Shims needed
Topic: Shims needed (Read 2190 times)
John A
No way to slow down...
Shims needed
July 24, 2018, 11:37:41 AM »
Does anybody know where I can find some round shims, 25mm ID, 30 mm OD, 1mm and 2mm thick? I've looked on the internet until Im blind, and all the usual sources, Mcmaster, grainger, msc and have come up emty
pehayes
Re: Shims needed
Reply #1 on:
July 24, 2018, 12:01:03 PM »
What's the usage? How critical are the dimensions? How critical is the material? Good lathe worker could make them.
acogoff
Re: Shims needed
Reply #2 on:
July 24, 2018, 12:01:57 PM »
I can see that the 30m OD is the problem. You may have to get the 25 ID and stack them up and turn them or grind, depending on how hard they are. Seems like a very odd shim.
Marshall County Minnesota USA
Antietam Classic Cycle
Happily stuck in the past.
Re: Shims needed
Reply #3 on:
July 24, 2018, 12:26:12 PM »
Convert the 25 mm to 1", 1 mm to .040" and 2 mm to .080" and maybe you'll have more choices? Just an idea.
Or just buy the 25 mm i.d. x 36 mm o.d. shims that McMaster sells and grind down the o.d. to 30 mm?
Last Edit: July 24, 2018, 12:28:46 PM by Antietam Classic Cycle
RinkRat II
Lake Powell AZ
Re: Shims needed
Reply #4 on:
July 24, 2018, 12:29:11 PM »
Greetings John,
I have a chunk of material (stainless) thats 25mm ID and 32mm OD and 1.5" long if you have a machinist that could whittle some out for you.
The alternative would be to locate a GOOD pump repair shop and see if they have some or a sleeve that could be machined to your needs. Lemme know
Paul B
These guys are an alternative too
https://www.bokers.com/search_results.asp
Last Edit: July 24, 2018, 12:52:23 PM by RinkRat II
John A
Re: Shims needed
Reply #5 on:
July 24, 2018, 01:09:37 PM »
I can make them but I was hoping to just buy some. I can chuck them up in the lathe and grind the ID but don't have a way to chuck them to grind the od. so I spose ill just get some with the correct od and grind them. it looks like it'll be faster than trying to find some. thanks
pehayes
Re: Shims needed
Reply #6 on:
July 24, 2018, 01:30:39 PM »
If you can do the ID to 25mm, then just build a little mandrel with a stem of 25mm OD by perhaps 3mm proud. Then build a 'cap' which has a recess of 25mm ID and perhaps 5mm deep. Drill a small center hole. Mount the mandrel in your chuck, add the shim, add the cap over the mandrel, use a live center and good pressure on your tail stock to pinch the shim between the mandrel and its cap. Now work away on the OD down to 30mm. Work gently and the shim shouldn't slip in the pinch. I often spend hours making fixtures like this that get used for 5 minutes.
guzzisteve
"Just Ride It"
Re: Shims needed
Reply #7 on:
July 24, 2018, 01:34:23 PM »
That sounds like rear drive pinion shims. Tired of spending $2 for them?
The one on the end under gear is 35mm OD , the inner ones are 31 or 32 OD.
Last Edit: July 24, 2018, 01:37:01 PM by guzzisteve
John A
Re: Shims needed
Reply #8 on:
July 24, 2018, 02:12:44 PM »
That's it, Steve, thanks, I thought it would be an industry standard thing. Ill do it like Patrick said, I was hoping not to but itll keep me out of the heat, fixing my old trucks that need attention too. I'm grateful I'm not a few hundred miles south this summer!
sidecarnutz
Re: Shims needed
Reply #9 on:
July 24, 2018, 02:59:48 PM »
Am I the only guy left who buys shim stock and the traces what I need with a scribe and then cut it out on a small hobby band saw?
Easy enough after that to deburr edges and use it.
2002 Kawasaki ZR7S
Shims needed
