Author Topic: NGC Winchester rifle question NGC  (Read 2512 times)
« on: April 07, 2018, 08:49:26 PM »
Just looking over my old 30/30 and notice the rear site elevator is missing.. I found one on line ($10) but the question is, does it fit just by capture under the buckhorn sight?   can it be installed with out removing the sight? or how is the sight removed?
#61
Re: NGC Winchester rifle question NGC
« Reply #1 on: April 07, 2018, 11:00:06 PM »
The ramp lives in a dovetailed lug.  Drift it out sideways, insert the elevator and drift it back in so it is centered on the barrel.
Offline Gliderjohn
« Reply #2 on: April 08, 2018, 12:49:07 AM »
On most of my rifles you just had to carefully lift up the rear site and slide the elevator in place. The elevator is held in place by the sight.
Back in central KS
Offline balvenie
« Reply #3 on: April 08, 2018, 12:54:52 AM »
The elevator is held against the barrel by the spring tension of the ramp. Has the ramp lost its tension, for the part to go missing? Will it hold a new part in place?
When I used to work on my open sight rifles, The whole rifle was secured by its barrel in front of the fore end, in a padded vice. Using thumb and fore finger, it is easy to lift the ramp by the buckhorn. The elevator can be slid out rearwards but you might need a circular motion at the same time.
You can make an elevator out of sheet or flat-stock, aluminium but it's labour intensive.
Oz
04 Cali
Offline SmokinJoe
« Reply #4 on: April 08, 2018, 11:32:19 AM »
Gently lift the sight in a way that doesn't scratch anything and slide in the ramp. From the picture you have sufficient tension. The ramps are normally lost in soft cases or rifle racks when bumped.
« Reply #5 on: April 08, 2018, 01:44:58 PM »
I didn't suggest simply lifting the ramp and sliding the elevator under it because if it fell out due to a lack of spring tension, lifting the ramp enough to get the elevator into place could make the problem worse.
« Reply #6 on: April 08, 2018, 03:30:01 PM »
the sight has plenty of tension.. I'll let you know how it wenr when the part arrives. thanks all!
Offline JoeB
« Reply #7 on: April 08, 2018, 07:17:48 PM »
If you need to remove the rear sight it was fitted in the dovetail slot right to left, so drift out left to right.
« Last Edit: April 08, 2018, 07:21:19 PM by JoeB »
Offline sidecarnutz
« Reply #8 on: April 08, 2018, 08:27:22 PM »
I made one some years back by cutting a wedge of thick sheet metal and then filing notches in it. Cold blued it after deburring. My Marlin lever rifle didn't care where it was made. Took it to a 25 yard range and sighted it in!
2002 Kawasaki ZR7S
« Reply #9 on: April 09, 2018, 04:19:52 PM »
Good info. Pay attention.  :smiley:
Offline mjptexas
« Reply #10 on: April 10, 2018, 09:21:53 AM »
This is what I would do.  I have bought a couple of rifles with missing elevators and have replaced them using this method.
However, I do not recall ever losing the elevator on any of the rifles I owned.  Always assumed the previous owner removed it for some reason.
Mike
'18 R Nine T Urban GS
'17 Griso
'16 XL1200 Roadster
'15 Monster 821
'14 Cali Custom
'14 Vespa GTS300 Super
'15 Vespa Primavera
'75 CB400F
'76 CB550F
Offline not-fishing
« Reply #11 on: April 10, 2018, 05:05:12 PM »
Yeah the old "I'm hitting over the target so I have to lower the sights" modification rather than using "Kentucky windage"
With my Swiss k31 I aim 1 foot lower and about 3 feet to the left at 300 yds (with my reloads)
Griso 1100
Rosso Corsa Lemans
1/2 a V50 III (with my son)
