Author Topic: porous casting repair  (Read 6296 times)
Offline Don G
« on: May 31, 2018, 09:53:49 AM »
There is a casting flaw on my V700 crank case in the main oil journal of course, I noticed that the oil light would come on at hot idle and go out with an RPM increase, I figured that maybe a bad sender was the cause. I sourced a proper fitting and installed a test gauge, I have 10LBS pressure with cold 20-50, so I pulled the lump out and stripped the front cover and oil pan off. I blocked off the oil pick up drilling and induced oil pressure into the sender hole. I found that there was a mass leak behind the cam gear.
Now I wonder about a fix for this casting flaw, I am not even considering welding , perhaps an aluminum based epoxy would be the best, anyone with any practical experience out there?
Online John A
Re: porous casting repair
« Reply #1 on: May 31, 2018, 10:07:12 AM »
I'd look at drilling and tapping for a plug if that's suitable. Otherwise a Devcon or similar product if you can get the oil cleaned out of the pores by heating and a solvent like MEK followed by acid etching.
« Last Edit: May 31, 2018, 10:11:08 AM by John A »
Offline JoeW
    • The Guzzi Doctor
« Reply #2 on: May 31, 2018, 10:19:44 AM »
I've repaired porous cases with JB weld BUT, that's a pressurized passage. Drilling and tapping could work, you'd have to at least pull the front main and oil pump to make sure you get all the filings out. That hole looks pretty big, who knows how big the fissure really is. I would think the best repair would be welding.
I have a spare v700 case number #1885.
« Last Edit: May 31, 2018, 01:11:55 PM by JoeW »
Joe Walano
Offline Zoom Zoom
« Reply #3 on: May 31, 2018, 10:26:37 AM »
Looking at the first pic, and noticing the small pin holes around the big hole, I would be concerned about any repair. The entire area looks thin. I could just see a repair failing and then you are back to where you started or worse.
Have you considered submitting these pictures to a dealer just in case Guzzi is willing to cover this. There is no doubt this is a casting flaw. It can't hurt to ask.
John Henry
Online John A
« Reply #4 on: May 31, 2018, 10:28:56 AM »
I would personally not weld because I'd be worried about distorting it. Maybe a welder can give a better estimation. You could just call Rodekyll and buy a good block. After looking at the pictures closer, I'd clean it, heat it, clean it, etch it and seal it.
« Last Edit: May 31, 2018, 10:38:23 AM by John A »
« Reply #5 on: May 31, 2018, 10:34:30 AM »
John Henry
I would think that the warranty has long ago lapsed on a V700.  :laugh:
I will be parting out a '67 V700, so if a replacement case is needed, I'll have one.
« Last Edit: May 31, 2018, 10:36:01 AM by Antietam Classic Cycle »
Offline Zoom Zoom
« Reply #6 on: May 31, 2018, 10:42:06 AM »
Well yeah. I was thinking it may be a modern V7(00)
It it is as you suggest Charlie, I personally would go looking for another block and be done with it.
John Henry
« Reply #7 on: May 31, 2018, 10:54:19 AM »
https://thumb.ibb.co/inY3nd/IMG_0145.jpg[/img][/url]
It appears the oil way goes from the center of the upper shaft to the center of the lower one, this would have been drilled after casting.
Could you strip it down and drill the oil way larger and then insert a sleeve? I'm thinking something like the thin walled steel tubing used for brake lines.
I would try stuffing something in the hole first, it doesn't have to be perfectly oil tight, similar to the lead plugs you see in carburetors.
It looks as though the flaw would be at the back of the oil-way, it might be safe to drill it without having to pull it all apart. The rougher the better if you want to try epoxy.
Really, how many years has this motor been running in this condition, it's no big deal to run low pressure at idle. My Eldorado will drop below 10 psi when it's really hot, idles below 800 at a guess back at 60 when moving.
BTW, none of my earlier Guzzis had a reliable oil pressure switch, I put a gauge on.
« Last Edit: May 31, 2018, 11:22:58 AM by Kiwi_Roy »
Offline AJ Huff
« Reply #8 on: May 31, 2018, 11:01:25 AM »
 that's a scrap casting. Should never have made it past QC. No real fix. Sorry.
-AJ
'71 Ambassador
'01 California Special
'05 Road King
MGNOC# L-753
Offline Don G
« Reply #9 on: May 31, 2018, 11:23:01 AM »
Yup, a new case is in my future, it looks pretty thin, that's why I didn't want to weld the hole closed, if it was cast Iron I wouldn't hesitate to braze it shut but aluminum is a different story, could be a disaster. I wonder if this has leaked from day one? I was road testing this engine after a complete overhaul and was wondering why it seemed to run hot, timing was on and had new springs in the distributor and jetting was correct, now I know why! I may take the case into the local Tig welder and get an opinion, but I think I may be contacting the chaps with the spare cases on offer, thanks guys!  DonG
Offline RinkRat II
  • Lake Powell AZ
« Reply #10 on: May 31, 2018, 11:29:54 AM »
 I agree with Kiwi Roy, if it's accesible to drill and sleeve that would be the most permanent fix. After you talk to your welder, talk to a machine shop and see.
