Author Topic: How to take fuel pump out of 1200 Sport gas tank?  (Read 3017 times)
Offline willowstreetguzziguy
« on: March 30, 2018, 03:48:00 PM »
I  am replacing the fuel filter on my 1200 Sport. I have the tank off and upside down. Took out the 6 bolts that hold it in. I can grab it and wiggle it around. How do I remove the whole thing?
2008 Guzzi 1200 Sport
Re: How to take fuel pump out of 1200 Sport gas tank?
« Reply #1 on: March 30, 2018, 03:50:44 PM »
If it's anything like the Norge, you have to turn and manipulate it out...just take your time and don't force it but there is a magic combo of twist and turn that brings it right out... :cool:
Offline Kiwi Dave
    • Guzzi Gander Ltd
« Reply #2 on: March 30, 2018, 03:54:19 PM »
Make the hole about 20% larger.  Putting it back in may be a problem, however!
Seriously, it got in there, so must be able to come out.  In the past, I've slipped the filter off the cable tie so it becomes a separate entity, and it you can't wriggle it out of there, you might want to consider cutting this tie and replacing it.
Why Guzzi had to make it so tight, I've often wondered.
Good luck!
« Reply #3 on: March 30, 2018, 04:53:41 PM »
I've only had mine out 2x (or maybe it was once on the Sport, once on the Griso.  Same/same.)  I don't remember it being horribly difficult.  But at my age, everything in the past is viewed thru rose colored glasses!  Be patient and gentle.  It will come out.
Bob
« Reply #4 on: March 30, 2018, 04:56:24 PM »
To remove it's like , strait, twist, roll around corner, twist, strait.
« Reply #5 on: March 30, 2018, 05:10:39 PM »
Thanks, I got it out.
« Reply #6 on: March 30, 2018, 05:48:26 PM »
Did you get the info off this forum re the Oetiger clamps and cheap tool to install them?
Offline Darren Williams
  • Finally got me a Griso!
« Reply #7 on: April 01, 2018, 07:53:37 AM »
And what did your filter look like???   :evil:   :Beating_A_Dead_Hors e_by_liviu
« Reply #8 on: April 01, 2018, 08:37:33 AM »
It was bulging. I’ll post a picture later today
« Reply #9 on: April 01, 2018, 09:21:11 AM »
Here's the bulging fuel filter I took out. It lasted 10 years, time to retire it. Installed the Wix 33032 fuel filter that I picked up, not at an auto parts store (none of them had them) but at the local Ace hardware store. . .
photo website hosting
Offline Scott of the Sahara
« Reply #10 on: April 01, 2018, 09:28:31 AM »
Make sure you have the hoses clamped tight.! And if you ruin the hose to the filter, make sure you get submersible hose to replace it. Not a job I will ever do again.
« Reply #11 on: April 01, 2018, 10:35:15 AM »
They all bulge and seem to soften a bit, but how well the plastic part stays crimped in the metal is the key to whether they fail or not. Mine didn't stay crimped, others have and lasted a long time.
« Reply #12 on: April 01, 2018, 12:18:28 PM »
You should use Oetiker clamps on the fuel lines...
« Reply #13 on: April 01, 2018, 02:27:32 PM »
YES I did.
