Author Topic: Tire air pressure question?  (Read 18196 times)
« on: April 19, 2018, 09:32:35 PM »
Should be a simple answer, but it could turn into an oil thread  :boozing:  :violent1:  :evil:
I was told by my tire only shop that the complaints about Metzler falling apart were due to low tire pressure. So here is my question...
When changing tires to the same "size" as the Owners Manual says to use. Should you go by the Owners Manual or what is stamped on the sidewall for air pressure? Could this mean that I need to know the weight of the bike and all carried upon it?
I ask because when I changed from Michelin Commander II to Metzler 888 in the same size, the max load and max pressure changed by 10psi and a few hundred pounds carrying capacity.
Offline Guzzi Gal
    • Sonoran Sunriders, YouTube
Re: Tire air pressure question?
« Reply #1 on: April 19, 2018, 09:52:10 PM »
I always thought what was stamped on the side of the tire was the max cold pressure allowable.
"Velvet" '16 Honda CTX 700,
"Miri" and Mori"
« Reply #2 on: April 19, 2018, 09:56:36 PM »
 The 10 % rule always applies . Start out at a baseline of 38 PSI front and 40 PSI rear , ride the bike until the tires are warmed thoroughly , then check the pressure . What you want is a 10% increase in pressure . Adjust cold pressure accordingly .
« Reply #3 on: April 19, 2018, 11:34:43 PM »
I should have mentioned. Book is 35 solo and 40 two up rear and front is 30 either way. Commander rear was 40 max and 888 is 50 max on the sidewall.
Thanks so far!
« Reply #4 on: April 19, 2018, 11:35:05 PM »
As I recall, Metzler recommends extra pressure in the rear tire of its heavy duty radials.
You should be able to search it up on Google. 42 or 44 psi.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
« Last Edit: April 19, 2018, 11:36:23 PM by rocker59 »
Offline ITSec
« Reply #5 on: April 20, 2018, 12:58:12 AM »
Dusty's reference is the best starting place, but there's no question that the starting cold pressure should be higher than the tire you came from. The sidewall max pressure rating is an indication - BUT ONLY THAT - of the ability of the tire design to hold air pressure and carry a designated weight.
Now, let's get into all the other factors....
What is the max weight capacity of the original tire at the spec pressure, compared to the replacement tire?
What is the difference in construction (bias v radial)?
What is the type of use that the tire will be exposed to (light v heavy load, highway v twisty v city riding, etc)?
What is the design of the tire compound (i.e., is it one of the newer multi-compound designs with a harder high-wear rubber down the middle)?
These all have an influence on what pressure will produce the best safety/wear/handling characteristics, and will (of course!) also vary based on how you ride the bike.
ITSecurity
2013 Stelvio NTX - Copper
2008 Norge GT - Silver
I am but mad north-northwest!
« Reply #6 on: April 20, 2018, 01:32:24 AM »
ITSec, your right, there are variables to this! Dusty has the right idea about pressure gain.
I guess I was just hoping for a simple answer like:
If you only weight half of the max capacity of the tire, then you only run half of the max psi or the like.
My loops always have been at about 32 psi F & R. My EVT as well. All seem to get great wear and handling for the riding I do. I never really worried about the pressure, as long as it was about 30psi. 20psi and it needed air, 35psi, let a bit out when measured cold. My Commander if run with 38-40psi would feel like a basketball over the lane reflector markers. At 32 it was fine.
Dang nabit ME888 and it 50psi max rating. It made me wonder! I have been running it at 38 and it has felt fine for the week I have owned it. The tire shop had it at 45, which I thought was a bit high. The bike is about 640lb if I remember right.
Thanks again!!
Offline Zoom Zoom
« Reply #7 on: April 20, 2018, 03:28:40 AM »
As already stated, the pressure listed on the sidewall of a tire is the max pressure that the manufacturer says is safe.
Low, (underinflated), pressure will generate excessive heat which can result in tire failure. Sometimes there will be evidence of that on the inside, as granules of rubber come off. Of course you will not see that unless you break the tire off the rim.
The vehicle manufacturer recommends tire pressure based on vehicle weight and often times will list additional pressures based on load.
Consider a car tire that has a flat contact patch. (From side to side.) Several vehicles may use the very same tire size yet have different pressure ratings dependent on the weight distribution of the vehicle. The heavier end of the vehicle, like the front, may have you using a couple extra pounds of pressure than the back which is much lighter. An underinflated tire will cause the edges to wear at a greater rate then the center and will generate more heat since things are flexing more. An overinflated tire will wear in the middle more than the edges. If you have a pickup truck that is always loaded, you would want to run a bit more pressure in the back that when empty. The ideal way to know the correct temp would be to use a laser thermometer and read the temp at the edge of the tread and the center. It should be uniform. If it is hotter on the edges, it is underinflated, and vise versa.
