Author Topic: Sucking the fuel out  (Read 6702 times)
Offline dguzzi
« on: August 20, 2018, 10:37:05 AM »
Is there a recommended pump to transfer fuel from motorcycle tanks?  Or I guess any tank...   Even a drill operated one might work if it handles gas ok.
'03 EVT
'87 Cagiva
'72 Commando
'71 Commando
'13 F150
'16 Mustang
Offline Zoom Zoom
Re: Sucking the fuel out
« Reply #1 on: August 20, 2018, 10:40:30 AM »
What about a hand pump like the ones used to fill a kerosene heater? Usually only a couple of bucks.
John Henry
Offline dguzzi
« Reply #2 on: August 20, 2018, 10:46:34 AM »
Not sure what you mean.  Certainly not those orange tube kind(junk)...
'03 EVT
'87 Cagiva
'72 Commando
'71 Commando
'13 F150
'16 Mustang
Offline yogidozer
« Reply #3 on: August 20, 2018, 10:50:00 AM »
how about just a hose, into a container, then empty the container into the next tank?
Offline Zoom Zoom
« Reply #4 on: August 20, 2018, 10:55:33 AM »
What I was thinking was this:
https://www.grainger.com/product/38Y789?cm_mmc=PPC:+Google+PLA&s_kwcid=AL!2966!3!166587421918!!!g!82166794917!&ef_id=W1BmHAAAALA6vhCq:20180820155050:s
Might be the same as you were referring to. The bottom could be shortened as needed and a hose could be attached to the other and once started would easily work as a siphon. Like I said, 2 bucks or so. I used to have one that took a couple D batteries but it eventually crapped out and I never bothered looking for another one. I think that was 10 or 15 bucks.
John Henry
« Reply #5 on: August 20, 2018, 11:05:40 AM »
A piece of plastic tube.  It's an Oklahoma credit card.  It works best in the dark.
 When done, remove the tube and leave the petcock open on reserve so the he won't be chasing you first thing in the morning.
« Last Edit: August 20, 2018, 11:08:32 AM by Sasquatch Jim »
Offline dguzzi
« Reply #6 on: August 20, 2018, 11:09:48 AM »
Well that would work but I was hoping for more versatility. I'd like to use it to drain gas from my mowers, bikes cars and other stuff.  We used to use an old fuel pump with battery clamps for moving fuel oil. A bit hazardous for gasoline, but the idea might work if the power source is more remote.
'03 EVT
'87 Cagiva
'72 Commando
'71 Commando
'13 F150
'16 Mustang
Offline yogidozer
« Reply #7 on: August 20, 2018, 11:17:41 AM »
What once was
K eep===I t===S imple===S tupid KISS
Is now
K eep===I t===C omplicated===K ids KICK
Offline Old Jock
« Reply #8 on: August 20, 2018, 11:20:34 AM »
Use this works a treat
https://www.amazon.co.uk/gp/product/B01M5D2XZQ/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
You can pump or siphon with it, but if pumping it takes quite a lot of squeezing
Offline Rich A
« Reply #9 on: August 20, 2018, 11:34:41 AM »
These work pretty well if there is a fair amount of fuel in the tank:
https://www.amazon.com/SUPER-EASY-SIPHON-HOSE-SES1001/dp/B00MVAIL76
Rich A
« Reply #10 on: August 20, 2018, 12:07:44 PM »
What's wrong with the taste of gasoline?
They have a name for you up here
http://mentalfloss.com/article/51399/where-does-word-hoser-come
Mowers a bit hard to syphon from unless you can elevate it.
« Last Edit: August 20, 2018, 12:12:09 PM by Kiwi_Roy »
Offline shaka
« Reply #11 on: August 20, 2018, 01:18:18 PM »
1998 V11 EV
Long Ago:
Norton Fastback
R50/2
R60/5
Offline RinkRat II
  • Lake Powell AZ
« Reply #12 on: August 20, 2018, 01:29:49 PM »
  dguzzi,
 If you can find a drill pump thats made with a neoprene rotor, thats your best bet, most are Buna , but if you run a bucket of water and dish soap through it afterward it'll last a year or two. Second option is one of the Kerosene pumps like in the Grainger post. Most hardware stores sell them for cheap.
       Paul B :boozing:
Offline Idontwantapickle
« Reply #13 on: August 20, 2018, 01:54:37 PM »
I use a 1/2 inch hose to siphon and start it by pressurizing the tank briefly with compressed air. Use a rag to make the seal for that step.
For the mower I just flip it on its side.
Hunter
Sir James Paul McCartney
AMA Charter Life Member
72 Eldo
84 BMW R100RS
Offline oldlegs
« Reply #14 on: August 20, 2018, 02:14:13 PM »
I've seen plenty of electric drills with sparky brushes that and petrol fumes sounds like it could be great fun ,not
Offline TimmyTheHog
« Reply #15 on: August 20, 2018, 02:20:52 PM »
I used to use a plastic hose to siphon the old gas out of my stone when I got it (sat for more than a year).
