Author Topic: Single disc Eldo '74  (Read 1110 times)
Offline danedg
« on: April 23, 2018, 08:58:42 AM »
The single disc on the Eldorado is starting to show some signs of wear after 76,000 miles. AFAIK it originally measured 6.5 mm thick. It measured 6.36 mm today. What are the wear limits for that disc?
'74 Eldo
'65 R60/2
'68 R60US
'54 R51/3
'78 Honda Hawk
'95 Mystic
Offline Aldo
Re: Single disc Eldo '74
« Reply #1 on: April 23, 2018, 11:35:08 AM »
Minimum thickness is stated by Brembo to be 5.7 mm
http://www.thisoldtractor.com/moto_guzzi_loopframe_disc_brake_rotor.html
MGNOC Lifetime Member
1973 Eldorado 850
1971 Ambassador 1000 Automatic
1960 Gilera Giubileo 98
1967 Benelli Sprite 125
« Reply #2 on: April 23, 2018, 01:19:35 PM »
How was it measured?  Remember, flat calipers only measure the thickest points.  Min thickness is the thinnest.  A rotor micrometer (I soooo want to say "caliper") has needle points and will seek the low points for true min thickness.  When you're fussing over a few mills, those needle points make a difference.
Brembos should have the min thickness cast into the webbing of the rotor.  The number can be hard to spot.  I just went out and looked at my Convert -- 5.7mm.  Obscured by rust (yay, cast iron!).  I had to roll a few degrees, search, roll, search . . .
« Reply #3 on: April 23, 2018, 02:16:38 PM »
HF sells an inexpensive gauge that will work if you need one.
« Reply #4 on: April 23, 2018, 02:56:00 PM »
Also you can take the rotor to a brake shop and they'll probably measure it for you.
