Kiwi, the coils are different between left and right. The right coil has an internal switch arrangement and has a 3 pole connector while the left coil is more of a standard coil with 2 pole connector and the switching done directly by the ECU.
The reason for this is that the MIU G3 was originaly designed to be used primarily on single cylinder engines and the use on a twin cylinder is a bit of a kludge, consequently, there is only one heavy duty switch for the ignition coil from pin1 of the ECU which is designated 'Cylinder Coil Command Output 1 (LH)'.
The right coil is supplied with battery from the 'Injector Load Relay' and a permanent earth (from ECU pins 7 & 23) and the switching for the coil comes from ECU pin 8 which is designated 'Cylinder Coil Command Output2 (RH)'.
All very straight forward I don't think.
A bit hard to swap them
Thanks for the suggestion.
Cheers
Brian
