Author Topic: 8V Norge Upper RPM Questions  (Read 2351 times)
Offline craigclu
« on: May 11, 2018, 08:58:24 PM »
2014 Norge with 8000 miles, GPR Albus (dB killer in place), colostomy bag in place, stock intake.  This is a bit of a non-issue as I seldom need or want to be at redline levels anyway but I'm curious....  I've been re-mapping with Beetle maps and just getting to a recent update with a late arriving ride season here in Wisconsin.  I've done some spirited (for me) riding to develop a current base-point and have noticed that running much past 7000rpm just sounds busy and seems to not add much in propulsion.  I put the new map on today (for GPR-equipped Norges) and gave things a run through the gears and had the same sort of feeling.
It does everything I want for the riding I do.  Easy starting, smooth running, linear acceleration, good mileage and has good, long legs for brisk riding.  Do others experience this same basic behavior and is it just the general nature of the engine?  I have little need for that part of the rev range but wonder if this is just a normal characteristic of this engine?
He who is without oil shall cast out the first rod...”-Detonations 5:72.
beetle
Re: 8V Norge Upper RPM Questions
« Reply #1 on: May 11, 2018, 09:45:24 PM »
The 8V peaks at ~7300 RPM, and is generally flat till about 8000, then drops off rapidly. I set the rev limit at 8500. You should be able to hit the rev limiter in 5th easily. It takes a bit of patience in 6th.
« Reply #2 on: May 11, 2018, 11:35:01 PM »
What year model? Has the top end ever been apart? I don’t think it’s likely to be the issue as the point at which you say it goes flat is a bit high but having the cam timing a tooth out will lead to a sudden flattening out of power but usually closer to 6,000 than 7,000.
beetle
« Reply #3 on: May 12, 2018, 01:12:41 AM »
Do the read the post, Pete. 2014 model, you goose!
« Reply #4 on: May 12, 2018, 01:54:47 AM »
Err? Obviously not :embarrassed: :rolleyes:
Offline craigclu
« Reply #5 on: May 12, 2018, 03:48:05 PM »
Thanks, guys.  I couldn't be happier with how it's running and mainly just curious.  I was on a 200 mile loop today with all types of roads and it feels like an electric motor at 80mph on the freeway and felt perfect on curvy, varied-speed roads and loads.  That got me 42 mpg (5.6L/100km) that could be easily improved on with more moderate riding.  It almost felt like valve float, with the thrust dropping off so clearly between 7000 and 8000rpm.  I don't want to change a thing.  Thanks for the effort on these maps, Beetle!  :bow:
« Reply #6 on: May 12, 2018, 04:44:57 PM »
I’d be tempted to check the cam timing ‘Just in case’ but I’m probably being a bit paranoid  :laugh:
beetle
« Reply #7 on: May 12, 2018, 06:15:47 PM »
I�m probably being a bit paranoid  :laugh:
You're not paranoid. They really are out to get you. Put your tinfoil hat on immediately.
 :shocked:
« Reply #8 on: May 12, 2018, 06:33:52 PM »
Tinfoil hats are for loosers! To really protect yer self you need a U-beut carbon fibre hat!
beetle
« Reply #9 on: May 12, 2018, 07:00:52 PM »
Guffaw!
Quote from Leah: "That's not very attractive, Pete."
Offline Larry
  • Escape Reality At Any Cost I Say
    • Melbourne West Church
« Reply #10 on: May 12, 2018, 11:37:29 PM »
That's just sad 😁
2002 Stone 1100 - Gone
2005 Breva 1100 - Gone
2012 Stelvio 1200 8V ABS - Gone
2013 Sport 1200 8V ABS - Current
« Reply #11 on: May 13, 2018, 12:25:46 AM »
Careful Larry, i’ll Be servicing your Sport this week...... :evil:
Offline Larry
« Reply #12 on: May 13, 2018, 01:01:46 AM »
Careful Larry, i�ll Be servicing your Sport this week...... :evil:
Hehe. I just couldn't resist 😁
« Reply #13 on: May 13, 2018, 09:00:28 AM »
err, uh.. nice t shirt. I like green. (momma told if I couldn't say something good, don't say anything..)  :grin:
