell Small Case at 360 CCA.  Lithium batteries are very durable if cared for properly and will hold a charge far longer than lead acid.   They represent a real technological advance over the traditional lead acid batteries which, even in their "gel" versions, are much the same as 50 years ago.
Downsides of Lithium batteries:
-- Expensive compared to lead acid
-- Need a dedicated, bespoke charger
-- In cold weather need a brief warm-up routine (eg, headlight on) to reach full CCA prior to starting.
If you are willing to make an initial investment, I believe a Lithium battery is worth it and perhaps even more economical than lead acid in the long run, in addition to the weight, size and durability advantages.
https://shop.antigravitybatteries.com/productline/starter-batteries/small-case/
« Last Edit: March 16, 2018, 11:28:23 AM by Diploman »
2015 KTM 390 Duke
Offline yackee
« Reply #5 on: March 16, 2018, 01:44:49 PM »
These are good suggestions, thanks. Given the price of the lithiums, I'll look for the ETX30L types...I wouldn't have known about those without your help.
I am not sure why the last lawn tractor battery died so quickly. I think it might be because I left the bike sitting for six months when I was overseas. In the past they seemed to last 4 years or so. I don't do the trickle-charger thing. Usually just charge them up at the beginning of the season.
Offline jacksonracingcomau
« Reply #6 on: March 17, 2018, 02:09:18 AM »
I use ytz 14 or generic thereof, no issues,last for many years (10 was best )
Not lithium, cheap and give you loads of room, save weight
On my uk bike have motobatt ytx 16, a bit bigger but still half orig
Both lay flat, terminals at front
Only need a battery to start, these cover that always, both sealed, no spill
If you want to play music, light the campsite or run things beyond charging output etc maybe need more
