Author Topic: Vibration free handlebars - cheap guzzi content  (Read 3031 times)
Offline lazlokovacs
« on: April 12, 2018, 08:36:16 AM »
Since her rebuild, my lemans V has been something of a paintshaker, which I'm putting down to her needing a good 10,000miles of running in...
Researching anti-vibration products on the internet I was underwhelmed...
So I got me 380mm of 5/16 old fuel hose and a bunch of shredded ping pong ball debris drifted good and tight into the hose (its a frustrating thing to do, thus free meditation mindfulness practice :laugh:) ....then a self tapper, a couple of washers and some used clutch cable inners, a whole load of grease, and my 'snakes' pulled right through the clip-ons.
Also whacked on some extra heavy bar weights from aprilia AP8104572 (tenner each)
which necessitated purchasing a couple of M6 x 120 bolts.... which I got for free in exchange for carrying a few boxes of screws into the store for the owner who had a bad back.
End result, massively reduced vibration in my clip-ons.
 :wink:
dunno if it was my DIY 'snakes' or the extra couple of pounds the bar-ends gave me (the lemans ones were pretty heavy too)
very pleased
YMMV
Does this qualify for Cheap Guzzi Content?
Re: Vibration free handlebars - cheap guzzi content
« Reply #1 on: April 12, 2018, 08:38:50 AM »
 It qualifies  :bow: :grin:
Offline tris
« Reply #2 on: April 12, 2018, 08:51:55 AM »
On occasion when we have a particularly recalcitrant machine we balance it using Densalloy balance weights - https://www.azom.com/article.aspx?ArticleID=9537
Given that Densalloy roughly twice as dense as steel we can get twice the weight for the same volume
Might be an option for some people - though I'm sure the rubber snakes are much MUCH cheaper  :thumb:
1993 TW125 "POS" - Resting
Offline Jurgen
« Reply #3 on: April 12, 2018, 06:20:19 PM »
I've got some vibration problems also, and am wondering about the function of the ping pong ball debris stuffed into the fuel hose.  Seems very light to dampen vibration.  The bar weights I can understand. How does this work?
Jurgen
Jurgen
Offline lucian
« Reply #4 on: April 12, 2018, 06:35:48 PM »
I roll up pieces of  lead flashing until it fits snugly inside the bar ends. Available at any lumber yard or home center and works great. I know others have used lead shot but with the rolled lead you don't need to fill the whole bar length. My Tuono had an annoying high frequency vibe that the lead eliminated.
Offline lazlokovacs
« Reply #5 on: April 13, 2018, 02:02:20 PM »
Jurgen
Jurgen
My testing was only marginally scientific
Ding a clip on with something soft-ish eg. a brass drift
it makes a big noise, so a lot of reverberation is happening....
Stuff a clip-on (that is unattached to the bike) with a fuel hose and ding it again
it makes a softer noise than before
Cram, and I mean cram, the inside of the hose with shards of cut up ping ping ball (match quality)
and ding the bar again,
quieter still....
I guess you are creating surface area and lots of little chambers for the vibration waves to bounce off?
lead shot, fishing weights and flashing etc all sound plausible too
Rough Edge racing
« Reply #6 on: April 13, 2018, 02:31:38 PM »
 In my opinion,If you have an engine that was smooth, then it gets rebuilt  and vibrates noticeably more....Something is different inside, like the balance factor.Or the tuning is off key....I have rebuilt many engines as an hobbyist and nothing is smoother than a fresh engine...
Offline lazlokovacs
« Reply #7 on: April 13, 2018, 02:41:48 PM »
yep,
you could well be right........... and thanks for the input
Rueing my decision not to balance crank while it was out
Not that it was silky smooth before I roasted the shells......
Best to keep the old clip-ons as vibration free as possible and keep riding
Have a spare 1100 engine that's getting a bloody good blueprinting soon, could well find it's way into the lemans in the future
Offline Roebling3
« Reply #8 on: April 13, 2018, 02:42:52 PM »
Next time I'll try foam rods; for another data point. Seems as though, from your suggestion, that should work.. . .although I'm doubtful. There's a physical & a sound component working there. I have 1# on each side of my V7 Racer w/ Legnano bars. The vibration is no longer annoying.  R3~
Rough Edge racing
« Reply #9 on: April 13, 2018, 03:03:22 PM »
yep,
 If the motor mount bolts are tight and the engine is running nice...Yes, just do what you can....I know some guys claim a motor get smoother with time but I would like to know exactly why that is...
« Reply #10 on: April 13, 2018, 07:30:16 PM »
 It's because your bones went numb so it only feels like less vibration.
Offline John Ulrich
« Reply #11 on: April 14, 2018, 03:47:52 PM »
This!   :thumb:
Eagan, MN & Scottsdale, AZ
MN MGNOC Rep  L#800
Offline Socalrob
« Reply #12 on: April 15, 2018, 03:40:32 AM »
I find the best way to reduce vibes on my BMW and my Motoguzzi is to ride my KTM 690 for a couple of days.
Offline lazlokovacs
« Reply #13 on: April 15, 2018, 04:08:02 AM »
likewise my '69 Triumph
 :laugh:
