Author Topic: Breva 1100 Torque spec- wheel shaft clamp screws?  (Read 2125 times)
Offline Neil
« on: June 01, 2018, 07:59:00 PM »
As the title says, I need the torque numbers for the four allen screws at the bottom of the forks that hold  the wheel shaft (axle) in place. Not listed in my copy of the service manual. Thanks in advance.
Online rodekyll
Re: Breva 1100 Torque spec- wheel shaft clamp screws?
« Reply #1 on: June 01, 2018, 08:20:59 PM »
They are pinch bolts and hold under even tension.   Snug them evenly by tightening one then the other and back until they both feel uniformly tight.  8-10 pounds/ft is probably good as long as they are the same.  If they are not even they will unscrew.
« Reply #2 on: June 01, 2018, 08:34:54 PM »
7 ftlbs max if a 6mm screw. May be the same as 1200 2V Sport or Norge.
« Last Edit: June 01, 2018, 08:37:07 PM by guzzisteve »
Online rodekyll
« Reply #3 on: June 01, 2018, 08:41:41 PM »
I'll go with that.   Heavy torque isn't needed.   Even torque is.
« Reply #4 on: June 01, 2018, 08:43:37 PM »
Yes, same as Norge     Fork Hub Closing--10nm     looked it up that quick
Offline GuzziNZ
« Reply #5 on: June 01, 2018, 11:38:20 PM »
10 Nm. No more !
Offline Neil
« Reply #6 on: June 02, 2018, 10:46:23 AM »
Thanks all,
            will check them tonight after work.
« Reply #7 on: June 02, 2018, 12:14:33 PM »
Four?
What bike is this? Most do not have pinch bolts on the axle nut side.
