Author Topic: Starter hitting neutral signal bolt, is this common? 850T  (Read 2109 times)
Offline NCAmother
« on: June 19, 2018, 09:10:48 PM »
Just mated the transmission to the BB motor, starting installing the starter, and it hits one of the attachement bolts for the neutral signal switch.  Everything is bolted up, mounted flush and doesn't look "cockeyed" although one of the starter mounting bolts is touching the bolt hold down the neutral signal switch.  Is this normal?  This is on an 850T
Howdy
Re: Starter hitting neutral signal bolt, is this common? 850T
« Reply #1 on: June 19, 2018, 09:17:51 PM »
Bosch starter or a Valeo/Valeo clone?
Offline NCAmother
« Reply #2 on: June 19, 2018, 09:19:03 PM »
Its the later model Valeo, thanks Charlie
Howdy
« Reply #3 on: June 19, 2018, 09:30:21 PM »
Not uncommon. IIRC, you'll need to swap the bolt for button-head.
Offline NCAmother
« Reply #4 on: June 19, 2018, 09:42:26 PM »
sounds like the first easy thing I could do to my 850T lol!
Howdy
Offline Daniel Kalal
  • Daytona, Stelvio [Kansas]
    • Trip Reports
« Reply #5 on: June 19, 2018, 09:52:06 PM »
The swap from Bosch to Valeo is clean and easy, but there's that one bit of clearance that you'll need to deal with.  On my Cal2, just a small bit of grinding on the neutral switch screw was enough to take care of it.
Offline Rick4003
« Reply #6 on: June 20, 2018, 06:29:23 AM »
I had the same issue when I installed my Valeo starter.
I used two countersunk screws and just countersunk the neutral switch so it fits.
-Ulrik
Moto Guzzi Ambassador - 1967
Yamaha FZR 600 - 1996 - SOLD
Offline mtiberio
    • TiberioRacing
« Reply #7 on: June 20, 2018, 06:36:32 AM »
this is the solution I use
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