Although a bike tire has a round profile, the inflation pressures will still vary between applications. If two bikes used the same tire but were 100 pounds different in weight, the recommended pressure will likely be different. In either a car or bike application, there would be an ideal contact patch that would be dependent on tire pressure.
John Henry
Offline chuck peterson
« Reply #8 on: April 20, 2018, 05:08:00 AM »
Less than 10% rise from cold, too high to start
More than 10%, too low to start
This idea takes into account all the variables of weight, temp, load, riding pace, road surface, and whether your dragging an anvil or not... :popcorn:
« Last Edit: September 28, 2026, 08:25:39 AM by chuck peterson »
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
« Reply #9 on: April 20, 2018, 05:14:49 AM »
Bingo
« Reply #10 on: April 20, 2018, 05:53:42 AM »
Thanks again!!
http://www.metzeler.com/site/us/en/answers/detail?idDomanda=2381
Moto
« Reply #11 on: April 20, 2018, 09:57:37 AM »
Less than 10% rise from cold, to high to start
Chuck is right. I'll add a codicil: Start your experiments using the Guzzi recommendations for the original tire. The rated pressure on the sidewall is not relevant unless you wanted to exceed it based on your experiments. But that won't happen.
Moto
« Reply #12 on: April 20, 2018, 10:44:45 AM »
Sounds like I should run it at about 38-40psi and see how the pressure changes.
Thanks again for the help with this!
Offline Roman Hordan
« Reply #13 on: September 28, 2026, 06:35:52 AM »
Late to this one, but here's something that might help. The number on the sidewall is just the max the tire is built to hold, not what you should run. Your bike's manual number is the right starting point since it's based on the bike's weight and how it handles, and the tire change doesn't alter that.
Since the ME888 rear is a stiffer, higher-rated carcass, I'd start at 38-40 cold and then do the 10% check people mentioned above. Ride it until it's warm, check the tire pressure, and if it climbed more than about 10%, you started too low. Less than that and you can go a bit lower.
Your 640 lb bike with the shop's 45 psi is probably on the high side, and 38 sounds like a good place to start. If it feels harsh over bumps, drop a couple of pounds and recheck.
Offline MikeP996
« Reply #14 on: September 28, 2026, 07:11:45 AM »
FWIW, I've seldom found the owner's manual tire pressures to be optimum for my weight/way I ride.  Typically it's several pounds too high.  For example, my V7 states 36/36 but I found 32F/34R to work better for me.  I've always done it by riding/adjusting.  I admit I never heard of the 10% thing until reading it here a few weeks ago.  I only found one reference to it after doing some research.  There are probably more but the only one I found mentioned 10% for the front tire and 20% for the rear.  I couldn't find any reference to it from any motorcycle tire manufacturer or several motorcycle manufacturers' manuals.
I admit I'm wondering if it's an internet myth invention thing.  ;)
« Last Edit: September 28, 2026, 07:13:39 AM by MikeP996 »
2021 Moto Guzzi V7 850 Special (UK)
1976 Honda CB400F (UK)
2017 BMW R1200RS (TX)
'73 Norton Commando (Mexico
2015 BMW R9T (Mexico)
(Wife's bikes:
2015 Ducati Diavel (TX)
2019 Honda Africa Twin  (Mexico)
2021 Honda NC750  (UK)
« Reply #15 on: September 28, 2026, 08:47:11 AM »
Since you brought it up..ignore the sidewall max, just don’t go over it.
I first heard, and saw it in the pits from AAMRR racing at Louden/Bryar….originated from racing as a starting point. Mechanics would measure tire pressure immediately after coming off track. Since 1978 I’ve heard it from many directions
Neat thing is, it applies across the board. If you’re really aggressive at riding, or a senior citizen like me on a 250 scooter, it still works.
It takes into account all the variables of bike weight, road surface, load, weather, style…anything you can think about what a bike will do..
The numbers in the books from the manufacturers are starting points
My Vert with bags and Windjammer needed 38/42 cold
Loaded for a 4 week trip it needed 40/46
My other Vert with no bags, no Windjammer needed 34/38
In all three cases they warmed by 10%. Measure cold tire. Ride a 1/2 hr. Measure again
More than a 10%, your cold start pressure is too low
Less than 10% your cold start is too high a pressure
38 lbs cold becomes 38 plus 3.8, almost 42.