   Paul B :boozing:
« Reply #11 on: May 31, 2018, 12:28:28 PM »
Drill it. Thread it. Loctite a tiny grub screw in it.
Online Perazzimx14
« Reply #12 on: May 31, 2018, 01:12:34 PM »
Since the block is no good as is you can't ruin it further by try to repair it.
2017 Road Glide Special
2020 Kawasaki KLX300SM
Rough Edge racing
« Reply #13 on: May 31, 2018, 01:33:38 PM »
 Hmmm, that does look cheesy when the photo is enlarged.... If possible, my hillbilly repair would be a small patch from aluminum sheet metal formed to fit with a few perimeter screws...And a high quality epoxy as a sealer between patch and casting...
« Last Edit: May 31, 2018, 01:34:15 PM by Rough Edge racing »
Offline larrys
« Reply #14 on: May 31, 2018, 02:25:04 PM »
I have an Ambassador block that I would let go, would that work?
Larry
'13 Monster 1100 EVO
'95 Cal 1100
'68 Bonneville
MGNOC 7248
« Reply #15 on: May 31, 2018, 02:40:31 PM »
The problem with changing the block is the engine No will no longer match the frame.
Assuming it did anyway.
My loop has the same No
What's the mileage on the odo?
Offline Don G
« Reply #16 on: May 31, 2018, 03:04:28 PM »
Yeah the frame and engine #'s match on this one, I have another 68 model and they also match, one other one that I have does not.  DonG
« Reply #17 on: May 31, 2018, 03:06:11 PM »
V700 numbers rarely match from the factory, so it wouldn't be a big deal. The '67 I'm parting out has engine number 1566 and frame number 1433. Ambassadors and Eldorados almost always do.
« Last Edit: May 31, 2018, 03:06:35 PM by Antietam Classic Cycle »
« Reply #18 on: May 31, 2018, 03:12:22 PM »
I wouldn't be afraid to weld it. The problem will be getting the casting clean enough to weld. That means a tear down, I'm afraid..
Offline Toecutter
« Reply #19 on: May 31, 2018, 03:21:31 PM »
Why aren't you thinking of welding? Seems like the most logical choice.
Offline JoeW
    • The Guzzi Doctor
« Reply #20 on: May 31, 2018, 03:42:33 PM »
That passage is accessible through the port from the bridge pipe. That is an 8mm hole, the leaking passage is 5 mm. A skilled machinist could open it up to accept a sleeve. I would not drill all the way to the cam bearing surface so the sleeve has an upper stop. Just an idea.
« Last Edit: May 31, 2018, 03:47:52 PM by JoeW »
Joe Walano
« Reply #21 on: May 31, 2018, 04:08:58 PM »
"Sure, bring it on over, I'll take a look"
« Reply #22 on: May 31, 2018, 04:10:07 PM »
Offline Don G
« Reply #23 on: May 31, 2018, 04:51:37 PM »
Good plan Kiwi & Joe, I will scope it out tonight, just have to find some tubing..... DonG :thumb:
« Reply #24 on: May 31, 2018, 05:35:17 PM »
Thin walled steel brake lines is what I used on my Eldo, the car parts places usually have short pre-made lengths, just drill out with a pistol drill to suit, I don't believe the 5mm is critical, 1/4" OD perhaps.
Offline JoeW
    • The Guzzi Doctor
« Reply #25 on: May 31, 2018, 05:46:21 PM »
Mcmaster Carr part number 9811T13  8 mm OD 5 mm ID seamless stainless tubing. .5m is $56.00
Joe Walano
« Reply #26 on: May 31, 2018, 06:00:49 PM »
Hi Don
I have a set of alpha numerical stamps and the star stamps as well to replicate the factory engine stamps, not that I am encouraging any fakery but it is a Loop motor after all and not something as rare as a V7 Sport or Le Mans. If you get a replacement block bring it over and we make it into a matching numbers block :azn:
Offline AJ Huff
« Reply #27 on: May 31, 2018, 06:29:25 PM »
Look the whole casting over. That's a shrinkage defect. That heavy section was feeding the thinner section and there wasn't enough metal at the end of solidification to keep the heavy section full. You might want to make sure you don't have any more where you have a heavy section to thin section intersection, same side of the casting.
-AJ
'71 Ambassador
'05 Road King
MGNOC# L-753
Offline JoeW
    • The Guzzi Doctor
« Reply #28 on: May 31, 2018, 08:07:25 PM »
I had a persistent oil leak on an Ambo recently. It wasn't a pressure leak just gravity. I found it with baby powder. And fixed it with JB Weld.
Sent from my VS988 using Tapatalk
Joe Walano
Offline JoeW
    • The Guzzi Doctor
« Reply #29 on: May 31, 2018, 08:32:33 PM »
I disagree, this passage feeds the front cam bearing and the rockers. I would try to be as precise as possible. 8 mm is .3150" 5/16 is .3125 that would be a decent interference fit. I would prefer doing it in a mill or a good drill press at the very least.
Sent from my QTASUN1 using Tapatalk
Joe Walano