After that, I got this cheap gadget for water/oil/gas (one pump for each) with a 5/16" fuel line tied to the end of the pump.
https://www.ebay.com/itm/Portable-Car-Manual-Hand-Siphon-Pump-Hose-Gas-Oil-Transfer-Pump-Plastic-TONSEE/391923548889?hash=item5b4076c2d9:g:22cAAOSwpXpZyMc7
You don't have to buy from e-bay. I believe it sells in some dollar-stores in US & Canada.
« Last Edit: August 20, 2018, 02:25:13 PM by TimmyTheHog »
Currently Bikeless...*cry*
Offline yogidozer
« Reply #16 on: August 20, 2018, 02:24:37 PM »
Duh, you're not suppose to be drinking it.
It ain't that complicated, most people are smart enough to do it....most people
Offline Diploman
« Reply #17 on: August 20, 2018, 03:05:16 PM »
Harbor Freight sells this inexpensive but efficient pump for transferring fluids - including fuel.         I have one, and it works very well.
https://www.harborfreight.com/multi-use-transfer-pump-63144.html
2015 KTM 390 Duke
« Reply #18 on: August 20, 2018, 03:55:04 PM »
I don't doubt it, but I bought one and could never make it work - it never pumped a drop.
I just don't buy HF stuff that has moving parts any more ....
Offline Adk.IBO
« Reply #19 on: August 20, 2018, 04:24:04 PM »
Love my 'crankypump' from Aerostitch. I use it for my lawnmower and snowblower at end of season(s) and keep it on the bike for when someone runs out...
Luke 23:34
« Reply #20 on: August 20, 2018, 10:12:20 PM »
For the complete Oklahoma experience, light a cigarette immediately after the transfer...
Online nc43bsa
« Reply #21 on: August 21, 2018, 01:15:45 AM »
Hunter
Hoser!   :grin:
1990 MilleGT
Offline dguzzi
« Reply #22 on: August 21, 2018, 08:23:37 AM »
I don't find that one...do they still make it?
'03 EVT
'87 Cagiva
'72 Commando
'71 Commando
'13 F150
'16 Mustang
Offline Perazzimx14
« Reply #23 on: August 21, 2018, 08:45:53 AM »
These work a treat and are cheap as chips. I cannot tell you how many times I've gone to mow the grass and found the Hustler needs fuel and the 5 gallon gas can is empty. Instead of heading to the gas station I pull the Hustler beside one of the bikes a few squeezes of the bulb and a fuel transfer is underway.
Also the long semi rigid tube that goes in to the transfer liquid is good for getting into the far reaches of motorcycle fuel cells to get most of the fuel out when you need to.
« Last Edit: August 21, 2018, 08:50:28 AM by Perazzimx14 »
Offline dguzzi
« Reply #24 on: August 21, 2018, 09:18:51 AM »
Same as Lannis, never could make it work...
'03 EVT
'87 Cagiva
'72 Commando
'71 Commando
'13 F150
'16 Mustang
Online John A
« Reply #25 on: August 21, 2018, 10:06:14 AM »
When I worked for Southern Aviation in Shreveport they had an air operated pump for transferring fuel. I've been looking for a shop air powered pump ever since. Big money if bought new so it's one of the things on my " buy it when I find it" at used stuff places. I've seen the results of bad things happening when gasoline is lit off by an electric spark so I wouldn't use a drill motor on a pump, but that's just me being overcautous. Burn units have made great strides in the last few years.
Offline Adk.IBO
« Reply #26 on: August 21, 2018, 10:20:23 AM »
Apparently not...
I did a search and found them on Amazon and EBay. They are being marketed for R/C fuels with 3 different names and different end fittings for them (maybe more). I like and use mine, I suppose Aerstitch's lawyers got a hold of them or maybe some accident...
« Last Edit: August 21, 2018, 10:46:22 AM by Adk.IBO »
Luke 23:34
Offline Vagrant
« Reply #27 on: August 24, 2018, 01:52:56 PM »
Rock auto has a 12 vt electric in line pump for under $20 to your door.
Offline Jurgen
« Reply #28 on: August 24, 2018, 04:23:25 PM »
I just sucked all the fuel out of my ATV with this item from Amazon.  Go to the Amazon Web site and enter "Custom Accessories 36668 6' Tube with Siphon Pump" in the search field.  Two squeezes of the bulb and gas starts to flow.  Since the tubing is packaged in loops, you tie a straight stick to it and guide the suction end into the crevices of the tank.  Best of all no taste of gas in your mouth and only $6.
Jurgen
Jurgen
Offline redrider90
« Reply #29 on: August 24, 2018, 06:50:34 PM »
Gas tapper can be used on almost anything including cars up to 2014. I has a special adapter to get by the safety valve in most cars up to 2014. https://www.ebay.com/itm/142028508567?hash=item21118f0d97
Red 90 Mille GT