42 cold becomes 42 plus 4.2, just over 46
You know, it’s math i said I would never need
Im closing in on 16,000 on a ME888 on the rear, highest mileage ive ever gotten. It is on a small block
« Last Edit: September 28, 2026, 08:53:01 AM by chuck peterson »
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
« Reply #16 on: September 28, 2026, 09:36:41 AM »
I know I'm being picky and pedantic here, and though I agree it's a good place to start I want to make clear that a significant change in tire type/weight rating etc. make that starting point less and less relevant (or I should say less and less accurate for with where you should land in the end).
Though I honestly see it more in the automotive industry where you can find much different load ratings between two otherwise seemingly similar tires.
Offline Moparnut72
« Reply #17 on: September 28, 2026, 11:11:12 AM »
"For example, my V7 states 36/36 but I found 32F/34R to work better for me."
This is what I found to be about the best for me as well.
kk
Mopar or Nocar
Current Bike:
2026 Triumph T120
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline wirespokes
« Reply #18 on: September 29, 2026, 08:28:53 AM »
I've heard that the front should show an 8% rise and the rear 12%. But using 10% works and is easier to calculate. The difference in the calculation is miniscule and not worth worrying about.
Online SIR REAL ED
  • uh.... it's personal....
« Reply #19 on: September 29, 2026, 09:23:21 AM »
Fascinating.  I have never heard this before.  You can learn something new every day.
I suspect heavy high horsepower bikes are much more sensitive to tire pressure than lighter bikes with less power.
2002 MZ Skorpion
1994 DR Skorpion
Offline faffi
« Reply #20 on: September 29, 2026, 12:46:00 PM »
Apparently, tire pressure will go up 1-2 PSI for every 15-20F temp increase. In my experience, living in a country where 90F is considered a heat wave that does not happen every year, tire temp and pressure do not climb much, even during extended rides/drives, be that motorcycle or car. Tire surface temperature after a trip is often below my body temperature. More pressure gives a cooler running tire, which again reduce wear. Surprisingly, my car tires have a lot more grip, wet or dry, with 36 PSI than with 32 PSI. In fact, stopping power at 32 PSI is significantly reduced. And running 36/42 PSI front/rear on my radial shod bikes does not seem to adversely impact grip, either, at least not the way I ride. On lighter bikes, I may reduce tire pressure to improve comfort.
Current bikes:
2002 BT1100
2018 V9 Roamer
1982 XV750/1100 mongrel
1990 XT600Z
2001 NT650V in bits
« Reply #21 on: September 29, 2026, 12:59:26 PM »
Apparently, tire pressure will go up 1-2 PSI for every 15-20F temp increase..
PV=nRT
« Reply #22 on: September 29, 2026, 01:32:11 PM »
From the Dunlop tire race engineers:
10% rise in pressure is the starting point (cold to operating temperature).  Adjust for riding style/personal preference from there.  2) all motorcycle rear tires slip about 5% just riding regular on the road.  High hp and aggressive riding styles as well as increased torque increase the slip.  Adjust as needed.
Offline willowstreetguzziguy
« Reply #23 on: September 29, 2026, 02:22:44 PM »
On Sept. 9 while getting my 2008 1200 Sport serviced by Jim Hamlin, he checked my tires and said…
Front Dunlop RoadSport IV 120/70 17 should be at 36psi
Rear Dunlop RoadSmart IV 180/55 17 should be at 41psi
2008 Guzzi 1200 Sport
Online SIR REAL ED
« Reply #24 on: September 29, 2026, 06:51:06 PM »
PV=nRT
Dr. Huzo, how many times have you told your students to: "Show your work!  Show the units!"
Mold these fine young minds Sensei....
2002 MZ Skorpion
1994 DR Skorpion
Offline wirespokes
« Reply #25 on: October 01, 2026, 02:17:26 PM »
I was 700 miles from home and had to get back. I'd noticed the tire had worn much more quickly than expected and didn't look like it would get me home. And, it was late on a Saturday and couldn't find a replacement. So I pumped it up to the max, rode 55 all the way, and did what I could to keep the bike leaned a little so the rear would contact more on the side where there was deeper tread. Kinda weird having semis passing ME.  When I got home the tire looked exactly as it did 700 miles ago.
So I wouldn't recommend running at max pressure, but in a pinch it certainly reduced wear!
